Question about Sega Dreamcast Console
Dreamcast weird colors
Well i recently bought a dreamcast off ebay. When i fired it up it had contrast colors (like the opposite) and my speaker lets off a unpleasant buzz. Video lead problem, or the console itself?
  • Anonymous Apr 15, 2009
    it is just wierd coulers
Same problem here. Tried another scaert port on the TV and it worked. Great!
Posted on Nov 09, 2008
  • 36 Answers
IF you are plugging it into the scart port then this has happened to me; it's because the dreamcast only supports one type of SCART (there's RGB and the other type...cant recall what it's called..)
The simple solution is:
1) if your TV has two ports then plug the scart cable into the OTHER one (one is usually RGB, one is not)
2) if you're using a splitter so many scarts can go into one socket then DON'T !
3) Might be your TV doesnt support it - find an RF adaptor instead, these generally work...
Posted on Oct 13, 2008
I hae the same problem with the rf lead, i'm gonna try and buy a scart lead and see fi that lps
Posted on Sep 20, 2008
    President:
  • 4,402 Answers
Are you sure you have the correct plugs into it, sounds like you have the video where the audio should be.
Posted on Feb 19, 2008
No video/audio when trying to play Dreamcast
It's not moving the mainboard that causes problems to happen. Alot of people don't know but the screws inside the Dreamcast that hold the mainboard down are different sizes and there is a place where a longer screw isn't supposed to go and it will go in to far and touch the mainboard and cause problems. But that's besides the point of your question but could have been done before. There could be a bad capacitor or a break in the solder joint where the AV port is at also.
Jun 23, 2017 | Sega Dreamcast Console
I just got a brand new cable for my dreamcast but i still have no picture. The problem seems to be internally. What should I do?
the problem might be in the Dreamcast its self or the tv you our using. try connecting it to a another tv and see if that works. If it dosent it is the Dreamcast and i have no idea were you will get another one exept on ebay.
Jun 25, 2009 | Sega Dreamcast Console
Freezing problem with Games
The Dreamcast is no longer supported because it was to easy to copy the games, but there are still a loyal few who keep the scene alive. I have no idea how much you want to put into fixing the problem, but the only way to fix your problem is flashing the Dreamcast BIOS.
Modification 101:
http://www.youtube.com/watch?v=v7v8cEU1I50
The Dreamcast is basically a computer; with the right programming you can do anything; and having a Dreamcast Keyboard is nice.
Other links you should check out...
DreamChip and 4 in 1 Connector
Another Dreamcast Mod Chip
The Ultimate Dreamcast Survival Guide
Sega Dreamcast VGA Mod
Modified Dreamcast BIOS
www.dc-scene.net
Nov 27, 2008 | Sega Dreamcast Console
Dreamcast turned off when there's a disk in it
madarchod band kar de ......from ayush yadav lps lko
Apr 08, 2008 | Sega Dreamcast Console
Dreamcast freezes.
take apart your dreamcast and look at the controller input circuit board, there should be a big resistor on near one of the boards corners, make a note of the coloured bands and buy a new resistor with the same pattern and replace the one already on the board with the new one.
Mar 09, 2008 | Sega Dreamcast Console
Sega Dreamcast console problem
First off, NEVER store a game console on top of a subwoofer. It is like a giant magnet, and electronic devices do not handle magnetics. I don't think i've ever heard of a VGA box, Sega brand or not, killing a console. Millions use aftermarket AV cables and adaptors on all consoles without problem. I think it likely died from being on top of the sub. Relocate it and you should be fine. Running it for a few hours isnt likely either unless you had the vents entirely blocked.
To the guest who's drive isnt spinning, I would say your drive motor has burnt out. This doesn't indicate a defect in Dreamcasts, per se, it just means bad luck or excessive dust which killed it. Either buy a different Dreamcast or see if you can find a drive replacement.
Hope this helps.
Feb 28, 2008 | Sega Dreamcast Console
Date screen
If you unplug you Dreamcast for extended periods of time the battery in your Dreamcast that saves that info will die (its suppose to last a month but over time they will wear out and not last at all). After 1 hour of gameplay (assuming the battery is still working, as Li's wear out) the battery will be fully charged and last a month.
Jan 17, 2008 | Sega Dreamcast Console
Sega Dreamcast screw
The Disc drive has a connector on the bottom that has to mate up with the opposite gender connector on the top of the motherboard. you have to press the Drive down first then put the screws in.
Nov 06, 2007 | Sega Dreamcast Console
Dreamcast Randomly Resetting
this the best solution it work for me
Jun 11, 2007 | Sega Dreamcast Console
Sega Dreamcast Console Logo
295 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
