Question about HP Pavilion dv6000z Notebook
Laptop LCD problem
Laptop Toshiba Satellite 1115 S103 screen size 14.1 inch
Laptop LCD displays all white screen. When I connect an external monitor it displays the video fine. Is the problem in the LCD, the Inverter or both?
  • xgrantheftx Mar 12, 2008
    I have the same problem with a Toshiba M55-S3512. As soon as you boot the laptop the screen automaticly turns white and does not change. When you connect an external monitor, everything works fine until you get to the windows login screen then the display reverts to the laptop and does not show anything. However, if you boot the laptop in safe mode while connected to an external monitor, everything works just fine. I tired your suggestion on pressing the Fn and F4 buttons but all to no avail. I could use any help or suggestions that you may have, thank you very much, and have a great day.
  • Anonymous Aug 24, 2008
    when turning on my laptop in getting white 'blobs' and white vertical lines across the screen. please help.........
Maybe the problems is your resolusion is to high
so you need to resize your resolusion.,
1.turn on your laptop
quickly hit F8 ( do not leave hit F8 until you see a safe mode, but don,t choose dsafe mode.,but choose enable vga mode).
3.if your laptop does,t appears safe mode or enable vga mode
you can repeat step one..
other solusion you can do step 1 and then wait until appears option safe mode ( but do not leave your finger hit F8 until appears menu safe mode.,and you choose safe mode and klik ok and yes and right klik on the desktop and choose propertis and setting and you see screen resolution and move the screen resolution until 800 x 600 and ok and restart and every thing will be normal..
from tandra halim.,solution for 1
Posted on Mar 20, 2008
  • 123 Answers
Hi, have you tried switching the screen mode, i think its FN button and F4, failing this you may have a faulty LCD controller chip, messy to fix unless you bring it some one who is repetable at fixing laptops...
Posted on Feb 19, 2008
TOSHIBA Satellite 1115-S103 hard drive upgrade?
I was unable to find the specific laptop
Toshiba Satellite hard drive removal
http://www.youtube.com/watch?v=8xv9oiNxyZk
How to replace the hard drive on a Toshiba laptop
Hope this helps.
Nov 26, 2012 | Toshiba Satellite 1115-S103 Notebook
Display divided into 3 parts
LCD screen cracked, and Three even strips going across? Doubtful. Haven't seen it but I always have my mind open.
Three strips that are irregularly shaped? Look like glass that has cracked?
'Jagged edges'?
LCD screen is broken.
Three even strips indicates to me, that there may be a problem with the Video Cable. Then the screen Inverter is next in the diagnoses.
My money is on the Video Cable.
ALL power removed, Anti-Static Precautions FOLLOWED, I would check out the graphics chipset first.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the laptop.
Left rear side. This is an example of a VGA Cable, and VGA connector. (VGA port on a laptop ),
http://en.wikipedia.org/wiki/VGA_connector
(Color of connector does Not matter. It is generally Blue, though)
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
There are at least 3 display options available;
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the same time tap once on the F5 key. (The F5 key is the Display Toggle-Over key)
No display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F5 key.
Is the display on the external VGA monitor, the same as the internal monitor of the laptop?
Problem is the graphics chipset.
Display is fine on the external VGA monitor?
Problem is the Video Cable, screen Inverter, or LCD screen.
Video Cable:
A) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/big/Toshiba-Satellite-A105-14.jpg
Switch Cover removed, Keyboard removed. Shows you where the Video Cable plugs into the motherboard.
B) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/big/Toshiba-Satellite-A105-21.jpg
Palm Rest Cover you can see the white rectangular connector, for the motherboard side of the Video Cable, at the top left.
It's above the black cable, and near the screw hole.
The Video Cable leads from the motherboard, up through the left Hinge, and into the Display Assembly.
From there it connects to the screen Inverter, and back of the LCD screen.
http://www.ebay.com/itm/Toshiba-Satellite-A105-6017B0050801-LCD-Video-Cable-Genuine-OEM-Laptop-TESTED-/290754851160?forcev4exp=true&forceRpt=true
In the photo, (You can hover your mouse cursor on it to enlarge), the right side connector plugs into the back of the LCD screen.
The black connector to the far left connects to the motherboard.
The small white connector at the top with the Red, Green, Black, etc wires, connects to the screen Inverter.
(The small Black cable, that comes out from the black motherboard connector, is a Ground wire )
Due to the close proximity of the Video Cable to the left Hinge, it can be pulled on from just normal opening, and closing of the laptop over time.
