Question about Maytag MER6772 Gemini Electric Kitchen Range
Gemini MER6769BAW Range/Dual Ovens
The lower heating element in the lower oven is non-operative. Is it likely a faulty element or something else? Is replacing the element difficult to do for a do-it-you-self homeowner?
  • 3 more comments
  • SWEETIE05 Mar 15, 2008
    I set the timer either on the upper or lower oven, set the temp required. it turns on for about 1 min then shuts off... it gives me an F9 error. i don't have te manual can someone help.
  • sdgb Apr 10, 2008
    I thought mine was the element, turned out to be the main circuit panel aka control pad. This cost me around $450. The element itself is not hard to replace on mine, a few screws and it unplugs. Have someone test it before buying one. If it is burnt out it may have a blown out spot that is easy to see
  • Anonymous Dec 05, 2008
    The lower element in my bottom oven is not working. The top element works, but the oven will only heat to about 225 degrees. Can someone walk me through a diagnosis and possible fix.
    Lower
  • Anonymous Mar 21, 2014
    LOWER oven wont heat
    Problem Solver:
  • 16 Answers
Depending on type of unit. most of the time they are very easy to change out.. look at element locate two screws. go shut off breaker to oven.. make sure its has no power. after removing screws element should come out fairly easy.. make sure not to let wires fall back inside unit. if so not to worry. just pull unit out from wall and remove back panel. push wire back through. hope this helps
Posted on May 15, 2008
Should the lower oven heating element heat all the way around? The heating element in my oven only heats and glows red on the front and two sides, The rear part of the element never glows red.
This is probably normal. the element has a fine wire inside the tube that you see and depending on where it starts in the tube it will start glowing from there.
Nov 15, 2014 | Maytag MER6872BAS Gemini Electric Kitchen...
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
Maytag Gemini Electric Range Model MER6770AAW. Upper oven broiler element will not heat up. Took the element to a parts appliance store where they tested it, and the element tested that it was still...
The control to tun the element on must be faulty, you will have to check it with an ohmmeter after youtake the wires off of jt make sure you draw a diagram of where the wires go when you put them back on Make sure to turn the power off before you start Hope this works for you good luck
Jan 03, 2011 | Microwave Ovens
New heating element pops circuit breaker
Obviously something is shorting out. Check all wiring.
Oct 31, 2017 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
MER6779BAW Range/Double Oven
I haven't checked anything but the heating element. The fault codes read F0-0, which means no fault but..... ?
Mar 03, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gemini MER6769BAW
Power to that element comes directly from the oven control. If you have replaced the element and all wiring is ok then the control is bad even if you hear it clicking. The part # is 74006213 and cost is $298.99 @ http://www3.sears.com/.
Part # for http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48695 is AP377973 and their price is $230.53.
Nov 11, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
484 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
