Question about Whirlpool Duet GHW9150P Front Load Washer
Same problem but I have a 3 week old maytag 9000 steam dryer, ran for a few minutes then turns off and display reads F 70
  • 506 Answers
From everything I have read on the F70 code (can't seem to find an exact explanation of what it is) It seems like people are getting replacement dryers due to a electrical problem within the dryer control circuitry. Since it is only 3 weeks old, get it replaced. Good luck
Posted on Feb 02, 2010
My maytag 9000 series with steam reads f01
it means one of the tubes is blocked this link should help you.
http://www.shopyourway.com/questions/1173878
Jan 22, 2017 | Maytag Dryers
Dryer is a week old. ran a cycle and dryer turned off. didn't trip breaker. wouldnt turn back on. so turned breaker off for a while then turned it back on. now dryer powers on but for only like 10 seconds...
A week old dryer should have, in its warranty, a condition that you can get them to exchange this for an identical (hopefully working) model free. Do it now, that is a short time window. It's usually one month.
Nov 16, 2013 | Samsung DV50F9A8EVP 27" Electric Dryer...
Dryer displays F 70 code. How do I get it to stop?
Unplug the dryer for 30 minutes. Then reconnect the power cord to the outlet. This will reset the code temporarily. Unfortunately, the code means that the central control unit (clock) isn't communicating with the rest of the components correctly. You probably will need a new clock or dryer (depending on the warranty status). If the unit is under warranty, contact Whirlpool or the store where you bought the dryer (if it is brand new).
I wish that I had better news for you.
Jun 05, 2013 | Whirlpool Duet Steam WED9500TW 7.2 Cu. Ft....
Screen reads CF1, and does not work
Maytag 3000 series .Dryer screen reads CF1, then CF2... then Cf3 and does not work
Apr 03, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The lights on the dryer work it wont start it didnt have any problems drying before this happened no odors or smells i have a maytag MDE5500AYW. please help. thank u
If the display on the dryer reads '88' then place a heating pad over the display. After a few minutes, the '88' code will clear, and it will work fine. Sounds crazy, but works every time for me.
Sep 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Maytag Bravos Steam dryer that reads service error code F1
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 30, 2009 | Kenmore Elite HE4 Electric Dryer
Maytage dryer squeak
do NOT use WD40 in a dryer. WD-40 has considerable flammability ingredients. the rotor is most likely the blower . check the wheel and the motor. could be loose or have something in it... if you want to lubricant.. use a high temp lubricant made for dryers..
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dehumidifier
After reading comments and complaints from other frustrated Maytag owners, I just went out and bought a new LG EnergyStar dehumidifier. I'm taping the receipt inside a plastic bag, along with the user manual, to the side of the machine. Hope this one works for a LONG time! Ronnisue
Jun 15, 2008 | Maytag Dehumidifiers
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
278 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
