Question about Insignia IS-LCDTV32 32 in. Television
The power will not stay on or off, just keeps coming on, then as soon as it starts to show the picture it turns off again.
  • Insignia Master
  • 12,061 Answers
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
Remember there are leathl Voltages inside TV's, and generally these days don't contain any "User Servicable parts" like in the "Old" days, instead Board Replacment is all that is generally done.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Posted on Feb 03, 2010
Polaris 500 efi atv c power won stay on keeps shutting off
you have a short circuit on a positive wire. inspect your fuse box and your wiring harness for any visual damage
Oct 16, 2014 | Polaris 2006 Sportsman 500 EFI - Red Flame
My fe-280 model has color problems.
Has this camera ever been left in a hot car?
Apr 17, 2010 | Olympus FE-280 Digital Camera
Rca r56wh78 Keeps coming on and shutting off
If you have no experience with electronics or are not a TV technician or not have the right tools then you will either have to get a tech or find a hobby to entertain youtill you can get it fixed.
The TV shuts doen because of a voltage leak in the power supply or on one of the X or Y video boards. Do not let it continue to cycle as eventually it will die completely and be more costly to repair.
This is not DIY It involves the starter solenoid and the oveload detector trying to shut down to protect itself. it also requires knowledge of circuitry and the use of volateg checkers
Please rate our help to keep the free service online ++++
Thank you for using Fixya
Sep 01, 2009 | RCA R56WH76 Projection Television
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
The monitor turns off and on repeatedly.
Is it desktop or laptop computer?
If its desktop the data cable might be loose on the back of the desktop computer.
Apr 26, 2009 | Acer Computers & Internet
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
On / Off problem
YOUR ON/OFF BUTTON ON THE FRONT PANNEL IS STUCK
SOME HOW (PRESSED IN ) TY SOME WD40 ON IT . SEE IF THAT WORKS.
Dec 12, 2007 | Samsung TXP3275H 32" TV
Insignia IS-LCDTV32 32 in. Television Logo
48 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
