When I put in dvd it stays on reading can you help?
  • 2 more comments
  • Anonymous Feb 19, 2008
    When I put in a dvd the dvd saya no disc
  • lynn08 Feb 19, 2008
    My Dvd that has been used once, keeps reading the disc, we've tried numerous discs, and cleaning it , not working
  • kiddblue Mar 01, 2008
    Hi I have aJVC recorder and it tell me ,when I tried to record dise error I use dvd+R 1-16 what is the right blanks to use.When I used ajvc 120dvd- rw it did it . help my husband does nt know how to fit this.
    thanks
  • nchudy2004 Jun 30, 2008
    When I put in a DVD the screen says "no disc" after loading for about 2 mins
Try a large hammer. I too have the same problem. It seems as if the dics are coming out with something that this DVD player cannot read.
Posted on Jul 26, 2008
  • 123 Answers
Have you tried another DVD, or try cleaning the lens with a dvd cleaner, good luck ;)
Posted on Feb 19, 2008
I have a panasonic RV26 DVD player. After inserting DVD it goes to the reading mode (normal) but it stays on the reading mode for awhile then code H02 shows and then stops and and will not accept any other...
The Optical head or the mother board is defective. The data is not received and so the Mp is not able to read or process.
hence if have cleaned the optical head lens, and there is no reading try to put in a audio cd to test. If the cd is read the head must be Ok and the DVD processing must be faulty possible board issue but if there is no reading then the optica head is faulty
Aug 30, 2010 | Televison & Video
I put divix movie on usb and put in player and he cant read it i tryed 5 different usb drive and then i try form cd he cant read divix movies. On one usb i have some other data he read that but "DIVIX"...
You are not using a properly encoded dvd. read the user manual and when encoding your own divx file (only trouble free guarantee) you MUST stay within the specs. you must use the following:
1. proper DivX Version, XviD Isn't a guarentee to work
2. Must stay within proper bitrate resolutionwhen and frames per second when encoding and make sure you stick to PAL or NTSC settings whichever your country or player used or was bought in.
3. use mp3 2 channel audio with proper bitrates and sample rate should be 41,000k or 48,000k or 96,000k
if you do your research and stick to these steps you'll be on your way to encoding your own videos and TV shows in no time and with little effort.
audio supported for listening to music is MP3 WMA & AAC (Which should be in the form of .m4a)
Jan 22, 2010 | Pioneer DV410V DVD Player
No matter what DVD we put in, the player stays on "READ"
either the disc you inserted hasn't got a menu. the only thing DVD's do this is because there is no Menu provided in the DVD DISC. In the other case, where it remains "read" the disc might not be clean, scratched, dusty or simply incompatible with your DVD Player. Always clean discs before and after playing them in your DVD Player. Hope this helps, good luck!
Jun 20, 2009 | Goldstar GBV241 DVD Player/VCR
Phillips Portable dvd PET824 won't play dvd; no picture or sound
you can try moving the laser lens that reads the dvd's just don't touch the lens just move that little square it's attached. all you have to do is move it back or forth just a little and leave it and try the cd and if that don't work just keep on moving it around until it reads. it'll work i had that problem on my dvd player and my playstation.
May 02, 2009 | Audiovox D1708 Portable DVD Player
CANNOT READ DVD MOVIES
You need a DVD decoder installed to play DVD movies on your computer even with a DVD Drive.
Learn more about DVD decoder software, use the link I have provided:
http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx
Please rate my solution
Jan 15, 2009 | Dynex DX-DVDR100 (DXDVDR100) Internal DVD...
Tray will not stay closed
This fault usually happens if the disc being read is not compatible with the player's firmware.
If discs are burnt from a computer, or copies, this can happen.
Does it do this with all DVD's?
Are you using commercial retail DVD's?
Otherwise something else is telling the player 'No Disk'.
Try a disc-based lens cleaner as laser may be grubby.
Or the laser diode could be defective.
Nov 21, 2017 | GoVideo D645 DVD Player
DVD will not eject from JVC HR-XVC27U
Disconnect the Power Cord. Open the Case and go to the DVD unit. On the right side of the unit you will see an indentation which is the mechanical portion of the DVD Unit.
Push the indentatation in, it is the eject switch. The DVD unit door opens remove the DVD stuck in the unit.
Put cover back on plug the unit in, insert a workable DVD and all should be OK.
The problem was the unit could not read a Defective DVD which I made and the unit was locked in to reading the DVD.
I hope this helps
May 22, 2008 | JVC HR-XVC27U DVD Player/VCR
Shuts down when I put a disc in
Possible cause is the spindle motor.
Mar 20, 2008 | Panasonic DVD-S27 DVD Player
Axion 7 inch DVD "Travel Theater" loading issue....travel theater....hmm...
Get your money back!
Sue them!
Next time buy a brand name that you can trust!
Mar 06, 2008 | Televison & Video
Can no longer read DVD
I PUT IN A NEW MEMOREX OPTI DIC CLEANER AND ALL I GET IS CANT READ DVD UNABLE TO READ DISK,CAN YOU PLEASE HELP.
Dec 10, 2007 | Samsung DVD-V3500 DVD Player/VCR
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
