Question about Dryers
Burner turns off too soon. Clothes don't dry.
I have a Maytag gas dryer and the clothes don't dry. I checked the electronic ignition and it glows red hot, ignites the gas burner but the burner turns itself off after about 20 to 30 seconds and doesn't restart even though the clothes are still wet.
What's the problem? If it is a faulty thermostat or temperature controller, how do I detemine which one it is?
  • 770 Answers
Most likely you have a clogged vent system that is going to the outside.try this remove the flex venting from the back of the unit and then start up the unit see if it still does it if not you wil need to clean out your venting if it still does it your cycle stat willl need to be replaced
Posted on Feb 20, 2008
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
Dryer is not drying i have to go through four or five cycles. you can see the red light going on and off in the back
By 'red light', do you mean the glow of the heater element or gas burner? Is this a dryer with an electronic control panel, or knobs?
This is probably the 'cycling' or 'high limit' thermostat going bad (or a sensor if it's an electronically controlled dryer). When this thermostat goes bad, it turns the heating element off too soon (because of internal physical wear) and the dryer runs at far too low of a temperature to efficiently dry clothes.
The thermostat is fairly cheap and easy to fix.
Go to repairclinic.com to look up your part. They also have how-to videos for some dryers.
Mar 01, 2011 | Dryers
Dryer blows cool, not hot, air
Clean the burner exhaust and intake vents of dust and lint. Make sure the gas is turned on to the machine. Watch the burner while trying to dry clothes--the igniter should turn red, then the main valve should open to start the burner. If the plate turns red, but no fire, the control valve assembly may need to be replaced. Is the unit under warranty? If so, you may need to take advantage. Hope this helps!
Dec 24, 2009 | LG DLG5988 Gas Dryer
Kenmore dryer 110 708 12990 Igniter glows, but
replace the two coils on the gas valve use the maytag coil kit much cheaper and same part
Jun 29, 2009 | Dryers
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Atlantis MDG8400AWW Dryer Runs Cool
I had a similar problem years back. It was the ignitor. The ignitor is a ceramic like piece that heats up (glows red) that ignites the gas. Typically when that goes, you will see some white residue build up where it cracked, thus breaking the electrical connection. This thing works like a heating element on an electric stove, but rougher looking.
The part was about $30 at my local parts store. I bought an extra one just in case so I have it on hand. I installed it with common tools.
You can check it to see if you lost connection by using a volt meter.
Good luck.
Dec 29, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
Problem With Maytag Dryer(PYE2300AYW)
you check the igninter on the burner . does it glow red when started then go off . or nothing at all . it has to glow red for any gas to come out to start the heat to dry your clothes .???
Jul 31, 2008 | Dryers
Dryers Logo
103 people viewed this question
Top Dryers Experts
Marvin
Marvin
