Have plugged in the two cords necessary for the function of the printer, but cannot turn it on.
  • 1,511 Answers
Hello Ma'am
I'm Waqar. I hope you remember me (Wiqi546), we just had a Live chat session on Fixya.
I request you to please Login back to your FixYa account and on the top right corner you will see a 'My Profile' link, go there and find the chat we had.
And kindly leave some feedback after accepting the solution IF you found me helpful, as that will be useful for FixYa's future reference.
I hope you will spare some time for this. We will feel obliged.
Regards.
Posted on Feb 02, 2010
Printer works but gives blank page
Issue: Scans and copies output a blank image Solution: Press ON/OFF switch to reset the multifunction device Reset the device when it is not functioning properly.If the device is not functioning properly or to clear memory, reset it.Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. Click here for instructions to attempt a service reset.On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.) Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Wait approximately ten seconds and then press the <ON/OFF> button again.Wait until the device has completed its cycling process before submitting another job request.Service Reset:On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Confirm the printer is not on and then unplug the power cord from the back of the printer.If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.Press the <ON/OFF> button repeatedly five times. Re-connect the power cord.Press the <ON/OFF> button to power the printer back on.Wait until the device has completed its cycling process before submitting another job request.Important:This procedure will not resolve a physical hardware issue. For example, a paper clip is wedged between the paper feed rollers or gears; or, the scanner assembly is detached from the inside housing.This procedure will not resolve all service errors or LCD related anomalies.Service errors appear as four characters (a combination of alpha and numeric codes).
Oct 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
How do you clear memory - its telling me its full but I have no message saying cartridges need replacing
Issue: ERROR LCD: MEMORY FULL
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it. important.gif Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. for instructions to attempt a service reset.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Service Reset:
  1. On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)
  2. Confirm the printer is not on and then unplug the power cord from the back of the printer.
  3. Press the <ON/OFF> button repeatedly five times.
  4. Re-connect the power cord.
  5. Press the <ON/OFF> button to power the printer back on.
  6. Wait until the device has completed its cycling process before submitting another job request.
Aug 29, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 error message 5b00
  1. On the operator panel, press and hold the button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the button again.
Service Reset:
  1. On the operator panel, press and hold the button for one second to power off the printer. (The display will go blank.)
  3. Press the button repeatedly five times.
  5. Press the button to power the printer back on.
    • This procedure will not resolve a physical hardware issue.
    • This procedure will not resolve all service errors or LCD related anomalies.
Aug 27, 2011 | Canon PIXMA MX310 All-In-One Printer
I have a Canon PIXMA MP 620 -I replaced the whole set of ink, then I turn it on it says "6A80 printer error" I turn on & off but problem still persist. I hope you can help .
  1. On the operator panel, press the button. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON button does not shut off the printer.
    Note: It may be necessary to unplug the power cord and retry if the above steps do not clear the error.
Mar 28, 2011 | Office Equipment & Supplies
How to resetter error p07 for printer canon mp258
Mar 01, 2011 | Office Equipment & Supplies
On my mp 460 ,after a refill, doesn't recognize the cartriges.Any help for reset?thanks.
Hi there you can try this it may help.
How to correct, fix: Reseat ink cartridge for Printer MP460) Issue:
ERROR LED: E, 1, 4
How to correct, fix: Press ON/OFF switch to reset the multifunction device Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.) Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer. Wait approximately ten seconds and then press the <ON/OFF> button again. Wait until the device has completed its cycling process before submitting another job request.
Turn the machine off, and remove the power cord from the electrical outlet.
Wait approximately ten minutes then plug in the power cord and turn the machine on. If the problem is not resolved, the machine may require service.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 16, 2010 | Canon PIXMA MP460 All-In-One InkJet...
C4280 wont turn on
Hi there
Not necessary is a bad cord first changes the fuse in the plug.
If that not work then it mat be the power supply transformer, or your switch on the printer.
All the best Pineworks
Feb 09, 2010 | HP Officejet 5610 All-In-One InkJet...
How to install a new catridge
Instructions
  1. Prior to replacing or disposing of your defective unit, follow these instructions to ensure the right accessories are removed. Turn the printer off, and then unplug the power cord. Wait for the printer to cool and keep the following accessories: Accessory Graphic a) Print cartridge
    CAUTION: To prevent damage, do not expose the toner cartridge to light. Cover the toner cartridge, if is necessary. c01142622.jpg b) Power cord c01142623.jpg c) USB cord c00601271.jpg d) User Manual and CD c00601269.jpg e) Input tray cover c01142624.jpg
  2. Transfer the accessories mentioned above from your defective unit to the replacement product.
  3. Apply power to the replacement product and test all the product functions.
  4. For additional support information for your HP product, please visit www.hp.com/support .
Oct 18, 2009 | HP LaserJet 1018 Printer
Computers & Internet Logo
David Payne
David Payne
