Question about HP Officejet Pro L7580 All-In-One InkJet Printer
I get a carraige jam. It asks me to remove paper,
I get a carraige jam. It asks me to remove paper, there is none. The carraige is striking the part of the service station, or spittoon that comes up to cover the tips of the printheads.
  • 240 Answers
Sounds like it needs serious servicing. You can look at having it fixed but it may just as well be worth it to replace the machine.
Posted on Feb 02, 2010
Every time I send a document to print, I get the message, "Paper Mismatch. Paper detected does not match paper size of type selected. Change paper and press OK on the hp officejet to continue...
When you print the document then select the size of the paper you want that to be print in. It will ask you when you print the document. It might be the case the default A4 size is set to other.
Try it might it can help you out.If not leave a comment will provide another solution.
Oct 11, 2010 | HP OfficeJet 7310 All-In-One InkJet...
I cannot get the jam out. Seems like I need the top cover off.
hello, have you already turned machine around to look at back of machine, and pulled off the rear cover, sometimes you can get the whole paper out this way. now if you already replace back cover and turned machine around, lift up front cover as if you where going to replace color ink, you will see a small door, lift this door up, and see if you can see the paper, and remove it, now if the print carraige is there, move to the left, all the way, look sideways from the left, and check to see if there is some paper on the right , if so remove. go ahead and close covers, if pressing ok to recover from paper jam, then power off, wait a few seconds, then power on.
Sep 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
Carraige jam. Screen says to clear carriage jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 08, 2010 | HP Photosmart D5360 Printer
Carriage Jam
Carraige rod is the rod that holds the cartridges and moves while printing on the paper and spreads ink on the paper and if this rod is jammed it is known as carraige jam.
Please follow the below steps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01423360&cc=us&lc=en&dlc=en&product=3204464
Please open this link and follow the steps.
If still the issue persists, please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Thanks Bye.
Please take care and KEEP SMILING.
Apr 10, 2010 | HP Photosmart C5280 Printer
It say carriage jam
Hi friend,
What probably happened is that paper jam caused the carraige alignment sensor to get out of place or to get covered, moved, etc and the printer doesn't know what to do...
What I would suggest trying is, unplug the printer, try pulling the carraige out to the center and then close it and plug it back in, see if this kicks it enough to reset itself.
Thanks,
Mar 20, 2010 | HP OfficeJet 7410 All-In-One InkJet...
CARTRIDGE JAM - CARRIAGE JAM - PAPER JAM - RESET POWER
change the carrage block will solve this issue.the carrage block cable is damaged
Jun 10, 2009 | HP Officejet 5610 All-In-One InkJet...
The paper is not feeding into the printer straight. And sometimes jams. The paper jamed when I tried to print onthe back side of a sheet of paper.
if its an inkjet printer then please mark that the catridges are able to free scroll on the carraige and if they fail then remove the catridges take a clean piece of cotton clean the foil which connects the catridge to the circuit , this worked for my HP 3940,
Mar 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Carraige Jam
maker sure the cleanout station is not stuck..it moves also...dont break it just see if it isn stuck...move the carriage back and forth. put paper in it and turn it back on.....if that does not work..take the paper out ..open the back and roll th big wheels a bit and try again.
Oct 13, 2007 | HP WanProbe V-Series Network Monitoring...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
112 people viewed this question
Seeker5211
Seeker5211
