Hi
I got the Bravia KDL-40EX713 and the uwa-br100 I had massive problems getting it to work with a BT home hub. Eventually I found manual setting that work. Firstly I logged on to the router and went the the advanced settings bit, then I went to the DHCP table that shows all the devices connected. I picked an unused Ip address from the range of existing ones being used (this sort of thing 192.168.1.73)
I then used the following settings for the other fields (I don't think the secondary dns setting is right but it still works)
ip 192.168.1.73
sn mask 255.255.255.0
default gateway 192.168.1.254
primary dns 192.168.1.254
secondary dns 192.168.22.23
If the DNS server ip is wrong then you get local access OK but internet access failed.
Hope this helps.
Ian
