Question about Hoover Nextra HNL 3166 Z Front Load Washer
My hoover hnl 7166 wont finish any cycle just washes for a bit then stops and the light comes on for door locked so cant get washing out. i have to put it on a spin then can open the door .
ngfam1
  • 639 Answers
SOURCE: hoover optima hnl 7166
I'm Neil, Glad to be of assistance for you!
Sounds like you need service.
Try :
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a solution solved rating in this site
Thank You
Neil
Posted on Aug 24, 2008
  • 417 Answers
SOURCE: Hoover Washing M/C Door Jammed
The interlock is stuck. You might need to get behind the casing to release it, you can do this by removing the top and reach down to the linkage just give it a pull and it should unlock. Remember to disconnect the machine from the electricity supply first.
Please remember to rate this article.
Posted on Nov 03, 2008
  • 3 Answers
SOURCE: my hoover washing machine wont spin and is full of
It's a safety feature that doesn't allow the machine to spin when there's still water in the tub. The drain pump has probably failed and you would need to replace it (there are some good places online where you can buy appliances spare parts). Try to set your machine on a 'Drain' cycle and see if the pump works.
Posted on Nov 05, 2009
  • 353 Answers
SOURCE: Hover washing machine model HNL 7166. The bright
could be a sign the bearing seal has gone u need to replace the bearings
Posted on Jun 29, 2010
Testimonial: "Thank you for the information. I will look into this and see if it helps.."
  • 6277 Answers
SOURCE: hoover model hnl 7166 door remains locked at end
Many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 27, 2011
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
The machine will not spin,it does the wash cycle then stops at the spin,also wont work when its set to spin only
This sounds like a safety issue. The door switch will not let the drum spin at high speeds if the door is not secure. Check the door first to make sure there is nothing obstructing the door. If the door is ok then you will need to most likely replace the door switch. Hope this helps. Good luck.
Sep 05, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
My hoover washing machine wont spin and is full of water. model number is hnl 9146-z
Nov 02, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Flashing stop light
have you tryed unplugging it for 5 minutes to see if it resets itself?let me know-mike
Oct 31, 2008 | Hoover Washing Machines
Hoover optima hnl 7166
Try :
A&E Factory Service
1-800-905-9505
Good work
Thank You
Neil
Aug 24, 2008 | Hoover Washing Machines
Not got user manual for hoover hnl7166
Click on Hoover (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Jan 13, 2008 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover Nextra HNL 3166 Z Front Load Washer Logo
168 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
