Question about PfaFF Sewing Machines
I have a Pfaff 2058 and can't get the bobbin to load right. The thread has loops in it and is real loose on the bobbin. I have been sewing for years and have never had this problem. I am ready to throw this machine out, it is unusable in this state. HELP I finally got my Janome out and it just hums along. Linda
SOURCE: Janome M100 mini sewing machine
Providing you have checked to make sure the needle is in correctly, if the machine will not pick up the thread then the machine will need retiming.
Posted on Jan 22, 2008
bargainbox
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
talk2ginny
  • 34 Answers
SOURCE: Anna had this problem with her Pfaff 332 sewing machine, I do too
Hi - it is possible that your needle is bent. Insert a new needle and check again - if you have the same problem, your timing is probably off. You could try buying a new bobbin case to see if that solves the problem. If you have had your machine tuned up within the last year or two, I would recommend a tune-up. If you know of a reputable sewing machine repair shop or dealer, the tune up should include correcting the timing and will extend the life of your machine.
Good luck,
Ginny
Posted on Jan 31, 2009
  • 69 Answers
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Posted on Feb 12, 2009
Mimito7
  • 128 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
Posted on Apr 19, 2009
My Pfaff grand quilter 1200 keeps bunching up the top thread on the bottom side of my quilts. I've replace the needle and thread. It won't pick up the bobbin thread. Could this be a timing problem?
Remove the thread from the machine. (Always raise the presser foot and pull the thread up, NEVER down!).
Install a brand new needle.
ALWAYS RAISE the presser foot when threading.
Rethread from the beginning and verify the thread pathway is correct.
Set the upper tension to midway between High & Low numbers--you may need to tweak this for your particular machine, but this is a standard starting point.
Confirm the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly. It helps if you begin sewing with the needle in the uppermost position.
Test on medium weight woven cotton.
If it is still not picking up the bobbin thread, then it most likely is a timing problem. You can search the internet for web sites and videos regarding sewing machine timing or take it for service.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Nov 21, 2016 | PfaFF Sewing Machines
How to adjust the tension disks on my Pfaff sewing machine?
Make sure your bobbin is the right size. If it is too high it won't turn freely. Also, make sure you drop the bobbin in so it rotates clockwise. The tension must adjusted by hanging the bobbin from your hand and bob it up and down gently. It should move about one inch downward once adjusted properly. The hole in your plate should be checked to ensure the center where the thread dispenses is smooth. Use a finger nail file to smoothen if needed. Now, adjust the top tension to four. You may need to adjust just slightly. Just remember when you remove the bobbin assembly to put a drop of oil on the race. (Many forget this). When you rotate the handwheel towards you the bottom thread should come up. If this doesn't happen then you will need to have adjustments made.
Jul 31, 2014 | PfaFF Sewing Machines
Hello! My reliable 1222 has hit a snag. When try to sew, the top thread is not being picked up by the bobbin thread. How can I fix it? Pavla
try changing the needle
clean under the needle plate & in bobbin area for loose threads & lint
try rethreading the machine top & bobbin, make sure to get every thread guide
make sure the bobbin is inserted correctly in the bobbin case
Mar 11, 2012 | PfaFF Sewing Machines
The stiching on my machine is real loose and catches on the underside of the fabric and bunches up, like the tension is real loose but it is set right can you help?
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 24, 2011 | Necchi 4575 Mechanical Sewing Machine
While I was sewing the machine stopped properly threading, so I tried rethreading and checking bobbin tension, but it looks like the needle is just not reaching the bobbin, so it is missing the bobbin...
Have you changed your needle? If so do a visual check on the bobbin case area.
-With the bobbin door open, so you can see the bobbin case, turn the hand wheel towards you and you should see the needle come down and the top thread catch and loop around the bobbin thread and pull both to the top.
-If if is not, it is going to be your hook to needle timing or clearance.
When the needle is on the up movement, the hook should pass right above the eye of the needle.
-Chris
Jun 08, 2010 | PfaFF Sewing Machines
When I try to use the embrodiery unit the thread bunches up on the underside of the material--it is very loose. Any ideas on what is wrong?
The tension on the bobbin (under the deck) needs to be right. When you load the bobbin, try and pull out the thread a little. It should be firm. You should have to pull a bit to get thread out. If not, the tensioner on the bobbin is set wrong or has backed off (Or you loaded the bobbin wrong) Don't use the bypass slot!
There is one screw on the side of the bobbin holder, where the thread is pulled through when you load the bobbin. This screw can be adjusted to control the tension. See pfaff page on bobbins
Apr 21, 2010 | PfaFF Creative 7570
My Pfaff sewing machine has started to loop the top thread underneath. Tried fixing the tension on the bobbin thread as they state in the manual, but the problem still persists. Any suggestions?
If the thread is looping underneath, you're top tension may be too loose or the thread may not be in the take-up lever. If it's looping on top, double check that the thread is in the bobbin tension or that the bobbin tension isn't too loose.
Oct 02, 2009 | PfaFF Creative 7570
Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Apr 24, 2009 | PfaFF Tiptronic 2030
Pfaff Expression 3.0 works great in the shop, but when I get it home the bobbin thread doesn't engage with the needle thread. The needle thread ends up making large irregular loops on the bottom of the...
pfaff expression 2.0 works the same. I spend lots of hours with the thread tension and it don;t give me a good stitch. the needle threed ends up making large irregular loops .
Apr 12, 2009 | White Sewing 1521
Bottom (bobbin thread) makes loops
I don't have the same brand as yours, but on my machine there is a little screw on the bobbin case that you tighten to increase the bobbin tension. If you've got one, turn it 1/8 to 1/4 turn at a time.
Jan 15, 2009 | PfaFF Hobby 4260
Sewing Machines Logo
70 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
