Question about Sony Playstation 3 (PS3) Console
Ps3 switches on then it just goes off then comes back on while you are useing then its ok for a while then off it goes again then back on
  • Sony Master
  • 12,061 Answers
Sounds like a classic internal Power Supply fault. You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done
Posted on Feb 02, 2010
My ps3 turned off during a game, when you try and turn it on the light on the power switch goes green for about 3 seconds then switches off again and has a red flashing light
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning.
So in order to fix the blinking red light on your PS3 you will need to repair the connection between the HDD and the motherboard.There is actually a rather simple way that you can do this yourself; while your PS3 console is switched off, locate the hard drive enclosure on the end of your console. Remove the plastic cover plate, then using a screwdriver unscrew the hard drive itself from its socket. Carefully remove it completely, then put it back in again. Tighten the holding screw, then restart your PS3
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
When playing regular dvdson my ps3, the screen will sometimes go black for just a second or two then come back on. I sometimes notice a red or green flash of color right before the pic goes out or comes...
Ok I have had this happen a few times before. What I do to fix it is disconnect the HDMI cable while everything is still on and playing and then re-insert the cable back into the TV. This re-configures the HDMI signal and should hopefully stop this problem.
Hope this helps and thank you for using FixYa
Aug 31, 2010 | Sony Playstation 3 (PS3) Console
When i turn my ps3 on the light on the front comes on green then goes to amber and then goes back to red meaning its turned its self of, nothing comesup on the screen either, plus with it doing this there...
The best way to fix PS3 light goes amber and back to red is to fix by yourself! Learn the PS3 fixing technique by using this product here :
PS3 Ultimate Fixing Guide
This is a package of text and video tutorials written by a professional PS3 repairman. Follow his demo you can easily to unscrew your console and fix parts inside. When you have learned the repair skills, no need to ask anyone here again!
Aug 10, 2010 | Sony Playstation 3 (PS3) Console
Hi,my ps3 is saying, the hard disk's file system is corrupted and will be restored. the it says press ok. after i press ok, then it says restoring the system, after that it restarts it goes back to the...
here's some ideas:
________________________
I fixed my ps3!! All you need is a friend with a ps3!! Swap the hdd's and boot up your friends ps3, format the hdd, put it back in your ps3 and you may need to format it again.
_______________________________________________________
I tried to fix my friend's PS3 HDD that way in mine...it still gave an error every time he booted up his PS3. At that point I stuck the PS3 HDD in my laptop, booted from a Windows CD and fully formatted it that way...stuck it back in his machine...used it to format....finally got his stuff going. Took a little extra time but no problems since.
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my ps3, the background pops up but the menu doesnt appear, i tried to connect the controller with the usb port but nothing works. it doesnt do any thing, HELP!!!!!
Turn your PS3 completely off by pressing the power button and then turning off the power switch in the back. Your PS3 should show no lights. Wait about an hour to let the system completely cool down, then turn the power switch on the back on again. Now press the power button and hold it until the system beeps. This will reset a few settings and make sure the system is OK. Hook your PS3 up using the RCA Red White and Yellow cable and turn it on again, and you should be able to be back up and running.
Jan 30, 2010 | Sony Playstation 3 (PS3) Console
My ps3 works with a hdmi cable but it will not display to any tv.
hold your finger on the restart button(the button next to disc eject button) for 5 sec to reset the settings
Jun 05, 2009 | Sony Playstation 3 (PS3) Console
How do you change the output setting from hdmi to the rca cable setings? I have no picture screen on my crt tv.
you have to reset the ps3 because you have it with hdmi before and the ps3 is looking for an hdmi connection is very easy and there is nothing wrong with your ps3 ok so do the follow
turn the power switch off on the back of the unit then put your finger in the on/off switch now turn the main switch on the back of the unit you will heard a first bip sound this is when your ps3 turns on ok keep your finger there in the on/off switch until you heard another bip sound now remove your finger from the on/off switch and bingo this will reset your video settings now you can see picture again using regular av and every time you use hdmi you have to do this again
Jun 05, 2009 | Sony PlayStation® 3 (80GB) Console
Flashing red light
The best way to fix PS3 light turns itself off and won't come back on is to fix by yourself! Learn the PS3 fixing technique by using this product here :
Apr 25, 2009 | Sony Playstation 3 (PS3) Console
The Hard Disk's file system is corrupted and will be restored
apart from physically reformating the hard drive yourself (taking it out and loading it on laptop or desktop and format, at your own risk), there isn't much else you can do. If the console is still guaranteed then contact sony and they will send you a new one.
If you do format it your self when you replace it in your ps3 you will need to format it again using thier options.
Nov 15, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
102 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
