Question about Air Tools & Compressors
I have a Porter Cable pancake air compressor CFFN 250N manufactured in 2004 that has an air leak. Pressure can only get to 80 PSI. Checked all the connections and found no leaks. Finally took the cover off the pressure switch box and felt air coming out behind the electrical wires. Apparently the on/off pressure sensing switch is stuck partially open. Any ideas as to what to do to save about $90 that Porter Cable will charge to fix it? Thanks
  • 194 Answers
There is a check valve where the line goes into the tank. The purpose of this valve is to keep air from coming out of the input line. This valve is likely the culprit and it is leaking out of the unloader. The unloader is actuated by the electrical switch when the compressor shuts off, and it relieves the pressure on the line so that the pump is not under load when it tries to start.
Posted on Feb 02, 2010
My Porter Cable pancake outlet regulator doesn't seem to work.
If your quick coupler is not jammed up, (remove & test) and assuming you are pulling the regulator knob out to adjust the pressure and it is not stripped, you will need a new manifold kit.
There are about 6 versions of this unit so you will need model and type to get the correct part. There are no individual regulator parts available for this unit.
Jul 02, 2013 | Porter Cable C2002 150 Psi 6 Gal...
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
My porter cable pancake PSI 150 keeps running will not shut off
The compressor has a max psi setting of 150.If the pressure is not reaching this or is only stabilizing at a low pressure you have an air leak around a gasket somewhere.If it is reaching 150psi and not shutting off your pressure switch is bad.Replace it.Check your owner's manual for a part number or go to www.factoryauthorizedoutlet.com to find the part.
May 05, 2011 | Porter Cable Air Tools & Compressors
My four-year old PC pancake compressor starts fine but only builds up 60 psi no matter how I adjust the pressure regulator. The compressor motor runs continuously. I checked for air leaks and can't find...
First take off the head on the air pump and check the reed valves on the valve plate. If they got hot and warped or cracked they'll work to a point then no more pressure can be built up. Next check the pistion ring and cylinder wall. If either is damaged you'll only get so much pressure build-up then it will leak past the piston.
Mar 07, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I have a Porter Cable pancake compressor Model CFFN250N-2 which when first stated will usually get up to approx. 135 PSI and shut off. However, after a few minutes the compressor will not get up to Max...
Hi, my name is John. Welcome to FixYa. Sounds like you are loosing air pressure somewhere, check for air leaks in the line and connectors. Thanks for choosing FixYa...John
Nov 22, 2010 | Porter Cable Air Tools & Compressors
Trouble building pressure
I would check the reed valves in the pump. One of them may be broken.
Jul 09, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Air Leak From Pump Head on Porter Cable C2001 Pancake Compressor
The real question is where exactly is the leak coming from. Compressors have a pressure release valve designed to let the pressure off of the compressor motor so it can start when there is pressure in the tank. This valve is often the culprit and fairly easy to replace. You can order it direct from porter-cable online. Just in case double check the drain petcock sometimes these get worn and won't close completely and can easily be over looked when trouble shooting.
Jun 12, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
Air Tools & Compressors Logo
243 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
