Question about Dishwashers
My servis dishwasher keeps overflowing, the water is draining ok. do you think it could be the seloniod thats near the inlet pipe. it is model num 02-800271
  • 51 Answers
No, unless the machine is filling up over night, it wouldnt be the solonoid valve. chech for a blockage in the tube going to the pressure switch. take it of the pressure switch and blow out any blockage. this should solve your problem.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Posted on Feb 03, 2010
LG dishwasher, it pumps out ok on start up in any program, but gives an OE error
The water inlet valve is an electrically-controlled valve that opens to allow water to enter the dishwasher. Depending on the model, the valve stays open either for a set length of time or until the dishwasher has enough water. However, if the water inlet valve doesn't shut off after the dishwasher has enough water, the dishwasher will overflow. If water drips into the dishwasher when the door is open, or if water collects at the bottom of the dishwasher while it is not use, you may need to replace the water inlet valve.
Feb 12, 2016 | LG Dishwashers
Water keeps coming into the machine, looking for electric valves.
The solenoid valve is under the machine. It will be a block of metal installed with fittings into the water pipe and it has a plastic cylinder attached to it. The cylinder will have two wire terminals on the end opposite the valve block and is typically about 3/4" dia. x 1 1/2" long.
Jul 04, 2011 | Dishwashers
Water vALVE DOES NOT QUITE SHUT OFF. AFTER WASH COMPLETED, water leaks slowly into tub and overflows onto floor. iT IS TYPE 1353-1. wHAT IS PART NUMBER FOR WATER VALVE? pRICE AND WHERE i CAN GET ONE? tHank...
If you can supply the Product number or model number I would be able to help.It would not be a major expense for a new inlet valve.Check if the drain pipe from the dishwasher if going into a pipe outlet in wall that it is not too far down into pipe as this could cause it to syphon back into unit.Also if drain goes to a sink outlet make sure the drain hose is above any other outlets,you could tie hose up into a "U" shape above outlet this will stop waste from sink getting into Dishwasher.
Hope this helps.
Jun 07, 2010 | Dishwashers
New Whirlpool Dishwasher filler overflows.
New Whirlpool Dishwashers will NOT accept the same "volume" of water that was desired by the same products of 25 years ago. Therefore the old 3/8" ID copper supply is too large and will overflow the tub filler/aireator (out the air vent holes). I just installed a new dishwasher supply kit consisting of a new 3/8" OD stainless braded hose with an ID of about 1/4". This delivers less volume than that recommended (in the installation manual) and therfore does restrict the flow a bit. However, the flowrate is adequate and the new dishwasher now works perfectly with no water overflow on the floor . . .
Dec 26, 2009 | Dishwashers
I get water all over my counter when dishwasher gets rid of water. There is a feature on my sink of which water comes out. This just started...
Since this just started, I would suggest cleaning out the p-trap under your sink. If your sink drains sluggishly without a pump, then your dishwasher will overflow your drain pipes with its pump.
Also, try facing any air gap opening into the sink.
If the pipes are clear, you may need to add a length of pipe between the air gap on the sink and the 'y' connector that the drain lines are connected to. This will help keep any splashing water from 'climbing' out of the sink-top vent. Good luck
Dec 04, 2009 | Dishwashers
ASKO D3432XLB keeps running, draining but hasn't gone into the wash cycle yet. won't turn off even when I turn the power button off.
Water on lower bottom. Leakage or blocked drain pipe. Is common error. The machine will act like this so that water wont get on your kitchen floor, in case of fault on inlet valve. The machine indicates overflow. Dry out water on bottom, and than the machine will work normaly. But check for leakage. Just in case.
Jul 18, 2009 | Asko Dishwashers
KitchenAid Dishwasher fill up with water after use
Hi BB,
There are only 2 places the DW can get water from. One is the drain line and the other is the supply line. We need to eliminate one to diagnose the problem, OK?
The first picture is a drain hose gone wrong...
Inspect your drain hose. If it looks like the pic above, you gotta fix that. Even IF that's not the problem right now... it will be in the future (and MAY be contributing to the problem now). You'll need to loosen the clamp, remove the drain hose from its' fitting, pull as much slack as you can get from the DW and then make a "loop" in it before reconnecting it. Like this...
The DW drain loop should be as high as the highest part of the sink...
I know that you have done a lot of experimenting in an attempt to figure this out. Just make sure that the drain hose is installed properly to eliminate it as the cause of the flood issue.
After you've made sure about the drain hose, leave the DW alone overnight. If you see water in the tub the next morning, you definitely have a failed valve on your DW. Since it's new (less than a year?) the valve is under warranty and will be replaced at no charge.
Hope this helps. If it's out of warranty let me know and I'll do the part look up for you and provide detailed replacement instructions, OK?
SG
Apr 14, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher occasionally won't fill...what am i doing right/wrong?
make sure there is no water at allin the base os the unit so remove panel again and check with flashlight. then hit the drain and cancel button.that should do it.
Jan 18, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
IE problem
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Dec 23, 2008 | LG LDF8812 Stainless Steel Built-in...
Lg dishwasher LD-12aw2
IE is a INLET ERROR. Possible causes ¥ The Water Tap not opened.
¥ The Inlet Hose is kinked.
¥ The Filter of inlet valve clogged by
impure water.
¥ The Inlet Water Valve is normal ?
¥ The water pressure is very low.
( below 0.3 kgf/ )
Possible solutions ¥ Open the Water Tap.
¥ Repair the Inlet Hose.
¥ a) Close the Water Tap.
b) Unscrew the Inlet Hose (Inlet
Valve side)
c) Clean the Filter of Inlet Valve.
¥ Replace or repair the Inlet Valve.
Feb 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
102 people viewed this question
Top Dishwashers Experts
Owen Barnes
