Question about Panasonic DP-C264 Copier
When printing on 170gsm thin card (fed in via the bypass tray on the side) this printer often has trouble sucking the sheets in. It will do a few, then when it doesn't manage to **** one in (it doesn't try very hard) it complains about misfed paper. None of which makes the printer impossible to use, just frustratingly slow on large print runs. Arrrgh! Anyone found a useful workaround for this?
  • Panasonic Expert
  • 1,326 Answers
If you are using the copier out of spec's alot. You may have to have the manual feed roller replaced. Just because it use to do it, it dose not mean it will alway's do it... Sorry, but have the manual feed area serviced.. Good Luck
Posted on Feb 03, 2010
Trying to print on clear pvc keeps acting like no card is there says card not fed , i put in non clear and prints just fine
Go to the printer driver setup screen and choose clear . The paper out sensor will then be bypassed and the printer will pick up the clear sheets.
Mar 12, 2016 | Office Equipment & Supplies
What is bad duplexer connection?
duplexer is the bit that turns the sheet of paper over to enable it to be printed on its other side. Its usually a tray that the sheet is fed into after its been printed on its 1st side, then out of again to effect the flip and print on the sheet's other side. Its probably a 'bolt-on' option to the printer and may not be seated quite right, so not all its connections are making good contact. Careful, though
as there are high voltages present inside the printer....switch it off and disconnect the mains lead before you go investigating the internals!
Regards
nicam49
Dec 22, 2010 | HP LaserJet 5000gn Printer
When printing in color, the color runs
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb), OHP transparencies, postcards*, letterheads,
colored paper, envelopes, label sheets, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray
Jul 13, 2010 | Samsung CLX-2160N All-In-One Printer
DOUBLE SIDED COPYING
First normaly copy first side, then take copied paper and set it in bypass tray, when you do thath, the copier ask you for paper size and type, choose correct sett. and confirm with OK.The side on wich you want to print must be face down in bypass tray.
May 11, 2010 | Canon iR 1600 Laser Photo Printer
MP Tray Paper Empty
"MP" tray is refering to the top fold down tray on the front of printer (bypass tray) You might load paper in the bypass and see what it does?
Aug 18, 2009 | Samsung CLP-610ND + Demo Laser Printer
Printing on an index card
something else you might try is taping the card to a full-size sheet of paper, so the printer can push it through with ALL the rollers at the same time. not all printers have a roller all the way across, so index cards get snagged by one side, and they'll walk to the opposite side while they're printing.
Jun 12, 2009 | Ricoh Office Equipment & Supplies
Dell 924 All-In-One printer
Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
• Letter*
• Legal
• B5
• A4
• A5
• 3x6
• 4x6
• L
• 2L
• 5x7
• Hagaki
• 10x15 cm
• 13x18 cm
25 greeting cards,
index cards,
postcards, or photo
cards
• The print side of the cards faces up.
• The cards are centered on the paper support, in between the left and right
paper guides.
• The paper guide rests against the left edge of the cards.
• You select Normal or Photo print quality.
25 sheets of photo
or glossy paper
• The glossy side of the paper faces up.
• The paper is centered on the paper support, in between the left and right
paper guides.
• The paper is loaded vertically against the right side of the paper support.
10 iron-on transfers • You follow the loading instructions on the packaging.
• The blank side of the transfer faces up.
• The transfer is centered on the paper support, in between the left and right
paper guides.
NOTE: For best results, iron-on transfers should be fed one sheet at a time.
50 transparencies • The rough side of the transparencies faces up.
• The transparencies are centered on the paper support, in between the left and
right paper guides.
NOTE: You can load a single transparency into the paper support without
removing plain paper.
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Bypass tray
you have to set the paper size in bypass tray. do you have a manual? go to system menu/counter button and scroll down
Mar 25, 2008 | Kyocera CS-2050 Black and White Copier
Repeated paper jam in fuser
Fuser's orange roller is not meant to be wrinkled, if this is then I would recommend you replace it (just slides out) pic below
b4eead5.jpg If printing on card, you need to feed via manual bypass and exit from the back, not on the top, aka the "face up tray." Tray pulls out from rear. Rear tray will only stack a few card sheets at once.
Setting on printer's control panel must be set to card/heavy paper type on manual bypass tray
Their may still be some card in fuser causing jams.
Please rate as FIxya or post back,
Cheers
S. :-)
Jan 01, 2008 | OKI C5200n Laser Printer
Trouble printing envelopes
Instead of Word 2000 use Corel Draw for printing invelope. Because there are too many options for placing your text at desired position.
Feb 06, 2007 | Canon imageRUNNER 4570 Copier
Panasonic DP-C264 Copier Logo
55 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
