Question about BenQ PE5120 Multimedia Projector
Lamp died and remote does not work - BenQ PE5120 Multimedia Projector
  • b_reynold772 Feb 02, 2010
    i know that, but i really need to know is are the two problems related in any way. Why did the bulb go, there was only 650 ish hours on it. do i have a bad balest (spelling) what causeed the lamp to go. how can i check the balest to see if it is faulty
  • samwise342 May 11, 2010
    What exactly do you need help with? If the lamp is dead you need to buy a new one and install it.
  • 51 Answers
I don't think the problems are related. The bulb shouldn't have failed as it is rated at 2000 hours. As for testing the ballast I don't believe that a conventional meter would do it. You would need a lamp testing device. For more go to http://www.myprojectorlamps.com/testing.html Since projector lamps or ballasts are not cheap you may want to have a a/v repair shop check your projector, because of the early bulb failure.
Posted on Feb 02, 2010
My HLP5063W tv comes on and works for 3 to 5 min then the pictures gets dark and the colors are distorted. The remote no longer operates the set and I can not turn it off using the front or side switch. ...
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours which is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen. Try Encompass .com ; shopjimmy.com
Jun 11, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
I got Two TV's My TV Connected to remote 1 in IR mode. After trying to record some thing using dvr the remote dies on satellite cannot change channel... Tech team tries every thing send new remote and...
topscrew2002
From what you have written, when you try to record on your DVR the remote stops working, is that correct? How long has this been happening? Have you received a new remote? If yes and it is still happening, you are probably getting IR interference from some source in that room. It could be from a florescent lamp, another player, or even the TV. Is the receiver in a open space or in an enclosed area? The IR sensor has to have a direct line of sight to work properly. You may also check on the receiver if anything is obstructing the sensors, maybe dust. I hope this helps.
Ray Calo
DISH Network
Dec 02, 2009 | DISH Network IR Remote Control
Unresponsive, lamp dies upon start
if you don't hear a high-pitched whir, the colorwheel is shot and needs replacing. if you do, one of the fans might not be working and the heat shuts it off so as not to cause damage.
Oct 15, 2009 | InFocus ScreenPlay 4805 Multimedia...
MD5880N replaced bulb and worked for 2 hours now nothing
Place heat shielding around the lamp to prevent overheat; use cooling spray (freon) to cool any chips or, circuit boards near the lamp as you attempt to start the set check the lamp for the correct serial # voltage etc.
Aug 02, 2009 | HP Pavilion MD5020N 50" DLP HDTV
Sony vpl-hs20 cineza projector- reset lamp counter
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Jul 19, 2009 | Sony VPL-HS20 Multimedia Projector
I cannot reset my lamp clock
http://answers.yahoo.com/question/index?qid=20080221185527AAvGCui
I just now replaced my lamp and tried the solution on the above bookmarked site (hold down VOL- on the TV itself while holding down the SPLIT button on the TV remote simultaneously for several seconds... I didn't need all 20 seconds that this site recommends), and that worked for me. About 5-10 seconds in, I saw a blue box on my screen that basically said "Lamp timer has been reset to 0" with an "Exit" box below that. It took me a while to find the "Exit" button on my remote control to clear that box off the screen, but that's how I cleared it.
My TV is just short of 3 years old; I bought my Panasonic PT-52LCX65 on "Black Friday" (day after Thanksgiving) in 2005. My lamp died last Saturday night.
Hope this helps! -- ChuckE
Jun 06, 2008 | Panasonic PT-52LCX65 44" HDTV
Fan does not work, light does
Your remote uses a slightly different band of IR for one and the other functions; lamp or on/off. This IR lamp or the circuit that controls the IR lamp has failed. You will need a new remote.
Hunter is good about making replacement parts available but as you said this is five years old. You may have to look for an after market seller on Ebay and chances are very good you can find a new one there.
Try Hunter first:
From Hunter Customer Care
Email:
Use Our Contact Form
Phone:
1-888-830-1326.
Monday-Friday 7am-6pm CST
Regards,
Worldvet
Jun 03, 2008 | Hunter 27177 Remote Control
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
50V500A
if the lamp has dies alot of the time to can look inside the lamp and see if it exploded (not always) do you get blinking lights?
Feb 01, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Lamp clock reset
The only way to reset the lamp timer is with the LG programmer remote, however resetting the lamp timer does not affect the picture quality. If you need a part # for the remote let me know. Maybe you can find an auth. service center who will let you use the remote. If they do, simply power the unit up and when running hit the instart button on the programmer remote and after the menu comes on the screen simply hit the offstart button. The unit will shut of and when you power it again the lamp timer will be reset.
Nov 04, 2007 | LG RU-44SZ61 44" Rear Projection...
BenQ PE5120 Multimedia Projector Logo
161 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
