Question about Acer ALN 325 Network Adapter
I have an acre power fh I had to reinstall windows xp and now I can't connect to the internet no light coming from Ethernet port how do I get reconnected
  • Acer Master
  • 12,061 Answers
You must install the correct Driver for that card. Either from the DVD that came with PC, or Download from Acer's web site.
Posted on Feb 02, 2010
Ethernet controller and USB are missing on XP
Yes, the device-drivers can be downloaded from the Internet, to one computer, and then burned onto a CD-writable, or written to a USB memory-stick, and then the files can be physically moved to the other computer.
But, "which" device-drivers is completely dependent on which computer that you have. Some motherboards have "integrated" network-adapters and "integrated" USB-ports.
Easiest solution is to take an add-in PCI network-adapter card, and install it, and connect the Ethernet cable to its socket.
Hopefully, Windows will recognize that card, and automatically load the correct device-drivers from the C: drive, i.e., without Internet access.
Or, if you buy an add-in card, it may come with a CD-ROM that contains the device-driver.
Once the device-drivers have been installed, you will have Internet connectivity. Access: http://WindowsUpdate.Microsoft.com
and click "Custom" scan, and then click "Optional Hardware".
Windows Update should find the device-drivers for your motherboard, and install them. Then, you can remove the add-in card, and connect the Ethernet cable to the "on-mother-board" network socket.
Dec 14, 2009 | Microsoft Windows XP Professional
I reinstalled Windows XP to my computer and now i cant get the internet. There is a yellow question mark and exlmation point next to Ethernet Controller and it has a code 28 error.
You should have had 2 cds that came with your computer. The 2nd one has all the drivers on it. Install the drivers and your problem will go away.
Nov 19, 2009 | Microsoft Windows XP Professional
I a am running a PC running Windows XP Professional which is connected to a local wireless router by way of an Ethernet port. This router also serves two other local computers through Ethernet...
You need to check your settings in Zone Alarm here's a guide on how to setup the prots.
http://portforward.com/english/softwarefw/ZoneAlarmPro/ZoneAlarmProindex.htm
Sep 14, 2009 | Microsoft Windows XP Professional for PC
Lost CD
To get my connection to work, I had to configure my Netopia DSL modem for Bridged Mode and let my router take care of the routing and address assignment. I would also try to get a working connection before configuring security. You can always do that later. You have the order of powering up you equipment correct. Read this link. It works for me.
http://www.dslreports.com/faq/15855
Apr 20, 2009 | Linksys RangePlus WRT100 Wireless Router
Ethernet port on laptob gateway not working
http://support.gateway.com/support/drivers/search.asp?param=MX6447&st=kw
From a computer that has internet access, download the appropriate ethernet driver for your network card from the link above. As for the recovery disk, you'll have to contact Gateway for a replacement disk.
Apr 14, 2009 | Gateway MT3705 Notebook
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
Ethernet not working after format and xp reinstall
Right-click the My Computer icon and select Manage, then go to the Device Manager in the list on the left and find the Network Adapter from the list on the right, right-click Network Adapter and select Uninstall. When you reboot, XP should find the Adapter and reinstall it automatically. Another reboot may be required.
If it still will not connect, go to the NIC Manufacturer's website and download the driver to removable media. The Driver Update option can be accessed in the Device Manager, but this time select Properties when you right-click the Network Adapter, and go to the Driver tab.
Dec 22, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Internet connect is not working
It could be a problem with the card or port itself, but it could also be a problem with the drivers. Check to see if the proper drivers are loaded for your network card - for example, if there was a recent network driver update download from Microsoft, uninstall it.
If this is not the case, try unistalling the drivers entirely, and then reinstall them from a fresh copy either from the original CD or downloaded from the vendors web site.
If that does not help, it could be a problem with Windows - I'm guess it's Windows XP? If something has messed up the TCP stack, Dial-A-Fix would be able to rebuild the stack for you.
If none of these help, then a physical failure is probably the problem. You could then replace the NIC (network interface card), or if onboard (that is, part of your motherboard and can not be removed), disable it in the BIOS, and add a PCI NIC card to the machine.
