Question about Welding Tools
I have a 230 volt welder wired to my fuse panel and it wont work they say it needs a plug why ?
    Champion:
  • 225 Answers
No it does not need a plug,what you are doing is called hard wiring the unit.if it is not working make sure you hookthe two primary wirers on each side of the panel,green is always ground no matter what!
Posted on Feb 07, 2010
230 volt welder
Breaker must be 50A and the size wire should be a 8/3.
Feb 23, 2014 | Welding Tools
Need info on doing an electrical hook up on a MMA 1555 inverter welder
Has it been replaced before? I would recommend getting it checked out because you can cause a fire if it is not the right size cable.
Dec 09, 2013 | Welding Tools
Inverter wiring diagram
Better get an electrician to test it if you don't want to damage the inverter.
Dec 09, 2013 | Electronics - Others
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
I have a marathon 3hp motor wired for 220 on a campbell hausfield air compressor. It has a white, black, and green wire coming out of the motor. I am using a no. 12 wire with ground. how do i wire it up to...
Hi! sims146
The Green wire from the electric motor is ground. Check the compressor motor, make sure it is wired for 220-230 Volts. If it has a white wire it could be wired 120 Volts. There should be voltage and current ratings on the motor plate. I always double check these connections. At 230 Volts this motor should be 17 Amps full Load. A 25-30 amp fuses are required to protect this motor circuit. Otherwise up to a 42.5 Amp Inverse Time Delay Breaker could be used.
The welder circuit should have 230 Volts between the Red and Black wires. The white wire is Nutral / Ground. Hopefully this is a 30 to 40 Amp circuit. The Four prong air compressor outlet, White is Neutral, Black and Red 230 Volts, Gray should be ground. Please check with Voltmeter, as some times people swap colors.
InMrFixIt
Jun 25, 2011 | Garden
I have a older lincoin ac225s welder I got this from a old man that said it worked . well it has no power cord on it and my question is is the ground wire connected to the point where the ground from the...
Hello, I was a little suspicious about the voltage on this unit. Forgive me if I am telling you something you already know on the power side of this welder. http://content.lincolnelectric.com/pdfs/products/literature/e230.pdf
The welder you have is a 230 volt single phase 60 hz. What you require is a 230 volt connection. The two line wires from the 230 are connected on either side of the switch. The ground has to be connected to the chassis / frame of the welder itself. I would not connect to the ground cable output, I would connect only to the metal chassis of the welder. This is to keep the welder isolated from the main power circuits in your shop.
Jan 28, 2011 | Lincoln Electric K1297 AC/DC 225/125 Stick...
I have a miller cp 300. It is wired for 3 phase power. I need to hook it up to 230 volt power. How do I do this correctly.
You cannot do this... 3 phase and single phase cannot be inter used... see 3 phase is 440 V AC, single phase is 230 Vots AC. This is unless the unit has Dual capability, in this case the wiring could only be wired to a Single Phase. of the unit. You will need a slow blow breaker of the correct rating and also the cable must be similarly CURRENT rated. If it IS only 3 phase, you can purchase after market single phase to 3 phase converters, that will allow you to plug the 3 phase into a single phase circuit and work, they quite costly though.
Mar 22, 2010 | Welding Tools
Lincoln mig welder 180, 230 volt 20 Amp Input. BUT! Manual says use ''Super Lag 40 amp Double Breaker, Plug on Welder Is Nema 6-50 ( 50 Amp ) Wleder cord is 12awg. What wire should be used to wire it up in...
Inspector is correct! In wall or conduit wiring awg will always be greater than "open air" wiring. IE: the size of wire coming from your pole ... it's smaller than from your service riser into your meter. Code allows the cord to heat up... open air will cool it down.
Dec 13, 2009 | Lincoln Welding Tools
Welding Tools Logo
93 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
