Question about Swintec 7040 Typewriter
After removing the paper roller to clear a jam, I am unable to re-insert the roller without it sitting in there too tight to roll the paper. Is there a trick to this?
  • Swintec Master
  • 3,594 Answers
The tray is probably not positioned correctly.
DickyO
Posted on Feb 10, 2010
There is a piece of paper jammed in the roller, but we can barely see it. We have taken the doors off but have not removed the rear panel. We can see the paper but unable to get a hold on it. What do we...
1) if you have a vacuum cleaner try use vacuum cleaner to suck the paper out.
2) IF YOU CAN TOUCH THE ROLLER, TRY TO ROLL THE ROLLER TO ROLL OUT THE PAPER.
Jan 08, 2015 | Office Equipment & Supplies
Clear paper jam pcr t2000
It\'s very unusual for the paper to jam as this machine uses a clam shell type of printer. Just raise the printer arm and remove the paper roll. Clear any paper from the print head and roller etc. Tear any wrinkled paper from the roll and then refit the roll with the shiny side of the paper towards you. Lay the paper in the printer and close the printer arm down onto the paper. If you are setting the journal side, wind some paper onto the takeup spool after it exits the printer and sit the spool into place.
If anyone needs a Casio PCR-T2000 manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T2000_users_and_programming_manual.html
Jul 08, 2014 | Casio Parts Cash Register PC Desktop
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
I'm getting Jam at Reg Roll on my Phaser 6180, and I think there may be a bit of paper in the paper path, but i can't see it. The machine says Open Door A, which I've done a few times, but it isn't...
Had exactly the same problem... today actually.
Found the solution with another model's manual - I removed the paper from the top, but hadn't realised there was a jam in the paper tray. It was only when pulling it out completely that I found it as below...
Jam at Registration Roller
1. Remove Tray 2 completely.
2. Clear the jammed paper from the printer's
intake slot.
3. Re-insert Tray 2.
4. Open front door A.
5. Remove jammed paper if present.
6. Close front door A
Nov 23, 2010 | Xerox Phaser 6180N Laser Printer
I have a aficio 200 and it is showing a fault misfeed at a and i have removed the paper but it seems to be stuck at that point
If after clearing the jam; the machine warms up, trys to feed again, and jams. There is something causing it to jam. This could be a feed roller, clutch, or sensor. If the jam never clears; you likely have a small chunk of paper sitting on a sensor, or a faulty sensor. Get a flashlight and take a good look into the "a" section, its a tight area but also short, so finding the paper shouldn't be too hard if there is some in there. Getting it out may require a long screw driver or canned air.
Nov 05, 2009 | Ricoh Aficio 250 Copier
HP 7680 paper jam
I spent 21/2 hours with the HP tech support - with their recomendation to upgrade my 14 month old computer to the bigger model because the screen reads "paper jam". I have had this printer replaced once already, 1 week after I received it for a defective doc feeder. I decided to take things into my own hands - First of all, no paper was ever located in the paper jam area. Several soft resets by shutting down for 20+ seconds, then pressing #6 at start up resulted in any improvement - the screen continued to read "paper Jam....." the HP tech was unable to offer any practical suggestions.
I turned the machine upside down after removing the document feeder and examined the rollers at the back of the rear tray where the paper jam was supposed to be. I noticed that there was some black residue on the gears and although the machine was off and unplugged - the rollers / gears would not roll freely and seemed to get stuck. I cleaned them thoroughly with an old but clean toothbrush and water. (don't grease the gears - I've heard it eats the plastic) - until the rollers would freely roll when I moved the gray rubber rollers.
Returned the machine to correct position - and turned it on - "paper jam" message returned but the machine was sounding different than it had - so I did another soft reset (unplug from wall and printer for 20 seconds, then holding #6 for a few seconds while plugging back in and now I can print. The printer went through its maintenance cycle and did a realignment. I can print and everything is working fine at this time.
I hope that this will help someone. I couldn't find any information on how to repair the printer and HP seems to be all about producing junk and convincing you to "upgrade" at a cost of $2-300. When this one does finally go - I won't be buying an HP!
The 7680 jams a lot and the document feeder has a lot to be desired. It has trouble feeding straight and if there is a jam anywhere in the machine - it is always difficult removing the paper without tearing it and creating more problems and waste of time.
Oct 20, 2008 | HP Officejet Pro L7680 All-In-One Printer
My printer is a MFC-685CW made by Brother. We cleared a paper jam and unplugged it as it suggests to do in our user manual. Our screen still says Unable to Print AF. Can someone help, this is very...
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
http://www.fixya.com/support/t227515-printer_paper_jam_brother_mfc
Aug 23, 2008 | Brother Office Equipment & Supplies
How do I clear jammed paper when there is no paper showing
I JUST MANAGED TO CLEAR MY PRINTER.  I UNPLUGGED EVERYTHING AND PUT MY FINGERS IN WHERE THE PAPER ROLLS IN.  I ROLLED THE ROLLER UNTIL I FOUND THE TORN PAPER.  GINGERLY I REMOVED IT.  NOT EASY.  MY PRINTER WORKS AGAIN! ALFIANNA
Apr 03, 2008 | Canon i850 InkJet Photo Printer
Panasonic Fax Phone Can't send or Receive fax
there maybe a small paper jam in the machine that you are missing. if you are handy, unplug the fax machine and look around where the paper is fed into. if you see paper trapped anywhere, try pulling it out with a pair of needle nose pliers. the machine will not work right till the jam is cleared.
hope this helps.
wg
Feb 10, 2008 | Office Equipment & Supplies
Swintec 7040 Typewriter Logo
51 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
