Question about Frigidaire Dryers
Drum turns but it doesn't get warm? - Frigidaire Dryers
  • 572 Answers
Check for the thermal fuses in it
Posted on Feb 05, 2010
Logik tumble dryer gdz 60-10sw heard clanging noise now dryer still goes on but drum doesn,t turn.
Sounds like the drum has fallen off of the support rollers. Will need to open up cabinet to verify
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jul 04, 2016 | Dryers
Mtd4 mistral
Underneath where the motor is,, there is a locking mechanism, which is operated by a cable connected too the lid, check cable hasn't snapped or come off,, it's adjustable also,, may just need adjusting
Jun 17, 2013 | Creda S202pw Debonair Spin Dryer Drier 9lb...
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Oct 23, 2012 | GE DBVH512EFWW Dryer
I have a Bosch Exccel condenser dryer WLT6305GB/01 FD 8309 200147 it seems to get warm not hot, isn't drying properly, stupidly replaced the heating element and thermostat unit before checking if it...
could be the condenser unit..........they get blocked up with lint..........i take then outside and flush with a hosepipe............
cheers
Jul 27, 2017 | Dryers
Siemens xlm1600 drum doesn't turn - motor running - full load of wet washing. Inlet/outlet checked and cleaned - ok. Won't even turn when empty. Whats up?
something jammed between outer drum and inner drum or bearings jammed, if any off these then belt will be burnt Re: Jeff
Apr 12, 2012 | Siemens Washing Machines
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
My beko condensor dryer is not turning anymore, the heat is fine but it doesn't tumble
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
Sep 22, 2011 | Dryers
The drum turns. It heats up. But only small loads of cotton get dry! We have changed the vent tube. Vacuumed the vent the lint catcher area and around the drum to remove lint and hair. Still not...
A very typical problem with GAS dryers is the soloniod coils that open the gas valve . When the coils are cool they operate just fine,but once the dryer gets warm from running the coils dont open the gas valve wwhen they are warm. If that is what your experiencing,the dryer heats when its cool but doesn't heat when it's been running for a while,the coils on the gas valve will need to be replaced.
GENE
Aug 16, 2011 | Roper RGX4634KQ Gas Dryer
Dryer not working I replaced the Thermal fuse and still not working.
Is the drum turning? If it's turning, then maybe the high-limit thermostat or element is bad. If drum doesn't turn, check lid switch.
Sep 26, 2010 | Kenmore 74672 Gas Dryer
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Dryers Logo
26 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
