Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hi, my machine keeps filling up with water when not in use. Today i tried to wash in it and it kept showing TEST on the indicator
  • 51 Answers
The solonoid valve needs to be replaced,
Posted on Feb 03, 2010
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
Washing machine stopping and starting when filling
Sounds like maybe a bad water inlet valve? timer may have isses as well? have u tried running it in hot water only and cold water only cycle? see if one line is bad in ur inlet valve?
Dec 16, 2014 | Washing Machines
We keep getting an error message E1. We have an LG 2120 model
The E1 or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Dec 13, 2014 | LG Dishwashers
I have a F and P GWL11. It seams to not be filling any cold water. If I start a load and have it set to warm, it will fill some water (hot) and then just keep turning the agitator -- no more water will...
Hi just read your posting.Now, have you tried a cold wash selection?Does your machine stop and beep and then show an error code?2 reasons why the machine will not fill with cold water are your water valve is faulty or your control module is faulty.Have you or can you borrow an electrical meter to test the coil of the cold water valve?Please reply with additional information and I am sure I can help you with this problem.Looking forward to your reply.
Sep 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
What does LF mean?
It is a long fill error. It flashes when the machine control board detected no change in the water level or the water level is not reached in a certain period of time during the fill cycle. Water is probably not entering the tub due to the water inlet valve not functioning or water enters the tub but not properly due to clogged fill hose screens.
Press the Pause/Cancel button to clear the error on the display. Remove the fill hoses from the water inlet valve assembly at the back of the machine and check the screens. Clean the screens and replace it if necessary. Make sure that the water supply valve is open and water is present.
Put the machine in standby mode (only the Clothes Clean indicator is on) and activate the Manual Diagnostic Test Mode to check the operation of the water inlet valve.
  1. Select any one button except Power, Stop, and Stop.
  2. Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds
  3. Press the same button when all indicators on the console are illuminated and "88" is displayed on the Estimated Time Remaining display. A single beep sounds and display shows the two digit console ID number for 3 seconds. The displayed ID number will change to "00" and the Add a Garment indicator will flash.
  4. Select Whitest Whites cycle.
  5. Press Start>Wash/Rinse Temp. The water inlet valve should turn on and fill the tub according to the Wash/Rinse Temp selection.
  6. Press Start to turn off the valve.
  7. Press Stop or Power button to exit diagnostic test mode.
Feb 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
Washer overflowed while filling for wash cycle.
A quick test to split up your possible trouble makers:
Let the washing machine fill with water and when the washer is about 1/2 full of water unplug the washers power cord from the wall outlet. If the water keeps flowing into the washing machine with the power cord pulled the fill valve ( where the hot and cold hoses are attached to your washer ) has mechanically stuck open and will have to be replaced. If the water shuts off when you remove it's power cord from the wall outlet, try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good = on to the next trouble makers.
The water level control is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has occurred. The WLC itself could be bad. The WLC uses a hose that the water level pushes air into to tell the WLC what the water level is inside the washing machine...the hose could be pinched, fallen off of the tub spout, has a pin hole, clogged up with calcium or soap curd and the WLC cannot "sense" or "tell" what is happening inside the washer.
Nov 27, 2009 | GE Washing Machines
My GWL11 won't fill correctly or wash!
Hi there you need a new cold valve in the washing machine. :)
Sep 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
