Question about Sony Cyber-shot DSC-W110 Digital Camera
Camera not switching on
When i switch on my camera it switches off automatically n it says turn power off n then on again. i hav tried it several times but same msg coming can u plz help me.it is sony cyber shot dsc w110
    Problem Solver:
  • 7 Answers
I believe there is a lens error, usually that message appears when the lens are stuck or not working.
Turn the camera ON by pressing the "play" button (to see images only) and if the camera turns ON with no problem, then the problem lies on the lens.
you can send the camera for repair or buy a new lens set from ebay, they go for around 30 dollars, but you have to be familiarized with cameras and very careful in order to install the new lens.
hope this helps.
Posted on Mar 22, 2010
Fixing a seized AF motor
One theory on this is that the camera's software or settings may somehow be corrupted, so you should go through the process of resetting the camera to its original factory settings. If that does not clear up the problem, try another AF lens and conform whether the problem is the lens or the camera body. If the camera is not focusing another lens, then you may need to clean the contacts or look for some sort of damage.
If it turns out that it is the lens, the best solution is to send it to Tamron for service and see what they can do about it.
If you cannot send it to Tamron, you ought to see whether it is something as simple as some sort of internal dust or dirt collection blocking the mechanical switches and functions of the lens.
Start with making sure that you have a fully charged battery for the camera or AC power adapter for the camera. You do not want any of the problems with the camera to be related to having too little voltage available.
Make sure that the camera's power switch is switched off. You do not need to have the battery or adapter connected just yet.
Next, with the lens off of the camera, switch back and forth several times, firmly, between AF and MF and switch the vibration compensation off and on a few times. Of course, do not drop the lens. Also, unless you need the zoom ring locked, you may want to make sure that the zoom ring lock is fully off. While you are doing this, or after switching back and forth, check the electrical contacts on the lens and the camera body. If anything looks even a little less than shiny, clean the contacts.
With the camera's power still switched off, put the lens back on the camera.
Either put the battery in the camera or connect the AC adapter.
Set the lens to AF with vibration compensation off.
Switch the camera's power on.
Try getting the camera to automatically focus on something. If it works, turn the camera's power off, then switch vibration compensation on, then turn the camera's power on and try again. It may be fixed, at this point, which means that you can ignore the rest. Otherwise:
Turn the camera's power off again and switch to manual focus. Turn the camera's power back on and rotate the lens's focus ring (gently) all of the way through the focal range two or three times. Try taking one or two pictures, just to be sure that everything is working in manual. Turn the camera's power off and switch the vibration compensation, then turn the camera's power back on. Gently rotate the focus ring all of the way through the focal range two or three time, and then take two or three pictures to verify that everything is still working in manual.
After that, turn the camera's power off and switch back to AF with vibration compensation off. Turn the camera's power back on. Try to get the camera to automatically focus on something. If it works, then turn the camera's power off and switch vibration compensation back on again. The turn the camera's power on and try to get it to automatically focus on something.
If all of this works, than you should be okay with it as it is. You may still want to send the lens in to Tamron to get it serviced, in case the problem was some sort of lint or dirt getting caught up in the gears or servo that moves the lens through the focal range.
If it does not work, you could try to force the lens to re-engage the autofocus servo. It will probably void your warranty, if you still have one, so you are better off send it in to Tamron for service, first, before trying it. Also, as the manual and common sense would indicate, if you try to force the lens to adjust its focus ring while it is switched to AF, you could easily break the mechanism in the lens.
With that being said, some people claim that they got their lenses to return to proper autofocus by leaving the lens switched to AF and trying to rotate the focus ring manually. One person says not to "force" it, his just took a "firm push". I have not tried this, so I do not have advice on how much force may work or how much will damage the plastic bearings, gears and teeth inside the lens.
May 04, 2014 | Nikon D60 Digital Camera
Wont turn on
If you think this has to do with the battery power, you also should check the contacts in the battery compartment. If the are not shiny, you can try to clean them with a dry cloth or a cotton swap. Don't use sharp tools in or close by a camera.
Make sure the battery is inserted correct and the battery cover should be locked correct.
If the camera was not used for a long time, perhaps some contacts are oxidised. Those contacts you can switch, try to switch them several times. Open and close the battery door several times. Press the on of button several times. Put the battery in and remove it several times. And hope the contacts will work again.
Mar 23, 2014 | Kodak EasyShare M883 Digital Camera
System boots several times.
it's PC? you try change for the power supply
Dec 15, 2009 | Intel Motherboard
It turn the power on and on again and nothing happens
This is a common problem for all Sony Cybershot digital cameras. It is saying the error "Access" because whenever you turn it on, the camera finds it hard to retract and open out the lens. Chances are, there is some sand or maybe dust or dirt of These are few things you can do.
You can blow a compressed air on the camera's lens to try to take off the dirt or granule of sand stuck within the lens. Also, you can try to hold the camera from your right hand with the lens facing the ground and hit the camera's base on your left palm. Do this several times.
Let me know if this helped you. Goodluck!
Sep 16, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Not able to click pictures
sounds like it's time for a new camera.
Mar 24, 2009 | Cameras
Camera refuses to switch on
lens mechanism not working properly so only it gives error, so camera says turn the power on. try to tap the lens while power up......
Aug 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Can't switch on
lens of camera got stuck. tapp the camera while turning power on button.
May 27, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Need help FAST!! Panasonic NV
remove battery for a while .put it again and try .if not works...remove battery agin then put it again by keeping power switch off. eject and remove cassette .take several eject operations. now try again.
Nov 04, 2007 | Panasonic NV-GS50 Mini DV Digital...
Always power ON
Switch is broken Check out Sony customer support If camera is a year or more old - buy new camera I suspect
Aug 07, 2007 | Sony Cyber-Shot DSC-P100 Digital Camera
When i click to take a shot,the camera switches off automatically
it could be that the battery is low that some times happens to me when the battery is low
Feb 21, 2007 | Fuji FinePix A500 Digital Camera
Sony Cyber-shot DSC-W110 Digital Camera Logo
416 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
