Question about Acer AL1912 19" LCD Monitor
Hi there,my acer al1912 monitor lights up briefly after i turn it ln and then turn black what could this be? Pieter
  • 11,361 Answers
It could be the problem in the power supply because of bad caps, or bad inverter circuits, or worst will be bad lamps. Look for bad caps first and report back what you see so we can guide you further, see example of failed monitors due to bad caps and lamps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 03, 2010
I use Acer AL1912 19inch (black) monitor. It is working properly for weeks. but sometime it suddenly go dark during work, although its light remains green. Now the only solution is to unplug its power...
Sounds like the monitor is dying, if it starts to die more and more often you will likely have to replace your monitor before it goes completely out. There are not many ways for a user to repair a monitor, unless the problem is with the computer, which you could test by connecting a different monitor to the computer for a while (if available). Hope this helps!
Mar 15, 2011 | Acer AL1912 19" LCD Monitor
Hi I am running Triple Acer AL1912 LCD monitors on a Mo-View triple monitor stand. I have run these for a couple years without fail. PC is running 2 video cards a NVIDIA GeForce FX 5600 and a NIVIDIA...
Most comon problem with monitors are bad caps in the power supply, any good reapair shop should be able to fix them easily, see pictures of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
At least you will have some info so you will not get ripped off by repair shops.
Mar 01, 2010 | Acer AL1912 19" LCD Monitor
How can I connect my Fujitsu Siemens key board with my Acer AL1912 monitor? There is a connect button on the key board, but where is the connect button on the Acer?
Is it a wireless keyboard? If that is the case, then you should have a receiver unit attached to the PC, usually to a USB port. The ACER is justt a monitor, here is the user manual: http://www.retrevo.com/support/Acer-AL1912-Monitors-manual/id/719ag115/t/2/
Jan 20, 2010 | Acer AL1912 19" LCD Monitor
Acer AL1912 19" LCD Monitor goes black after power up
With the screen connected to the pc (which is running and putting out a signal) hold a bright light to the front of the lcd - a led flashlight works well. Do you see an image? If so then circuitry driving the inverter backlights may be at fault. I had this happen with a Dell Flat Screen, and found one of a pair of transistors which drives the backlight had developed a short.
Aug 01, 2009 | Acer AL1912 19" LCD Monitor
I have a acer al1912 faulty
It might be worth a try but the two different sizes could have differing resolutions and if they do, the boards are not likely interchangeable.
Jan 29, 2009 | Acer AL1912 19" LCD Monitor
Acer AL1912 Monitor - Screen to black and light on yellow
I found some solutions other posted that didn't come up the first time I looked. I did a reboot and I'm good to go!
Dec 07, 2008 | Acer Computers & Internet
No display
Your minitors power supply is now damaged, probably from the power outage. I t will need to be repaired or replaced. Check the cost and benifits of both options and make a discision.
NSSMS
Jul 30, 2008 | Acer AL1912 19" LCD Monitor
Won't Turn On
Hi
If the green light doesnt turn on, check if the wall outlet is workign properly.
Also pls check with another moitor power cable.
If the above steps dont work, then the monitor needs to be serviced.
Jan 14, 2008 | Acer AL1912 19" LCD Monitor
Acer al1912 19" black
See if the problem happends in safe mode ( while booting hit F8 and aboot menu wil come up) if everything works fine then your issue will be the driver or a resulition that the display does not support or a refresh rate. Frist try to change the Res to a lower one and common (1024X768 or 800X600) also change the refresh to somewhere 70 to 75 and reboot if this dosent fix the problem try updating your video driver in safe mode
Jan 09, 2008 | Acer AL1912 19" LCD Monitor
Acer AL1912 19" LCD Monitor Logo
137 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
