Question about Marvel 61AR Compact Refrigerator
My Marvel 61 AR's stopped running. It is plugged
My Marvel 61 AR's stopped running. It is plugged in - light is on, but not running - temp is at 16C with the dial set at 5. What can I do? Is it related the thermostat, the one that I cannot find? Thanks
  • subdriver May 11, 2010
    If you can tell me the serial number of your unit I can help you determine if you have a control problem or something else. (I need to know which control it has and I can tell by the serial number)
  • 93 Answers
Most cases is bad thermostat, Marvel #800-428-6644
Posted on Mar 02, 2010
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
Jul 26, 2015 | Marvel 61WC Wine Cooler
What freon is in marvel wine cooler 61 WCMA
Don't know, but their should be a label on or near the compressor that tells you.
Mar 01, 2015 | Marvel (6SBARBSG) Wine Cooler
Zodiac ei series salt levels are fine cannot increase chlorine indicator light above 20%
need more info is this connected to a system if so you have to change it in the system if not on a system sounds like a bad control board
May 19, 2014 | Zodiac Nature 2 Cra30 Replacement...
Compressor
What information due you seek on this Marvel unit, What technical information are you wanting for this unit. This unit runs off a pod for the temp controls and if set wrong, it will not run. So what information are you seeking. The compressor is a 120V and can be wired directly to run. Please on you need of information so I can help you.
Thanks
Oct 15, 2013 | Marvel 61AR Compact Refrigerator
Where can i find parts for the Marvel 61 AR. One of the door shelf bracket supports broke. The small white piece that hold the aluminium bar to the door itself
Call the factory at 1-800-223-3900 or contact them via marvel@marvelindustries.com
There are very few companies that stock their replacement parts. You can order direct from the factory with a credit card.
Dec 17, 2009 | Marvel 61AR Compact Refrigerator
I have Marvel 6bar beverage refrigerator that suddenly stopped cooling- any suggestions on how to fix- I am trying to avoid paying a couple hundred dollars for repair thank you for your time
If light work but not running at all, then change the temp control (thermostat). If compressor and condenser fan motor are running but not cooling, then you have sealed system problem
Dec 01, 2008 | Marvel 6BAR-BD Beverage Cooler
Panasonic casette air conditioner-display error temp 'CHECK'
Check that your water pump is working and not blocked up as the unit will keep swicthing off if it can not get rid of the water.
Nov 24, 2008 | Panasonic CW-C60RU Air Conditioner
Marvel 6BAR stopped cooling
The dip switches define the temp range. You have it set to the warmest. Try moving the next dip switch to move the range cooler.
Jun 23, 2008 | Marvel 6BAR-BD Beverage Cooler
Marvel 61AR Compact Refrigerator Logo
463 people viewed this question
Top Marvel Refrigerators Experts
richie46
ray gallant
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
