Question about Pioneer PL-990 Turntable
Motor turns feebly, not enough to make the platter
Pioneer PL-990 turntable, several years old.
Turned it on for the first time in over a year.
Lights up, but platter doesn't turn.
Upon removing platter and belt, I find that the
motor turns feebly, but not enough to make the platter turn.
Bad belt?, Needs oil?
  • Pioneer Master
  • 5,259 Answers
Sounds like the motor is bad if you say it turns feebly. See if you can turn the drive shaft with your fingers easily. If you find it hard, it's possible that something might have worn out. You could try oil in that case.
Posted on Feb 03, 2010
How can iget the belt back on my turntable pioneer pl 990
PUT IT ROUND THE PLATTER BASE FIRST,THEN LOOP A BIT OF STRING ROUND THE BELT LONG ENOUGH, SO WHEN YOU PUT THE PLATTER BACK ON,YOU CAN LIFT IT UP A LITTLE BIT WHERE THE MOTOR WHEEL IS THAT TURNS THE BELT, PULL THE STRING TOWARDS IT SO THE BELT GOES OVER IT.DROP THE PLATTER THEN PULL THE STRING OUT.
Mar 31, 2011 | Pioneer PL-990 Turntable
Hello My turntable do not spin
This turntable is a belt driven type. The belt wraps around the underside of the platter and the drive motor spindle. If the belt has slipped off, broken or is so old that it is slipping - the platter will not turn. Usually you can remove the rubber cover on the top of the platter to use access openings beneath to put the belt back on.
The turntable product brochure, owner's manual and related info is available from Pioneer, here.
I hope this helps!
Dec 03, 2010 | Pioneer PL-990 Turntable
My pioneer PL990 turntable, the pitch wavers.
try cleaning the inner ring on the underside of the actual turntable platter and also the motor spindle using isoprynol alcohol or use neat clear spirits like bacardi/vodka with cotton wool etc. if black residue comes off either the platter or the motor spindle that will be residue from the old belt that could cause the fluctuation in speed? good luck.
Jul 10, 2009 | Pioneer PL-990 Turntable
Pioneer pl 990 turntable
Lift off the platter mat, then lift off the platter from the spindle - gently.
Underneath the platter is a sub-platter around which you place the belt - it should be held there by the stretch of the belt while you turn the platter back up the right way and place it back on the spindle.
Turning the platter by hand, you should see a small pulley come into view through one of the holes in the platter. You then stretch the belt slightly so that it slides over the pulley. Take care not to twist the belt while doing this.
Jan 10, 2009 | Pioneer PL-990 Turntable
My pioneer turntable pl 233 not been used for years. Despite new belt, keeps slowing on playback. Does it need motor lubricant?
Hello, You need to remove the platter\ remove the old bearing grease\ re-lube platter bearing with new 30w motor oil. Good luck
Dec 10, 2008 | Audio Players & Recorders
Help need to replace beltplease help turntable
FAIRLY SIMPLE...
1) REMOVE THE PLATTER
2) WRAP THE BELT AROUND THE INNER CIRCLE FOUND ON THE BOTTOM SIDE OF THE PLATTER, THE BELT SHOULD FIT PERFECTLY....
3) PLACE THE PLATTER BACK INTO PLACE...
4) THROUGH ONE OF THE SPACES ON THE PLATTER, TAKE THE BELT AND PLACE IT OVER THE MOTOR WHEEL...THAT SHOULD DO IT.
Aug 18, 2008 | Pioneer PL-990 Turntable
Platter problem
It sounds like the motor pulley is too high. try to screw down the pulley, maybe it came loose...The platter is designed specifically for the turntable and should fit perfectly in place....Another reason might be that the platter does not belong to the turntable, it might be too small and therefore sits lower than it should.
Jun 30, 2008 | Pioneer PL-990 Turntable
Pioneer pl 990
Remove any tape from the belt
That is the drive belt for the turntable .
It's not that hard to set up. Take the mat off the platter and wrap the belt around the underneath -slightly-less-diameter portion.
With a pointed end needle or something like it , put the tip between the belt and the platter portion it's wrapped against.
Pull the belt away from that( keeping the rest of the belt on the platter portion) and set it over the motor pulley. This is usually a small diameter brass spindle unit
Mar 27, 2008 | Pioneer PL-990 Turntable
Belt off
Lift the platter. PLace the belt under the platter on the inside ring. PLace it back on the turntable, and you can stretch it back onto the motor with your finger or black stick through one of the holes on the platter, while the platter is positioned where it is accessible. if you need a replacement, try...
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES-Drive_Belts/c271_272_278_398/index.html
the technics belt #2 seems to be universal. The staff there is top notch and can get you the correct belt. Call them with your model.
Keep me posted.
Nov 03, 2007 | Pioneer PL-990 Turntable
Pioneer PL-990 Turntable Logo
248 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
