Brother DCP 7020 error 'back cover open close
Brother DCP 7020 printer error 'back cover open close cover' ... it is closed ... tried everthing
  • Open the back cover.
  • Pull the flap down that hides the orange roller on the fuser (be careful: it's hot)
  • Locate the inner flap that runs from the centre to the right hand side.
  • 3/4 along the right hand side, there is a tiny little perpendicular appendage on this bar that should sit in a slot. Locate it properly and the error will go away. You can go that by slightly bending the slot if fits into on the inner flap. The appendage can get jossled out of the slot when one is removing jambed paper.
Posted on Mar 11, 2010
  • 3 more comments
  • datravis Jan 03, 2011
    Daniel,
    You should go and train the Brother technicians. They wanted me to take my printer to a repair shop. Your solution worked like a champ. Thanks.
  • lynnmalonza Jun 06, 2011
    Daniel you have been most helpful i have been going crazy for the last 3 days trying to figure out the problem ..... thanks i have solved my problem
  • Rocky Feb 02, 2012
    Solution by danielwdc worked perfect. There is a long appendage and a short appendage actually and they are connected to the same horizontal member,the horizontal member or bar located between posts on the inner flap, any movement on the long arm creates an equal angular movement on the short arm. The short arm had popped out and I relocated it in its slot, the slot in turn being in the inner flap.
  • Denis Shumaker Nov 18, 2012
    Walla!!! Thanks Dan. After a half day working on this problem and working with customer service I was advised that the printer needed to be taken to a customer service center. I decided enough was enough and purchased a new printer this morning. After reading this post I was able to solve the problem in about a minute. I guess I will try to repackage the new machine and make a return. Thanks again.
  • Spiker
    Spiker Aug 16, 2017
    Perfect!!! Thank you so much! This printer was actually put out to be recycled because of that little do-flicky you just helped me fix.
Thank you Daniel - it worked for me!
I just spoke with a Brother Customer Service Rep. and he did not mention this potential fix. He ended up recommending a local service center, but suggested that it might be less expensive to purchase a new pinter instead.
Note to others: the tiny perpendicular appendage is on the (this thin black plastic)flap that you pull down to expose the orange roller. There was a separate black piece on the flap that was slightly bent & "jossled out of the slot" as Daniel mentions.
I hope this works for you as Daniel's advice above just saved me about $170 on a new printer - Thank you!
Posted on Apr 28, 2010
    Ha! I should have checked this site earlier. After spending most of a day trying to figure out how to solve the door open issue and working with Customer Service who suggested that I would need to take the printer to the service center I decided to get a new machine. Found the post a few minutes ago and walla!!! I think I will repackage the machine and try to return it. Thanks Dan.
Back cover open message but cover is closed
Sounds like the sensor has been damaged try turning off at wall and re starting if it continues you'll have to go into maintenance mode and reset
Apr 09, 2014 | Brother DCP-7020 All-In-One Laser Printer
BACK COVER OPEN
The back cover sensor is detecting the back door is opened. Open and close the back door firmly to fix this message.
Aug 22, 2012 | Brother DCP-7020 All-In-One Laser Printer
Dcp 7020 "Back Cover Open" lights up even after it
Try doing a power reset.
Turn off the printer/Unplug it for a few minutes/Plug it back in/Turn it back on.
Jan 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
My Brother DCP 7020 won't stop flashing close back door
There's a micro-switch that "trips" when the door is opened/closed. It's not sending a "closed" signal to the printer. Clean the switch, with a blast of compressed air. Check that a small "finger" is going-in to the slot, to "trip" the sensor, as the door is closing.
May 07, 2010 | Brother DCP-7020 All-In-One Laser Printer
The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Help
one ot the doors, most likely the one on the right is not closed, there is a sensor switch there it is not being activated, make sure all levers are in he correct positions so the doors can close evenly.
Jul 23, 2008 | Brother DCP 7010 Multifunction Laser...
Brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
Dec 20, 2007 | Brother DCP-7020 All-In-One Laser Printer
The printer jammed and now will not restart
unit was turned off while it had this error, follow these instructions:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=dcp7020_us&Cat=4
Dec 03, 2007 | Brother DCP-7020 All-In-One Laser Printer
Back cover error on LCD won't go away
This is most likely caused by the back cover switch. It is either broken or the lever on the back cover is broken off.
Sep 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
2,039 people viewed this question
jasbo
jasbo
