Question about Bosch Nexxt 500 Plus Dryer
How do you install a side exhaust vent for this unit?
  • 221 Answers
Hi, You have to order a side exhaust kit from the manufacturer. Part number: WTZ 1265. Phone number from the owners manual is 1-800-944-2904. If you don't have the manual, I found here: https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=thjozmkcdcso0pdmdb---oAK&UMOBID=thjozohcdcso0pdmdb---oAK
Pages referenced were 18 and 32, best of luck.
Posted on Feb 02, 2010
Need to know if I can convert it to outside vent
This unit has a three way exhaust capability on it. There is a plate on the back that you remove to set the blower housing to back, top or frontal exhaust. You take the plate off and then just lift the blower assy. up and then reset it back into position for the direction that you want. It may be missing the vent louver for outside exhaust if it wasn't left with the unit when it was installed.
Sep 17, 2013 | Sharp R-1850A Convection/Microwave Oven
I have a Haier Commercial Cool air conditioner, model CPRD12XC7, 12,000 BTU that has 2 hoses off the back and is made to be vented thru a window. I want to install it in a closet with no windows. Can I...
Mark, the two hoses serve different functions (Fresh Air Intake & Hot Air Exhaust). Therefore, they would have to remain separate. Also, Haier does not recommend extending the length of the hoses, to accommodate a specific change in installation. And yes, they can be vented through a wall to the outside. But, you would need to use something similar to a clothes dryer vent termination on the outside. Most exterior dryer vent terminations have insect screening and a flap door that opens when air from the dryer pushes it open. This would be fine for the exhaust hose, but not the Air Intake Hose. I guess if you could carefully remove the flap door. it could be used on the Air Intake hose. Also, keep in mind that the unit requires a minimum of one foot air space clearance off the back of the unit, for proper air circulation around the unit. If clothes will be hanging in this closet, that may present an air circulation issue.
Hope this helped you, please let me know. Thanks.
May 26, 2011 | Haier Heating & Cooling
Can this unit indoor vent be changed to vent outside?
Yes. There is an installation manual available for this model listed at managemylife.com. Just type in the model number under the "Manuals" link and the installation manual is available in .pdf (Adobe) format that you can download or print for FREE. Ductwork installation instructions for outside rear exhaust and outside top exhaust are listed. I hope this helps you.
Mar 01, 2010 | GE JVM1650 1000 Watts Microwave Oven
NuTone 8310 :fan motors keep burning up
I was not aware there was a fuse in the unit. This is a Nutone8310 side vent system correct?
Here is the installation sheets.
Its possible it is wired incorrectly. Follow the instructions given by nutone from the link.
Jan 01, 2010 | Broan-NuTone N-769RF Combination Light Fan...
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Dec 15, 2009 | Whirlpool GH8155XJ Microwave Oven
Exhaust fan doesn't work and blows air from top vent
Some microwaves have a adjustable fan. We have one that you can vent out the back, the back top or through the front top filters. The latter is what it sounds like you have. If you take the small back panel off and lift out the fan motor you'll see that you can place it in the direction you like.\\
KK
Jul 04, 2009 | Kenmore 60654 Microwave Oven
New furnace flame rollout
Have you checked the venting either on the side of the house or on the roof ? did you or the company who installed it go by the specs on how many elbows and length of the venting run ? It also sounds like you have some blockage somewhere, if your in a climate that has alot of snow or some type of freezing rain, your intake or exhaust could be plugged by ice or snow, if so, a quick solution for this is if you have a shop vac , take the tube and hook it up to the exhaust side of the vac, then place the vac tube into the 2" vent wrap a rag around that to make a better air seal, then turn the unit on, if ice is the problem it will blow it right out ! if this does not fix the problem, I would consult the company who installed it and have them come take a look, should be no charge if the system is new, hope this advise helped, please rate this and let us know how we did, thanks for your qquestion,
mr.grzz
Jan 25, 2009 | Goodman GDS80904BNA Open Flame Heater
Install a Thermador UCV36 cook'n'vent
Hi schmidt_rich,
I'm Harvey the Master Plumber.
Your question is: You took over as owner builder when your builder "took the $ and ran". You are installing kitchen cabs now and discovered the PVC vent pipe (which goes into the foundation and out the side of the house) is in the wrong place for the location of the downdraft unit and integral blower. The vent is actually under the electrical connection panel. You were told initially( 2 yrs ago when you bought the downdraft cook'n'vent) there could be no bends in the exhaust fan route or it would change the effectiveness. Does anyone know if it is ok to put a bend in the connection to the vent? Or do you need to redo your kitchen cabinets?
I can syphathise. I have had to deal with this same problem. I have found that one ell will not degrade the effectiveness enough to notice. If you need more then you may need to adjust cabinets.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Over Stop Microwave Vent Blower doesn't remove steam
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
The installation instructions are what you need.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 13, 2008 | Microwave Ovens
Bosch Nexxt 500 Plus Dryer Logo
367 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
