Question about Refrigerators
I have a Frigidaire Side by Side Refrigerator with a defrost problem
I have a model FRS26ZRFW1 Frigidaire, bought on June 97. I followed your instructions for a similar problem and replaced de thermostat. The freezer still making frost build up, closing the circulation of the freeze and not cooling the refrigerator. Because my model is different I couldn’t find the timmer to replace.
I did check the heat element with the digital multimeter set to de beep position, but I couldn't hear anything. I also tested the new thermostat and it checked closed when cold and opened after removed from the ice.
What should I do?
You're right! I did change de heater and the fridge is working great now.
thank's
Posted on Feb 22, 2008
    President:
  • Refrigerators Master
  • 2,651 Answers
Your heater should def "BEEP" when checking for continuity. if not you got a bad heater, defrost timer should be located under left or right side of kickplate
Is there a charge to ask a question?
Hello friend, I appreciate your post!
There should not be a charge to ask your question as this is a public site for assistance. I would be happy to assist you with the issue on your Frigidaire refrigerator, FRS26ZRFW1. -Matt
Oct 06, 2014 | Frigidaire Refrigerators
How do you put your refrigerator on defrost mode
Hey friend, thank you for the post!
From my understanding you are trying to set your Frigidaire refrigerator into defrost mode. In order to be able to provide you accurate information on how to do so could you provide me with your model number please? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side in a top mount. But on a side by side and a French door refrigerator it can be found on the right hand side. I look forward to hearing back from you. -Matt
Jul 22, 2014 | Frigidaire Refrigerators
Location of defrost timer on frigidaire model lfus2613f3
Hello Friend, thank you for allowing me to assist you!
It appears that the defrost timer of your Frigidaire refrigerator (LFUS2613F3) uses the main control board to energize defrost. The defrost timer is located at the front of the control console in the fresh food compartment (display that controls all functions). I do hope this information proves to be helpful! - Z
Jun 04, 2014 | Frigidaire FRS26KR4A Side by Side...
Where is the defrost relay button?
Frigidaire equips most of its refrigerator models with automatic defrosting capabilities. This means that owners don't have to set a calendar reminder to manually defrost. The internal automatic defrost control and timing mechanism is placed at the bottom of most Frigidaire refrigerators, next to the stationary panicon1.png that captures water - even the defrosted meltwater is automatically evaporated. You might be confused about how the defrost timer works, thinking it is broken. Frigidaire understood this might be an issue for some owners and suggests double-checking the defroster for normal operation because it may not be malfunctioning at all.
Read more: http://www.ehow.com/how_12165725_troubleshooting-frigidaire-defrost-timer.html#ixzz32x8RyDGe
May 27, 2014 | Frigidaire Ffhs2622mh 26 Cu. Ft....
Frigidaire  FRS26ZRFW1 not cooling
One non-question, so many non-answers.
May 06, 2012 | Frigidaire Refrigerators
My refrigerator frigidaire FFUS2613LSO is not cooling
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 23, 2011 | Frigidaire FFUS2613L Side by Side...
We just bought the house so we are not used to this. Could it be in defrost mode. The freezer is ok but as said the temp goes up a degree and now at 20c
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 02, 2010 | Frigidaire FRS-26DR7D Side by Side...
My frigidaire refrigerator keeps defrosting on the freezer side
sounds like a bad defrost timer
or depending on the model a bad
electronic or adaptive defrost board
Oct 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool Gold freezes up to frige side
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Frigidaire FRS6R5EMB Side by Side...
Refrigerators Logo
377 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
