Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
CPU fan I have finished assembling a desktop computer and briefly powered up to check the cooling fans. All fans worked fine except the CPU fan which gave a little spurt and then stopped. After about 3 seconds it again moved briefly a number of times but at no time did it start up and run normally. After 9-10 seconds I killed the power to prevent the processor overheating. I checked the connection of the fan to the CPU Fan connector on the motherboard and it appears to be fine. Can anyone suggest a solution? The processsor is a Pentium 4 631 3.0 GHz and the motherboard is a Gigabyte Model 965P - DSA
  • mckjohnm Feb 24, 2008
    Yes, all other fans and lights were working. I have since discovered that on this motherboard, the CPU fan does not spin until the CPU has reached a preset temperature and then the speed varies with the CPU temp. It is possible to check that the fan is working by plugging it into either the PWR FAN or SYS FAN sockets.
    Brigadier General:
  • 3,614 Answers
When you say power is going to the mobo, are
other fans and lights turning on? You also may have forgotten to plug in
the large ATX power cord from the PSU, or the smaller 4-pin rectangular 12V
power cord. Is the correct local voltage setting for your PSU selected (110
or 220)?
Posted on Feb 19, 2008
Cooling fan for a presario cq5621wm dont work
Central Processing Unit chips have a tendency to overheat when used for long periods of time. This is why virtually all desktop processors come installed with cooling systems that include a cooling fan. However, cooling fans are not invincible. They can burn out if they are not cleaned often and properly. To clean the fan in a Compaq Presario desktop, there is some light disassembling involved to gain access to your computer's CPU fan.
Turn off your Presario desktop and disconnect the power cord from its socket. Wait 10 to 15 minutes before you begin disassembling your computer. Attach an electro-static discharge wrist strap to your wrist and attach the wire clip to the outer casing of the desktop. This helps prevent damage to your computer caused by static electricity. Rotate the desktop so the back panel is facing you. Place the desktop on its left side. Remove the two Phillips-head thumb screws from the right side of the computer's back panel. Grasp the molded grip on the side access panel and slide the panel away from the desktop. This will reveal the interior components of your computer. Locate the cooling fan assembly attached to the back panel of your computer. Grasp the power cable extending from the fan, follow the cable to its connector on the motherboard and disconnect it from the motherboard. Locate the locking tabs on either side of the air duct assembly. Insert a small flat-head screwdriver into the notches on each tab and disengage each tab. Remove the air duct once the air duct assembly comes loose. Repeat this procedure in reverse to install the new cooling fan assembly.
This might not be your specific desktop computer it might give some insight into repair or removal
How to Properly Clean Your Desktop Cooling System & Fan http://www.youtube.com/watch?v=GgOaIJ82gFM&playnext=1&list=PLu_9NJ3Eiy2XGhZxa5wlnkxdPbrJG5hjw&feature=results_main
Feb 22, 2013 | Compaq Computers & Internet
Fan not working
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Feb 18, 2013 | Acer Aspire AX3960U4102 PTSFF02027 Desktop...
Dell inspiron will not stay powered on
You could have an overheating problemWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 29, 2012 | Computers & Internet
Fans are not working in desktop
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 07, 2012 | HEWLETT-PACKARD Hewlett Packard Pavilion...
My desktop computer power on fine, however it will shutdown while loading the windows xp, what is the possible caused of this fault??? thanks for your help, Jane...
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Apr 26, 2011 | Computers & Internet
Dell desktop suddenly making surging noises from the tower .It doesn't feel hot.8 months old.Surging lasts a few seconds
this sounds like the hard drives working extras hard. can be caused by malware and viruses as well as anti virus software and realtime protection. the computer might also have a bad bearing in one of the computers fans when you shutdown and power backup listen to the back by the power supply. see if its coming from their or from the cpu cooler. replace as necessary.
Feb 18, 2010 | Dell Studio 1537 Laptop Computer PC...
After about minutes of running the computer just
this sounds like an overheating problem.
First thing i would check would be the CPU fan. you will have to remove the side access panel on the case to check this.
If the CPU cooling fan is covered in dust, and the spaces between the cooling fins on the heatsink (right underneath the CPU fan) are clogged with dust. it would cause this problem.
there is also a fan at the back of the computer inside the power supply that can get clogged with dust, and may possibly overheating and shutting off. if you look in the back of your computer and find where the power cord plugs in, the power supply cooling fan is right around there as well.
If there is a good buildup of dust, it would be best to have your computer professionally cleaned. Using a vaccum cleaner is not a good idea unless you are familiar with procedures of working with static sensitive components.
hope this helps
Feb 15, 2010 | Gateway LX6810-01 PC Desktop
Shutsdown without notice could it be the fan mor fans not working
This is typical of a overheating (thermal shut down) CPU problem.
When the CPU overheats and shuts down, it won't bootup again until the CPU cools down. If this is not fixed then the CPU will fail.
This problem is caused by either a faulty fan or the fan and heat assembly is clogged with dust.
Check the fan to see if it spins freely, replace if faulty and clean the dust off the fan and heatsink assembly.
Also apply fresh thermal paste to the heatsink/CPU.
Sep 27, 2009 | Acer Computers & Internet
E7400 CPU cooling fan
You need to Plug the Fan to the motherboard. I uploaded an image. http://img140.imageshack.us/i/overviewl.jpg/ Hope this helps
Jul 12, 2009 | Intel Computers & Internet
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
115 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
