Question about Toshiba Satellite A75-S211 Notebook
How do you replace a keyboard on a Toshiba a75-s211
    Scholar:
  • 73 Answers
Hi look here.
http://www.irisvista.com/tech/laptops/ToshibaA75/satA75_1.htm
please rate.
hope this helps
Posted on Feb 03, 2010
Testimonial: "That was exact information I needed for my computer problem.....Thanks so much!"
Ok i did a clean install of windows 7 ultimate on my toshiba satellite a75 s211 then when i do that i cant hear so i get the latest realtek driver from the toshiba website i install it and i still cant...
Issue with your Hard Disk Possibility of bad sector ..on the primary sector... So Download Partiion Magic and Re- Partionnate your Har drive and Re install you windows
Sep 22, 2010 | Toshiba Satellite A75-S211: A75-S211 Intel...
My toshiba fans their a little noisy how bad do i need to replace
Two cans of compressed air can work wonders. I usually use both cans at the same time, just take the laptop outside and spray away. Make sure it's off, of course ;)
May 25, 2010 | Toshiba Satellite A75-S211 Notebook
My Toshiba A75 S211 os XP Home microphone is not working, is there a switch or something else?
Hi, from the "Start" search window: Type: microphone, select to open and configure to specification. "If the solution helped, rating it is appreciated , thanks.
Mar 17, 2010 | Toshiba Satellite A75-S211 Notebook
My Toshiba Satellite A75-S211 computer, will suddenly shut down.
Mine did this and I thought it was overheating and vacumed the back vents. This fixed the problem.
Nov 20, 2009 | Toshiba Satellite A75-S211 Notebook
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
Toshiba A75-S211 memory
I'm showing a base memory on that unit of 256 so your max upgrade is 1gb to 1.2gb total.
1GB (1x1GB) Toshiba Notebook 2.5v PC2700 DDR333 SODIMM
Apr 14, 2009 | Toshiba Satellite A75-S211 Notebook
My Toshiba A75 S211 shot off
the issue is likely thermal shutdown (it got to hot) listen to establish whether the fan(s) are working. you will need to take it apart to gain access to the fan area to clean out the dust and dirt.
Mar 24, 2009 | Toshiba Satellite A75-S211 Notebook
Toshiba A75-S211
You can do either.
I suggest that if you want to double your memory capacity is to buy another memory module with the same specs and size as the existing one, preferrably from the same manufacturer.
Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    How do I replace a keyboard on a Toshiba Satellite A75-S211 laptop computer. I cant see any way to get it out. Also, the power button needs to be repositioned... same problem.
    How to take apart Toshiba laptops. Instructions with pics ... 10 posts - Last post: 21 Mar 2006 Toshiba Satellite A70/A75 Toshiba Satellite P25 Toshiba Tecra A1 .... Toshiba Portege 3500 Tablet PC manual. How to remove and replace the ...
    www.thinkcomputers.org/forum/showthread.php?t=632 - 76k -
    Dec 31, 2008 | Toshiba Satellite A75-S211 Notebook
    Toshiba Satellite A75-S211 Notebook Logo
    127 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