Jan 27, 2008 | Dell Dimension 2350 PC Desktop
Setting up Comcast High Speed Internet with a Linksys Router
The following article will describe how to setup Comcast High Speed Internet with a Linksys Router: Connecting your cable modem to the Router 1. First connect directly to your Cable modem without the router and verify that you can get on line. 2. Once you've verified that you can get onto the internet without the router please proceed. If you can not please contact your ISP for further assistance. 3. Now unplug the Ethernet cable that connects to your DSL modem from the back of your computer. 4. Take the connection that you just unplugged from the back of your computer and connect it to the WAN port of the router. 5. Take a different Ethernet cable and plug it into port closest to the WAN port, or into the LAN port. 6. Look on the front of the router. The following lights should be illuminated: - Power - WAN Link - Link/Act (On the port that you connected your computer to) - Note If other lights other than Link/Act are illuminated on this port, that is normal - You may have a few other lights illuminated depending on the model number router you have, but the 3 above must be illuminated for proper connection. 7. Hold the Reset button on the router for 30 seconds or more 8. Restart your computer Checking the MAC address of your Computer Please follow these steps from the computer that was connected directly to the internet with out the router. If you do not, then you may not be able to connect to the internet properly. A. Windows 9x/ME 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in winipcfg and click the OK button 3. When the "IP Configuration comes up" click on the gray box the black arrow and select your Ethernet card. 4. Please make note of the "Adapter Address" B. Windows 2000/NT/XP 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in cmd and click the OK button 3. When "Command Prompt" appears type in ipconfig /all 4. Please make note of the "Physical Address" Configuring the Router 1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP). 2. When "Internet Explorer" opens type http://192.168.1.1 into the "Address" bar and click on Go. 3. The "Enter Network Password" window will appear. 4. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. By default the router will be set to Obtain an IP Address Automatically. 6. Click on the Advanced tab. 7. Click on the Mac Addr. Clone. 8. When the page loads, input the Adapter/Physical Address you made earlier and input it into the proper fields. 9. Click Apply Finishing the Setup 1. Shut down your PC. 2. Unplug the power from the back of the router. 3. Unplug the power from the modem. 4. Wait for 30 second. 5. Power up the modem. 6. Wait for the lights to stop blinking. 7. Power up the router. 8. Start up your computer. 9. Surf the internet. - *Note: If you are still unable to get on to the internet please repeat from step 1.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
The following article will describe how to setup Comcast High Speed Internet with a Linksys Router: Connecting your cable modem to the Router 1. First connect directly to your Cable modem without the router and verify that you can get on line. 2. Once you've verified that you can get onto the internet without the router please proceed. If you can not please contact your ISP for further assistance. 3. Now unplug the Ethernet cable that connects to your DSL modem from the back of your computer. 4. Take the connection that you just unplugged from the back of your computer and connect it to the WAN port of the router. 5. Take a different Ethernet cable and plug it into port closest to the WAN port, or into the LAN port. 6. Look on the front of the router. The following lights should be illuminated: - Power - WAN Link - Link/Act (On the port that you connected your computer to) - Note If other lights other than Link/Act are illuminated on this port, that is normal - You may have a few other lights illuminated depending on the model number router you have, but the 3 above must be illuminated for proper connection. 7. Hold the Reset button on the router for 30 seconds or more 8. Restart your computer Checking the MAC address of your Computer Please follow these steps from the computer that was connected directly to the internet with out the router. If you do not, then you may not be able to connect to the internet properly. A. Windows 9x/ME 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in winipcfg and click the OK button 3. When the "IP Configuration comes up" click on the gray box the black arrow and select your Ethernet card. 4. Please make note of the "Adapter Address" B. Windows 2000/NT/XP 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in cmd and click the OK button 3. When "Command Prompt" appears type in ipconfig /all 4. Please make note of the "Physical Address" Configuring the Router 1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP). 2. When "Internet Explorer" opens type http://192.168.1.1 into the "Address" bar and click on Go. 3. The "Enter Network Password" window will appear. 4. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. By default the router will be set to Obtain an IP Address Automatically. 6. Click on the Advanced tab. 7. Click on the Mac Addr. Clone. 8. When the page loads, input the Adapter/Physical Address you made earlier and input it into the proper fields. 9. Click Apply Finishing the Setup 1. Shut down your PC. 2. Unplug the power from the back of the router. 3. Unplug the power from the modem. 4. Wait for 30 second. 5. Power up the modem. 6. Wait for the lights to stop blinking. 7. Power up the router. 8. Start up your computer. 9. Surf the internet. *Note: If you are still unable to get on to the internet please repeat from step 1.
Feb 16, 2006 | Linksys WRT55AG Router
Acer ALN 325 Network Adapter Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
