Question about Maytag Ovens
Our oven doesn't heat and smells like gas
When you turn the oven on it doesn't heat and smells like gas. When the oven is off it isn't leaking gas - we tested this.
  • 221 Answers
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Posted on Feb 02, 2010
A tenant of ours is saying that their Maytag 27" single oven of: Every time we turn on the oven, there's a very strong gas smell for at least the first few minutes. The oven is heating ok.
you should probably go over or send someone ASAP to pull it out and check the lines are connected properly and haven't become damaged.
Could you imagine the lawsuit and property damage if their was a gas leak. This is the very reason gas has an odor added, it is the only warning sign of a potential leak and explosion.
I would take this very serious and give immediate attention.
Nov 15, 2016 | Maytag Ovens
KGHST307HBS6 bake cycle does not heat up, no gas smell, broiler still works, ignitor glows about as bright as the broiler ignitor and was recently replaced. The gas valve recently replaced and no smell of...
you have 2 posibilities the first one is very unprobable and the second will fix the oven
1) the new gas valve is defective and while the proper amprage is being supplied to it,it simply wont open
2) even though the bake ignitor is indeed coming on it isn't drawing the proper amp draw (3.2-3.6 amps) to open the gas valve ,the very fact the ignitor comes on totally eminates that the control isn't providing power to it for the bake ignitor to heat
i have been a appliance repair technician for over 30 years and am 100% confident that by replacing the bake ignitor the oven will work fine
Jul 20, 2011 | Ovens
Hoping someone can point me in the right direction. Oven won't light, but the stove top burners are fine. Don't smell any gas or any indication the oven is attempting to light....
next time send the brand name and model number so i can look up your machine,if it's a gas stove most likely it will be a bad ignitor,even if the ignitor glows it still could be bad,if the flame doesn't ignite and the ignitor is glowing change it out,if it isn't glowing pull out the ignitor and check it with a meter,common problem.
May 07, 2011 | Ovens
My oven works fine it just doesn't heat-up. I can hear ignition clicking but no fire from burners. A technican told me to purge the union above gas to get rid of air in the line. Thanks Louis
Personally I wouldn't describe an oven that doesn't heat up as working fine. You shouldn't have any air in your gas line unless this is the first time firing the oven, in either case the air in the gas line would work its way out eventually and the oven would light on its own.
Check to see if your ignitor is glowing before you hear the clicking, if the ignitor isn't glowing it needs to be replaced and is fairly easy to do so. If your ignitor is glowing you should check to make sure you are getting gas to the burner. The only way I would recommend checking this is with your nose, do you smell gas when the gas valve clicks? If you do then something is wrong with the burner, either dirty or the exhaust is too strong, or even gas pressure too low. If you don't smell any gas that doesn't necessarily mean no gas is coming out, at this point you should call a authorized service provider to take it over from here.
Nov 03, 2010 | Baxter BXA2G Stainless Steel Gas Single...
When I first turn on the oven I can smell gas. This just started so I don't that it is a leak at a gas line connection poin. It must have something to do with an internal valve.
Have the Glow bar ignition, thermocouple and gas regulator valve checked. It is not un-common for some gas smell as the Glowbar heats the thermocouple bulb.
This in turn when reaching the correct temperature activates the gas regulator. If the Glow bar is not providing ignition quick enough. More gas can be released before combustion is initiated. This extra can be the smell you are experiencing now.
Best to have the unit serviced by a qualified technician to be safe.
Good luck Luck be safe!
Nov 26, 2009 | Maytag CWG3100A Gas Single Oven
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Build in Over Gas - Oven does not heat
I called a repairman it was the igniter.
Jan 26, 2009 | Magic Chef 9122 Gas Single Oven
Oven gas
For safety purposes call gas technician to check your gas pipe. If stove turn off supposed not to smell gas.
Jul 23, 2008 | Frigidaire FGB24S5A Gas Single Oven
Gas Smess
the gas might be too high, try turnin it down, or their is a falt with the oven
Jan 13, 2008 | Ovens
Gas leak from oven
Sounds like the ignitor is weak and needs to be replaced. How old is the oven and what is the model # from the sticker on oven?
Nov 06, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
490 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
