Question about Maytag Neptune FAV6800AW Top Load Washer
2 PROBLEMS: 1. THE WASHER WILL START AND RUN FOR A SHORT WHILE, THEN IT STOPS AND BEEPS AND I WILL GO PUSH THE START (PAUSE) BUTTON AGAIN...IT WILL GO A LITTLE LONGER AND THEN i HAVE TO REPEAT THIS..ABOUT 4-6 TIMES TO GET THROUGH ANY OF THE WASH CYCLES. THEN, I HAVE TO DO AN EXTRA SPIN CYCLE TO GET ALL OF THE WATER OUT OF THE LOAD. 2. THE TOP RIGHT LID LATCH WAS DISABLED A LONG TIME AGO WHEN IT STOPPED WORKING. ONLY THE LEFT LID LATCH WOULD ENGAGE WHEN THE CYCLE STARTED. NOW, WHEN THE MACHINE IS STARTED, THE LID LOCK JUST DOES THIS CONTINUOUS CLICKING NOISE, BUT THE LOCK DOES NOT ENGAGE. THIS MAYTAG NEPTUNE WASHER HAS BEEN A NIGHTMARE FORM THE GET-GO...IT'S ONLY ABOUT 4 YEARS OLD. PLEASE ADVISE. I KNOW THE FIRST PROBLEM WILL REQUIRE PARTS...HOWEVER, IS THERE A WAY TO DISABLE THE LEFT LID LOCK AND THE MACHINE WILL WORK?? NEED HELP..PLEASE.
  • macelam Feb 02, 2010
    OK, DO I JUST NEED TO REPLACE THE LEFT LATCH...AS THE RIGHT ONE HAS BEEN DISABLED FOR A COUPLE OF YEARS. AND, I HAVE ENTERED THE PART NUMBER BUT CANNOT FIND IT ON THE SITE. THESE ARE THE NUMBERS ON THE LATCH ASSEMBLY THAT I REMOVED...
    MCS
    MAYTAG G2902540
    11500-62
    THIS IS THE KINDA BOXY PART THAT MOUNTS UNDER THE TOP...IS PLASTIC AND HAS HAS 6 PRONGS THAT A WIRE PLUGS INTO.
  • macelam Feb 03, 2010
    I need to know the part number to the lid latches. I took the left latch "box" off...enter the model and part number, but the part I need doesn't come up. Thanks
  • 767 Answers
Http://www.repairclinic.com/Appliance-Parts?s=t-FAV6800AW-%3d%3dc226 This should have the parts that you are looking for both hindges and the door latch along with the retainers.
Posted on Feb 03, 2010
  • 534 Answers
I think from what you are describing is the answer to your problem is going to be the replacement of the latch that you say is disable. This is a safety device and if the door opens everso slightly during the wash the machine will shut down. So I would suggest having the latches replaced and see if the problem is not cured.
Hope this helps
Dave
Posted on Feb 02, 2010
  • 11,896 Answers
The lid switch will most likely have to be replaced.
  • Nate Stansfield
    Nate Stansfield Feb 03, 2010
    you can get part number, pics and numbers of any part, diagrams, and option to order parts at partselect.com
    http://www.partselect.com/MultiModels.as...
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
Washer gets to rinse cycle and starts to pump water then stops?
Before hitting any buttons you need to write down the fault code. As soon as it starts beeping take note of which lights are on along the top row. There are 8 lights. Count from the right and tell us which number light is on and which are off. That will tell us the error code and what it means.
May 30, 2017 | Fisher and Paykel GWL11 Top Load Washer
My Kenmore Elite washer model 110.27062600 stopped working. All the front panel lights are flashing on and off for 7 times then pauses and starts blinking again. The machine will not do anything. No...
if this is an oasis model. Try pushing other buttons you should get a touch tone (beep) as a good response. if no sound you seem to have a interface problem. not a main ctrl.
Sep 19, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Rental...no manuel...first time using washer. pushed regular, large, cold, pause resume. When it finished filling with water it beeps 3x than stops for a couple minutes then beeps 3x etc. It is filled...
Your problem is with the pause/resume button. This button allows you to add/remove items before the cycle is complete. If you press this button and there is water in the machine it will beep for a period of time (3 mins) and then empty the machine automatically so you can open the door. After opening the door the cycle can be restarted again by pressing the pause/resume button again.
Nov 07, 2009 | Washing Machines
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Wahing machine
Try pushing the skip button this may reset the prog. These machines will beep to indicate a fault. Dependant on how many times the machine beeps b4 it pauses ie 1 beep then a pause would indicate the machine isn't filling, 2 beeps its not pumping out, 4 beeps doors open. Hope this helps
Nov 30, 2008 | Zanussi FJS1225W Front Load Washer
The wash beeps all the time
To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is started.
Nov 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Maytag Neptune FAV6800AW Top Load Washer Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
