Question about Lasko Ceramic Heater
My lasko 5144 heater just stopped working. It was running and a piece of cardboard fell against it and then the heater stopped and it will not start up again. I cannot find the owner's manual.
2 Suggested Answers
  • 35 Answers
SOURCE: I lost my owners manual & would like to know
Follow this link:
http://www.laskoproducts.com/heaters/heaters.html
and put in your model of heater. Once on your models page, the link to the manual is near the bottom of the page, a red link.
Posted on Mar 15, 2011
Osilating stopped on lasko 2554 fan
Lasko's are good for stripping the gear in the base that makes it oscillate. If it's still under warranty, they will send you a new fan.
Jul 28, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
Schematic plf504d thermalinc
My experience with Lasko heaters is with the small portable ceramic types. On mine there are two knobs. One is the "Power"; the fan symbol is for fan only, then (I) Low Power and (II) High Power 1500 watts. The other know is the thermostat from (-) to (+). Set the thermostat towards (+) until the temp in the room is the way you want it. Then turn the thermostat know towards (-) until the unit shuts off. This is now the temperature setting and the heater will cycle on and off to this setting. Hope this helps.
Dec 13, 2013 | Lasko 5610 Baseboard Heater
My suzuki rm 250 starts and runs for a few seconds then stops . I have taken carb of and cleaned it out and seems to be fine. there is also a really good spark from plug.
First up, check all electrical connections are good, especially magneto wires exiting crankcase and CDI and coil. Check the continuity of the different phase wires with a circuit tester to be sure.
Disconnect the manifold from airbox to rear of carby, at least enough to put a flat piece of cardboard against back of carby throat inlet. Start, and if bike stays running, you have an obstructed air filter or airbox inlet.
If it still stops, then place the cardboard firmly across carby inlet and turn over engine with throttle open. There should be fuel visible on the card. If no fuel on the card, you have fuel delivery issues and likely cause is an obstruction in jets or float needle/seat. Check condition of fuel filter and fuel flow from tap also.
If you have fuel visible on the card you may have badly set air mixture screw (generally 1.5 turns out) the wrong sized jets fitted or a leak in the inlet manifold. Are the reeds in good condition?
Goodluck, cheers!
Nov 13, 2010 | Suzuki RM 250 Motorcycles
My microwave stop working the clock and timer works but food is still cold. (The round cardboard piece on it's ceiling fell off about 3 months ago.)
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 09, 2010 | Sharp R-1480 Microwave Oven
I have a Lasko Model 5532 electric heater. It has suddenly started shutting off often. I run it through the reset procedure (unplug 5-10 minutes, then restart) and that gets it going again, but then it...
All of these space heaters have thermal protection units in them. They are safety that shuts the unit down if it starts to overheat.If your fan is operating, then it sounds like the thermal protection circuit is faulty, and you'll need to contact Lasko for a replacement. These units do not have parts that can be purchased due to their UL compliance. Check the fan though, it might be obstructed. I have seen that more than once....Rob
Dec 28, 2009 | Lasko 5530 Ceramic Compact Heater
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Lasko heater beeps too LOUD
I was cleaning out my Lasko ceramic heater 6000, looking for instructions on how to do so, and came across your comment. After I opened it up and cleaned everything out (really easy, no instructions needed, it is all obvious) I started thinking about how much I hate that beep as well. So I decided as long as I had it opened to try to disable it.
Well, I could tell from plugging and unplugging that it was (unfortunately) mounted on the under side of the green circuit board. You will have to unscrew the circuit board completely (all wires still attached) and (carefully!) move it so you can flip it upside down to get to the other side. Note: there were 7 screws to remove and 1 was under the motor and really hard to get to. The motor looked WAY too complicated to remove so I got the screw started just a little with a precision screw driver and turned it the rest of the way with needle nose pliers.
Once the circuit board is off, the beeper is a little black circular thing (about 1/2 inch in diameter) with a little hole in the middle. It has a serial number on it and a "+" symbol. It looks like it is built in two pieces (upper and lower), so I tried to carefully remove the upper piece with needle nose pliers while leaving the lower piece connected to the circuit board. Well, the whole thing ripped out! I thought two things: 1) It will never beep again, and 2) I hope this didn't break a circuit causing the whole thing to fail.
Well, I put the circuit board back on ( I left off the one difficult screw, as 6 of 7 is more than sufficient to hold it on). Put the whole unit back together, and . . . . IT WORKS FINE!!!!!
Nov 30, 2008 | Lasko Ceramic Heater
Lasko 5365 Ceramic Compact Heater Troubleshooting Forum.
Try taking a can of compressed air and spray in the vents in the front and the back of the heater. The heater has a sensor that gets dusty and causes it to shutoff to prevent overheating.
The heater should function properly once the dust is blown off the sensor.
Dec 02, 2006 | Lasko 5365 Ceramic Compact Heater
Lasko  Ceramic Heater Logo
715 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Mack Baxter
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
