Question about Uniden DECT 6.0 Cordless Phone ID
Would like to increase number of rings before answering machine comes on.
  • Uniden Master
  • 7,993 Answers
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
Posted on Feb 03, 2010
2 Suggested Answers
mumma_1
  • 903 Answers
SOURCE: number of rings on answering machine Panasonic KX TCM 506 BX
http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
this link will take you straight to the operating manual in pdf format
hope this helps you out
Posted on Oct 28, 2008
KX-TG5621C changing number of rings
The KX-TG5621 isn't an answering machine. It will ring until you answer, some answering machine picks up, or the caller hangs up.
To change the ring count on your answering machine, refer to the documentation for that answering machine. If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
Oct 17, 2014 | Lands Phones
Increase number of rings before voicemail, vtechcs6419
The CS6419 isn't an answering machine. The phone will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on an answering machine or voicemail system, refer to the documentation for that system. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jan 28, 2014 | Vtech DECT 6.0 Digital Cordless Phone
On the uniden TRU9466 is there any way to increase the number of rings before it goes into voicemail?
The TRU9466 isn't an answering machine. The number of rings is controlled by whatever answering machine or voicemail system you have on your phone line. Please refer to the documentation for the answering machine or voicemail system to change the ring count.
If you need further assistance, please reply to this post and specify the answering machine or voicemail system.
Jan 22, 2014 | UNIDEN AMERICA CORP Uniden TRU 9466 -...
Fax is not coming through.
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Jul 06, 2011 | Lexmark X6150 All-In-One InkJet Printer
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
How do I increase the time between the phone ringing and the answerphone coming on?
It really depends on the type of machine you have. Some have a sliding indicator on the side or bottom that is for the number of rings depending on where the slide is. New models can be programed from the handset by going to menu, then initial settings, Answering, then number of rings. Type the number of rings at the prompt and hit save. That is how my new machine works.
Oct 26, 2009 | Lands Phones
Press
function
64
set
look at the printout
look for number of rings
to set the parameter
press
function 74
set
Feb 07, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
the default setting is 5 rings. if you need to change that:
set the ring to answer to higher number, however, that will put the machine in manual answering of fax.
the better setting is to rest the phone or the answer machine to a lower number of rings.
Jan 13, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I have a discontinued phone and have lost the instruction book and need to figure out why the fax machine is not letting the answering machine pick up.
you have both the fax machine and the answering machine on the same phone line.
The fax machine and the answering machine are set to answer in a certain number of rings.
In your case the fax machine is set to answer the line in less rings than the answering machine. You have to increase the number of rings of your fax so that the answering machine will work.
Aug 06, 2008 | Lands Phones
Increase rings
This is a programable item in your phone.Check your user manual.If you do not have the manual find your phone on line and look up the user manual.
tk46
Jul 17, 2008 | Panasonic KX-TG1033S Cordless Phone
Uniden DECT 6.0 Cordless Phone ID Logo
3,353 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
