Question about Sony VPL-EX4 Projector
Data projector is not turning on. How can I check for broke fuses?
  • 2,237 Answers
Open up the top case. the fuse will be on the power supply board right next to where the power cord plugs in. you'll need a continuity tester to test it. if it is blown, replace it with the exact size and type. if it is not blown, replace the power supply.
Posted on Feb 03, 2010
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
I have no power to my EPSON EMP-X5.. what should i do to make it turned on.. it has totally no power at all.. i just left it stock for 3 weeks.. and then it happens.. we use it at our church.. please help...
Hello
Just check its power chord. Without power ON, nothing can be done with the projector. Try it with other plug point. If it also does not help you, the projector need service. There is protection fuse inside it, which caannot be replaced by the user, without proper knoledge in electronics, and sufficiant tools to open it. OK.
Nov 20, 2011 | Epson EMP-X5 LCD Projector
My projector went from color to black and white then the projector turned off
Sounds like a similar problem I had not too long ago. I ended up having it repaired; turned out the colorwheel broke.
Mar 29, 2011 | InFocus IN2102EP Projector
I own a HP MP1900 projector and it wont turn on anymore...the bulb does not look blown and it never gave a going bad msg?
First check that the plug is in the socket and the power is switched on. (don't laugh, a friend did that just last week!) Next check if the fuse in the plug is OK. If you have no spare fuse try swapping one from another plug that you know does work. Next check the projector for signs of an inbuilt secondary fuse. These are often a circular access about 1to 1.5 cm across that screws out of the body of the projector. Hopefully one of these may cure your problem.
Oct 01, 2010 | HP Compaq MP1800 Multimedia Projector
The Fan does not run on my Ektalite 1500
Either the power motor has failed or the fan belt has broke. With the lamp removed (important!!), turn the projector on and see if the slide change mechanism functions. If it functions (moves your slide tray back & forth), then chances are that it is the fan belt. If it does not move the tray, then I would suspect the lamp thermal fuse has opened. Either problem will require a repair by a factory-trained repair dealer.
Feb 08, 2010 | Kodak Office Equipment & Supplies
Epson 7550c projector - ELPLP07 lamp fuse.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Oct 04, 2009 | Epson 5550c / 7550c Replacement Projector...
Projector not working
Have you tried the internal fuse? without a proper fuse in the panel you will get no power i.e. lights and such to the device. Simple but the first place to check.
Nov 02, 2008 | InFocus LP350 Multimedia Projector
NEC Projector
they have a fuse on the power board inside the projector itself, But normally the fuse does not go bad unless their is a dead short in the unit.
Dec 13, 2007 | NEC MultiSync MT830 Multimedia Projector
Sony VPL CS5 Multimedia Projector Problem
probably the lamp could be failing
or check the fan'lamp cover switches are being 'made'
Oct 17, 2007 | Sony VPL CS5 Multimedia Projector
Sony VPL-EX4 Projector Logo
303 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
