Question about Executone Lands Phones
I have a IDS 108 System that had a power outage that caused the system to default, and in the process as well the ACD application is no longer available, a backup will not restore the application. Is their still someone that can turn on Software features, and also the batteries on the proccessor card are they still available? Or what is a replacement? Thanks
  • 1,871 Answers
Hello! Please provide the complete model and serial # of your phone system...
Guru...........saailer
Posted on Feb 04, 2010
Mithsubisi cassette unit Error code S108
Error 108 are caused by misconfigured system files.
Error 108 Problems usually happen when the computer's registry system overloads with to much data, or when certain system files become missing or broken.
Try disconnecting power for 10 minutes or so to reset the unit.
Jan 17, 2013 | Heating & Cooling
Sony CDP-CX450 Cd Player
As in most current devices, absence of power (as in shortages/outages) simulates a reset. The reset reverts the unit back to factory defaults which of course does not have user configurations and settings.
A workaround perhaps would be with the use of a UPS as those used in computer systems.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 23, 2008 | Sony CDP-CX450 400-Disc CD Changer
22.1:10 system error
Fault code:IDS right unit faulty...
Location: Remove left cover, you can observe the unit where we insert ink cartridges.
IDS:Ink Delivery system: This unit contains two individual units called as right & left units with respective DC motors... Each unit maintains three ink cartridges to push the inks to print heads through ink tubes.
How to shoot the problem: The easy method is to replace IDS unit (well known as Ink supply station).its costly affair.
For tech guys only: Remove left cover, disconnect IDS cable from electronic module, remove screws,take out IDS, remove both motors. Now rotate manually both pumping shafts, you can observe the right shaft harder then left, result motor unable to run the unit as same as left unit. Now follow the snap shots lubricate as shown in movie, once its done perform IDS test through diagnostic test.(entering in diagnostic mode:shut down the unit using the power button through control panel,hold UP & OK button power on, wait till printer enters in to the mode, scroll to diagnostic test & utilities, scroll to Ids test. if its passed you are succeeded or else try once again the same process. Pl don't do this R & D if you are not confident..This is my experience try it.. Best of luck
Dec 04, 2012 | HP DESIGNJET T1200PS 44IN 2ROLLS 32GB RAM...
Power outage now you have to select a line manually instead of just picking up phone and it's taking awhile before it starts ringing
What usually happens after a power outage is the system defaults because the backup battery in the memory card is dead. That means 2 lines only on every phone, pulse dialing, and all phones ring. If your system looks like that, it's time to call the Nortel repair tech. He can replace the battery or software module with a new one and reprogram the system.
Carl
Aug 17, 2010 | NorStar M7324 Corded Phone
We seemed to have a power outage over the weekend. We have M7324 system with 6 rollover lines, only the first two work now, the other four are not working. I rebooted the system, no change. Can you help?
You must have an older system. There is a battery built into the control unit (not user replaceable) that stores the system programming in case of a power outage. When the battery is dead, your system will lose all programming and default to assigning the first 2 lines to all phones. The system will have to be completely reprogrammed.
Please Note: Now would be a good time to install a UPS/Battery Backup unit on the phone system. I recommend a large enough unit to keep the phones running for at minimum of 2 hours during a power outage. Install the UPS/BB first, and then reprogram the system (so it won't have to be reprogrammed twice). Good Luck!
Aug 02, 2010 | NorStar M7324 Corded Phone
Installing XP
Acer computers come with a factory restore partition installed from the factory. The following instructions are direct from Acer's support website:
Note: These steps will return the system to the original factory installation including all factory installed drivers and applications.
Back up all data prior to using this procedure.
  1. Plug in the AC adapter and battery.
  2. Turn the system on
  3. Immediately, press ALT on the keyboard and start tapping F10.
    Continue holding ALT and tapping F10 as the unit boots up.
  4. A screen stating "Starting Acer Erecovery" should appear.
    (Release ALT and stop tapping F10 at this point)
  5. There will be 4 options:
    1. Restore system to factory default
    2. Restore system from user backup
    3. Restore system from cd/dvd
    4. Exit
  1. Enter the password created when eRecovery was first started.
  2. Read the on-screen warning and choose Yes.
  3. Click Next. The recovery process will start.
When recovery is complete the system will re-start and will need to complete the setup of Windows.
When setup is complete a process will clean up the recovery files.
Please be patient as this process can take 5-10 minutes or longer.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 18, 2009 | Acer TravelMate 4230 Notebook
I am trying to re-install ACD vrsion 7 which I bought some time ago.
check if it is still in the recycle bin, or you try a system restore if you can not restore then you need to install using the cd of this ACD system
Dec 19, 2007 | ACDSystems ACD Systems 7.0 Powerpack for...
Ring and paging system
I have seen cases where programming can be messed up or even set back to default with rapid on-off-on-off power surges that often happen in power outages. The system will need to be re-programmed. I have never programmed an NEC system but here is what you need. Either find a local installation company that can fix this for you OR figure out which NEC phone system you have and locate the Programming and Installation manual for it. (not a user guide or administrator's manual) The phone's part number will not help you figure out which NEC system you have, it only narrows it down a bit. Look for the main control unit in the basement, utility closet, etc.. Programming any phone system can be daunting for someone who has not done it before even with the right manuals. If you are not up to it, look for a company that can help. MAKE SURE the system is defaulted before re-programming it! There could be a glitch in the programming that cannot be fixed without a system default so you want to do this before making any changes. Also, I would highly suggest a UPS backup power supply for the phone system. This will keep it running for a short time in a power outage and will stop this from happening again. If you have a small system with 1-12 phones, most small UPS systems made for computers will work. Small phone systems use less power than a computer and monitor.
Aug 21, 2007 | NEC Electra Elite 32D-1 Corded Phone
Only 1 phone rings
There is a small battery inside your main control unit that keeps programming in memory during a power outage. The life of the battery is about 5 years give or take. When the system goes down for an extended period (or possibly several quick on/off cycles) your programming will be wiped out. By default, only a few telephones will ring. The battery is most likely a small blue 3-cell battery soldered right on the main board. It's not easily replaced. You can get a technician to replace it or hook up a standard battery backup unit (UPS) made for a computer. Your phone system uses less power than a computer so it can use any UPS and will last longer than advertised. Hard to say exactly how long. Just don't re-program the system until you take care of the problem or it will just default on you again.
May 30, 2006 | Vodavi Starplus DHS 7312 Enhanced Phone
Lands Phones Logo
Top Executone Lands Phones Experts
David Burbee
David Burbee
Tom Chichester
batMichael
Level 1 Expert
Are you an Executone Lands Phone Expert? Answer questions, earn points and help others
