Question about Dell Latitude D600 Notebook
Acer notebook VGA problem
My notebook when connected up to an LCD TV via a VGA cable when booting up displays the Windows desktop but then goes off and the TV says 'no PC input' . Changing the resolution and toggling between the two displays has no effect on the TV. Any ideas please ?
  • Octogenarian Feb 20, 2008
    My notebook is an Acer Aspire 1522 running Win XP. I can toggle between screens OK but the TV screen says 'no PC input' except when booting up when it displays the Windows desktop correctly. Possibly a BIOS problem.
    Thanks for your help.
    Scholar:
  • 101 Answers
Not sure about your model as the header is Dell D600 and you mention Acer but the solution is probably the same. You need to enable the 2nd display - I'm assuming you are running XP. Go to display settings -easiest way is to Right click on the desktop, bringing the display menu and Left click on Properties (bottom entry). Then click on Settings and you should see 2 screens and you will need to enable the 2nd monitor and set up how to display on it. Additionally there is a setting in the BIOS that enables both display outputs.
Posted on Feb 20, 2008
I am trying to connect an acer one notebook to a beko 32" flatscreen and everytime i plug the vga lead in the laptop screen goes black an the tv says no signal,,what am i doing wrong??
It could be a no. of things:
- Wrong input selected via the TV
- The VGA input on the TV is turned off
- Problem with the VGA cord
- Problem with either VGA port
there the basics, if there all great and it's still no working, try setting your Computer display to EXTEND rather then projector only, then play around with your graphic output settings.
UPDATE all your Drivers and check all your cables. PLUG IN YOUR LAPTOP, yes it will make a difference to the way the graphics card operates.
Hope this helps.
Mar 05, 2011 | Acer Aspire One PC Notebook
How to connect an acer 3680 with windows xp to lcd tv
hi khan, its very easy to do this process , you can connect vga card just see this video
immortal4u_0.jpgGood luck ! if you think your problem solved don't forget to rate
Jan 01, 2011 | Acer Aspire 3680 Laptop
I recently purchased a ASUS K60 Notebook from best buy. I am using Windows 7. I am trying to hook it up to my 42" inch LCD tv via a VGA cable. My problem is that when I do all I am getting is my Desktop...
Since you are using a laptop to connect to an extended monitor, follow these steps:
  1. Make sure that both the laptop and TV are on.
  2. Connect the VGA cable from the laptop to the TV.
  3. Then hold down the FN key and the function key with the TV/Monitor icon like the one below to switch to dual monitor display mode.
Jun 09, 2010 | ASUS K60IRBBBR05 Notebook
Can i connect my acer 10.1 to my tv ?
yes if it is LCD tv you can using the VGA cable
Dec 30, 2009 | Acer Aspire One PC Notebook
I have connected my old dell laptop to this TV with VGA cable and audio cable and it worked with no problem. Have new Acer Aspire one netbook- connected to computer with same cables - can see windows...
First, you want to make sure the laptop's internal/external display mode is set properly. On Acer netbooks, this is usually changed by holding the "Fn" key, and pressing "F5". Either the TV or the computer display should flicker when you do this. There are 3 modes:
1 Computer only
2 TV Only
3 Computer and TV
If changing between thos emodes doens't work, continue on.
I am going to assume you are running Windows XP. Please correct me if I am wrong.
To display your desktop on an external monitor, you'll need to change/check some settings. Your netbook is most likely attempting to set it's display settings automatically, but it is expecting a computer display, not a television, so the resolutions and refresh rates are conflicting. That's why it will only display on one and not the other. Before Windows loads, the netbook is using a very low resolution,so it displays on the TV. Once Windows loads, it switches to some non-standard resolution that your TV cannot display and defaults back to your netbook screen.
The solution is to find a resolution that your television will display:
1.Right-click the desktop, and then click Properties.
2.In the DisplayProperties dialog box, click the Settings tab.
3.Click the Display list and select your external monitor (..the TV. It will most likely be display #2).
4.Select the Extend my Windows desktop onto this monitor option.
5.Select 640x480 in the "Screen Reolution" section for Display #2.
6.Click Apply or OK.
Note: If you see the background change on your television, mmove your mous there to make sure it's working. If it DOES work, go back to the "Screen resolution" section for Display #2 and find the highest resolution your television will display
Sep 19, 2009 | Westinghouse SK-32H540S 32 in. LCD TV
Monitor only works with DVI/VGA adaptor.
if your monitor came with a disk try installing the drivers again you might still have the drivers for the previous monitor you had with your system if not try going to the manufacturers website and getting the drivers and install them
Aug 13, 2009 | Acer AL2016W 20" LCD Monitor
How do i set my acer travel mate 2312lm to 1440 by 900 pixel so i can work my lcd tv
**Your Laptop has VGA port for connecting external monitors :
Laptop Video Specs :
Laptop's Max Resolution1024 x 768
Integrated Video card : SiS Mirage M661MX
NOTE : If LCDTV does not have a VGA port, you will not be able to use it a external monitor.
Steps :
1. Connect Laptop to LCDTV using a VGA Cable
2. Right-click on your desktop and select "Properties." (or click on start > Control Panel > Display)
3. A new window displaying several tabs will appear. Select the tab called "Settings."
4. You will see boxes with numbers on the middle, in your case 1 and 2 will be present.
5. Click on 2 and click on box beside "Extend my windows Desktop onto this monitor" then choose the resolution that you like (1440 by 900) then click on apply. If 1440 by 900 is not available, choose the closest under 1440 by 900. Don't go over 1440 by 900 since that is the max value that will work on you LCD TV.
6. After clicking on Apply, the display should be present on the LCD TV. (The disply is an extended desktop so you will not see the start button nor the taskbar on the LCD TV. but it should have the same wallpaper. You can Drag the windows to the LCDTV. This will serve as an extension of you desktop. (Ex : You can watch movie on the LCDTV and you can do documents on the laptop's screen at the same time).
Oct 27, 2008 | Acer Computers & Internet
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Acer 3610 help
Try this:
Start -> Control Panel ->Display
Select the settings-tab
Check the "Extend my windows desktop onto this monitor"
Apply
I am assuming you connect to your LCD TV with VGA or DVI cable?
You may also have to press Fn+F5 (or some other combo) to enable the vga/DVI out on your computer. You may also have to change the resolution for the secondary display (the TV)
Nov 14, 2007 | Acer Aspire 3610 Notebook
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Dell Latitude D600 Notebook Logo
640 people viewed this question
Alun Cox
