Question about Refrigerators
I am having problems with my samsung fridge model - SR-S2028CSS
The fridge dont work properly, the the temperature of the freezer and fridge seems to be the same and it switches off for a long time and goes on again causing the food to defrost and go bad.
  • FaithFarai Feb 22, 2008
    Thank you for your quick response and i think its really fantastic!!!
  • 123 Answers
Does it freeze at all? you may have a problem with the coolent in the back of the fride which if so (depending on the cost of the fride) may be cheaper to replace, also the dial you use for selecting the freeze level could be faulty
Posted on Feb 19, 2008
Samsung American fridge freezer SR-S2028CSS keeps beeping and randomly turning the fast freeze on and off.
quite possibly it needs some freon added to the system and only service people can do this
Jan 06, 2016 | Samsung Refrigerators
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
My Samsung Cooltech plus fridge's temperature keeps on skipping back to 9 degrees celcius. Freezer is working fine, what can the problem be?
Every time I select my fridge and freezer temperature from -16 and 3 degrees C respectively it keeps on going back to 20 and 18 degree C. Please assist.
Mar 11, 2011 | Samsung CoolTech Plus / Basic Bottom Mount...
Hi. I own an older Samsung SR-S2028CSS fridge/freezer. The temperature control setting and ice mode selection buttons were ineffective and the fridge and freezer had increased in temperature, but...
blank display with segment flashing is a fault code samsung appliances use this method for displaying faults ...
samsung fridge freezer trouble shooting videos are available on youtube ..
have alook at this video and see if its the same segment that you have
Jan 20, 2011 | Samsung RS2534 Side by Side Refrigerator
Samsung side by side fridge freezer sr-s2028css. having seeked advice from refridgeration engineer was told compressor was not working, had a new compressor fitted by another engineer but still existing...
Did they change the start relay as well as the compressor? On Samsung refers the start relays do not come with the compressor. If they didn't its possible that the start relay is clicking.
Oct 07, 2010 | Samsung Refrigerators
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
Samsung fridge freezer not cold enough
Hello whiten61,
Welcome,
You said, You noticed there was condensation in my fridge and a strange smell coming from it, also my freezer was cold but didn't seem to be cold enough, I have a digital display and it was still showing -22 for freezer and 3 for fridge. I turned the power off on the wall and when i turned it back on which was straight away it shown -3 for freezer and 16 for fridge... I then noticed the ice cream in freezer very watery, however ice in freezer still frozen? i pressed the quick freeze button which eventually the temperature came back up but i keep getting the exact same problem... Can you help. thank you.
Samsung side by side refrigerator SR-S2025CVW
How old is the fridge?
You did all the right things!!
But this sounds like a bad thermostat.
or a bad control switch.
Unfortunately it sounds like you may need service to do an hands on diagnoses and replacement of one of these parts I listed here!
Let me know how you do! Or if you need something else.
We do have very good sponsors here on this site that do repair work, should you take this course!
Huuum
Please remember to leave a rating.
Oct 14, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Feb 28, 2008 | Refrigerators
Refrigerators Logo
409 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