This means the Video Cable connection on the motherboard side could be loose, or the LCD screen side, or both.
The diagnoses is to PHYSICALLY check BOTH connections. A loose connection at the motherboard, or at the back of the LCD screen could be so small in distance, that you will not see it with the human eye.
Could also result in damage to the Video Cable.
View the Video Cable with the Switch Cover removed, and see if there are any obvious signs of damage to the sheath of the cable.
If there is there could be damage to the tiny wires inside the Video Cable. (Stretched/Broken)
Use a multimeter set to OHMs, to check all wires inside the Video Cable for continuity, or have a 'Mom and Pop' computer store check it for a few bucks, or replace the Video Cable.
Video cable connections are tight? Video cable continuity check checks out OK?
Screen Inverter.
The test for a screen Inverter is to use a sensitive multimeter.
Read fairly expensive.
http://www.fonerbooks.com/test.htm
Not having access to a sensitive multimeter that you can use, means just replacing the screen Inverter. Seems like 'part changing', and it is, but you have to work with what you've got.
http://www.sparepartswarehouse.com/Toshiba,Satellite,A105,Laptop,Inverters.aspx
Find THE model number for your laptop, and the correct screen Inverter. A screen Inverter, and an LCD screen are a MATCHED unit.
Screen Inverter is checked out to be OK, or replaced, and symptoms are still the same, the problem is the LCD screen.
Remember, the first part of the diagnoses was to see if the divided parts were EVEN going across, or jagged and irregularly shaped.
Jagged in shape, and not even strips going across, means cracks in the LCD screen.
Replace.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
[ Main article for A and B links above;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm ]
For additional questions please post in a Comment
Regards,
joecoolvette
Oct 22, 2012 | Toshiba Sattelite A105-S2051 Notebook
Where can i get assembly or disassembly info for my toshiba satellite 1115-S103. Need to put it back together.
Here are the link for the Toshiba Satellite 1115-S103that you requested.
For Html
For Pdf.
Download the file and for html you have to extract first click the file with extension html.For pdf download the file and you dont have pdf reader download acrobat reader and install, in order to view the pdf file. Have a good day
Dec 22, 2010 | Toshiba Satellite 1115-S103 Notebook
I have an old toshiba satellite 1400/2400 and the lcd screen first happened to show black stripes and the picture was shaking, and now the screen is fully black. Is there a way to fix it?
If the laptop appears to boot up and the hard disk LED flashes, then the problem could be a back light fault. This fault could be caused by a faulty inverter or a faulty CCFL lamp. Please clcik on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 23, 2010 | Toshiba LCD Display for SATELLITE...
My Problem w/ my Toshiba Satellite P105-S9337 model no. PSPAGU - OOJOOV is it has a strip of white line vertical on the screen and it's about 1" thick? is their a way I can fix this problem?
Connect an external monitor to the VGA port on the computer. If that display is correct, then it's probably the LCD screen on your laptop that is damaged.
Find a computer-store. They may have "pre-owned" LCD screens the same size, for about $100.
A "brand-new" LCD screen is at least $200.
Replacing the LCD screen is *NOT* something that *YOU* can fix, unless you're a qualified technician.
Jun 15, 2010 | Toshiba Satellite 1105 Series 14.1" Flat...
Red vertical stripes 1" wide, black screen half screen, normal windows screen 2" left side
So long as there are no inpact marks on the screen or cracks there is an issue with the lcd screen and so long as the machine is in manufactures warranty is covered (1 year).
You would need to get in touch with the company you purchased machine from if it is in warranty
Mar 18, 2010 | Toshiba LCD Display for SATELLITE...
Internet problems
please give more details, like error messages, codes, etc! :)
Dec 19, 2009 | Toshiba Satellite 1115-S103 Notebook
Toshiba Satellite Laptop 1115-S103 trouble shoot VGA & projector
it should be f5 if not then look for an icon that has a computer screen on it
Apr 08, 2009 | Toshiba Satellite 1115-S103 Notebook
Toshiba Satellite 1115 S103 can't install Windows XP home edition
after it reboots it will ask you to boot from cd,
ignore this and let it boot from harddrive, where it has already copied the files to... it should setup ok from there
Apr 06, 2009 | Toshiba Satellite 1115-S103 Notebook
Powers on but won't boot
If you swap boards and the machine still won't boot, then your problem lies with either the hard drive or memory.
Jun 25, 2008 | Toshiba Satellite 1115-S103 Notebook
HP Pavilion dv6000z Notebook Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
