Question about Philips 42PFP5332D 42 in. Plasma Television
No video phillips 42pfp5332d gives great sound but no picture.
  • stratocastic Jul 09, 2008
    Watching the TV normally, all of a sudden it does a click/pop sound and the picture goes off.. The sound keeps playing normally.
    I've already checked all of the fuses internally.. (4?)
    Which circuitboard will I need to replace and how do I get one?
    Thanks!
    Scholar:
  • 72 Answers
It could be SSB but also several other boards JIP, Y-Main, or Logic board If u wanna know how to check each one of these send me a comment if u want to ivest the time into this project.
Posted on May 02, 2008
  • 92 Answers
PROBABLY NEEDS SSB REPLACED BUT YOU WOULD HAVE TO DO SOME VOLTAGE TESTS TO BE SURE
Posted on Feb 22, 2008
Philips model: 42PFP5332D/37 The other day it clicked and the picture went out. The blue light comes on and it stays blue with no picture or sound
Your set need a thorough check-up. Contact the authorized service centre or an experienced service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 14, 2015 | Philips 42PFP5332D 42 in. Plasma...
I have sounds but no picture
If you have sound and no picture you blew a bulb around a $30 bulb plus labor to fix
Apr 25, 2012 | Philips 42PFP5332D 42 in. Plasma...
Phillips 42PFP53320 42" Plasma TV. No picture,
Hello jporter...
welcome here in fixya..
That problem is one of the common problems of plasma TV (have sounds but no picture)..As a expert of flat panel for more than 5 years I already encounter that kind of problem many times..
Actually that problem is caused of either X,Y or Z sustain board or even both 3 boards are faulty..Because some models when the one of those boards have short circuit or bad there are possibility that other sustain board are affected..But most the problem like yours is "Y-SUSTAIN" board..
I can't find your model online please double check it it either Phillips 42PFP5332D/37 or 42PFP5532D/05
And for specific and easy way to find replacement please try to look at the part # of that board (it is usually printed on the sticker attach to the board itself..
Hope it helps and please don't forget to rate my answer..
Have a nice day!!!
regards,
Chester.
Feb 04, 2012 | Philips Televison & Video
Phillips 42" LCD Mod#42PF722OA/37 picture is off
hi have you googled it or how to fix and put your problem then youtube should find video some where on there to help hope this helps good luck
Mar 04, 2018 | Philips 42PF9996 42 in. HD-Ready LCD...
How do you find the power board for the Plasma TV Phillip Model Number 42PFP5332D/37
Carefully remove the back of the TV. If you have a grounding strap, wear it. If not, always keep one hand on the TV and use the other hand when ''rooting around'' back there to prevent shock damage. The power supply will be large, and very heavy. Here is a link to what it could look like - this link is a list of all possible power supplies in your model along with photos. http://www.shopjimmy.com/catalogsearch/result/?q=42PFP5332D+power
Once you find the power supply, locate a part number on a sticker or the board itself and match that up to one of the power supplies from the link. Leave the power supply inside the TV until you have the replacement in your hot little hands, so you can remember how it went in etc.
Jul 08, 2011 | Philips 42PFP5332D 42 in. Plasma...
When I plug the TV in, it will click, no picture will happen, I can see green lights through the back of the TV flashing the same time the clicking happens. Phillips model number 42PFP5332D/37 serial...
You may have a problem with the power supply circuit which is a common issue with these types of TVs. Inspect the circuit for burnt parts, leaking or swollen capacitors and loose solders.
Nov 06, 2009 | Computers & Internet
My phillips 42 inch plasma tv just clicks when I
There is no lamp in a Plasma TV screen and no ballast.
Check the power supply capacitors.
Aug 19, 2017 | Philips 42PFP5332D 42 in. Plasma...
No sound on the hd setting on my lcd phillips hd tv
look in the owners manual about installing devices or components--- sounds like you have something hooked up wrong that is not allowing the video and sound to work--- if that doesnt work--- try using a combination device and hooking the two items to it--then run that device's wires to the television
Dec 03, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Power Problems - won't turn on
first thing to do is determine if there is a blink code as that gives a direction for t/s. regardless, what you should do first is offload the y main and x main sustain boards from power supply one at a time as there is a common issue where these boards can cause load on power supply and if voltages come up with either one offloaded that board should be replaced before proceeding. if y main is the issue there is an upper and lower buffer board to left of that board and also should be replaced at same time as 3 boards complete a circuit and replacing one could cause damage to others.
Aug 15, 2008 | Philips 42PFP5332D 42 in. Plasma...
Philips Problem
Philips 42PFP5332D/37 power problem.
The set blue light comes on, then then standby light comes on and flashes. no picture, no sound and no help from philips. Anyone knows the cause and possible solution? Help
Jul 23, 2008 | Philips 42PFP5332D 42 in. Plasma...
Philips 42PFP5332D 42 in. Plasma Television Logo
138 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
