Question about Bronica ETR-Si Medium Format Camera
Using the Bronica E42 extension tube on the ETRSi, what problems are likely to emerge when using the E42?
2 Suggested Answers
SOURCE: Wanting to purchase Focus screen for Zenza Bronica
Keep an eye on ebay as they appear on there occasionally. However, you can't always get exactly what you want and it took me a while before I could find a split image version. All you have to do then is win it!
Posted on Oct 06, 2010
Non availability of LR 44X4 battery for etrsi
They are still easily available online.
Here's one supplier that I regularly use. Even if the supplier is no use to you, you'll see the many other model numbers for the same battery.
Aug 16, 2011 | Bronica SQ-Ai Medium Format Camera
Inherited bronica etrsi camera, removed lens and now cant get it back on, dont have manual, please can you advise. thanks barb.
A. To attach the lens to the main body, align the red dots on the lens
and the main body and then insert the lens fully into its mount.
Rotate in the counter-clockwise direction until it stops, with an audible
click, which will indicate that it is securely locked.
http://www.tamron.com/assets/pdfs/ETRS.pdf
Aug 20, 2010 | Bronica Cameras
May 06, 2010 | Bronica ETR-Si Medium Format Camera
Which 120 backs & lenses for my ETRSi do I buy?
All ETR backs work with all ETR cameras except the ETR-C, which only uses the inserts. The early backs have a single latch and a winding key. The middle ones have double latches and a winding thumb wheel. The Ei backs have double latches and a winding crank like a 35mm has. The Ei backs also have a locking dark slide to prevent accidental film exposure wnen the back is off the camera. All inserts work with all the back frames. I the used market you will find them in any combination (frame, insert & darkslide).
I am aware of three series of lenses: MC, EII and PE. They all work fine with any body.
Jun 14, 2009 | Bronica ETR-Si Medium Format Camera
Bronica AE II E Finder Owners Manual
Since I never use a TTL flash with my Bronica's, I'll give you my suggestion for a great solution. Using your TTL Metz flash, (make sure you've connected the TTL cord for Bronica ETRsi) take 8 shots at different apertures on A (Automatic), then take 8 shots at different apertures on M (Manual). I realize this will waste one 120 roll of film, but one negative will stand out as your perfect exposure. Yes, whenever you reduce the ISO in half, your basically overexposing the film by one f/stop. Just remember that this overexposes everything your shooting from foreground to background. With flash, this may cause your highlights to wash out, but any good lab could print for the highlights and make the background go darker. I used to shoot Vericolor at ISO 125 instead of it's rated ISO of 160.
Fotobean
Jan 21, 2009 | Bronica ETR-Si Medium Format Camera
Like to fit my bronica fisheye p e into nikon f 5 camera
The lens you're refering to is the Fisheye-Zenzanon-PE 30mm, yes? As far as I'm aware no Bronica ETR > Nikon F adaptor has ever been made, and if one was to be it would be rather cumbersome.
You're probably better off selling it and using a Nikon Fisheye-Nikkor 16mm 1:2.8 in its place.
Oct 25, 2008 | Bronica PS Zenzanon (1.4x) (bq1275) Lens...
Battery problem with ETRS
On the AEII Finder, there are four contacts on each side of the finder and also the ETRsi body. Clean the contacts on both sides and see if this helps. Another test to see if it's getting voltage from the battery is on the body contacts(on top of the body where the viewfinder slides on). Take a multimeter (any multimeter) and touch the ground (black) probe to any place on the body except the contacts and touch the positive (red) probe to each contact on the body and see if there is battery voltage anywhere. If you get voltage that's close to the 3 volts from the battery, then it's good. If not, there is a circuit break between battery & body and this requires a repair shop because the camera would need to be stripped down to locate the problem. Be aware that the body battery supplies voltage to the Seiko Electronic shutter and the AEII prism. Hope this helps.
Jul 17, 2008 | Bronica ETR-Si Medium Format Camera
Battery
dear choirboy,
the accepted battery models for the bronica etr-si are 4LR44 and/or 4SR44.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 09, 2008 | Bronica ETR-Si Medium Format Camera
120 film backs
skip frames or overlapping(multiple)exposure is caused by the film advancing mechanism. if you treasure your camera y back. send it for service.
pc-cook
Oct 10, 2007 | Bronica ETR-Si Medium Format Camera
Bronica ETR-Si Medium Format Camera Logo
164 people viewed this question
Top Bronica Photography Experts
Tony
Tony Parsons
Tony Parsons
Are you a Bronica Photography Expert? Answer questions, earn points and help others
