My Screen will not come on unless I turn it on and off ten to twenty times. My monitor is a 19 inch Mdl VA1930WM ViewSonic.
  • 11,361 Answers
You may have bad power supply, inverter circuits, or bad lamps, need to open it up and report back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 03, 2010
Want schematic for viewsonic monitor va1930wm
Hi Marcel, thanks for using FixYa.
While I could not find the precise schematics you were looking for, here are some helpful tips you can use to find them before you go to a repairman to fix your TV.
Do you still have your original box and manual? Some companies include the schematics here or provide you a phone number to call to find them.
Utilize Viewsonic's support page found here.
Email vsparts@viewsonic.com for schematic information. You will likely have to purchase them however.
Some big stores like Best Buy are able to order the schematics from the manufacturer if the customer service representative is unable or unwilling to give you the correct information.
Unless you can find someone who has the schematics (either online or on here), it is likely that you will have to purchase them yourself.
Emailing vsparts@viewsonic.com is probably your best bet to find them.
Hope that helps!
Jan 05, 2012 | ViewSonic VA1930WM LCD Monitor
ViewSonic VA1930wm Screen stays on for about 2 seconds, and then goes off. 1) If no computer is connected you get a "no signal" message which stays for about 1 seconds and then goes off; blue...
Very typical of View Sonic. Sounds like a back backlight or inverter. I would go to www.viewsonic.com and open up a RMA. Most view sonic screens have a 3 year warranty. They will repair at no cost ..(if it is within that period) There is a date code on the back of the screen that will help you validate the above information.
Nov 07, 2010 | ViewSonic VA1930WM LCD Monitor
My 19 inch ViewSonic monitor shows red /voilet
Please check the VGA cable at both ends to make sure there are no bent pins and fit into the socket properly at both ends. Also try this monitor with other PC also since it can be in the video card.
Apr 25, 2010 | ViewSonic VX912 19" LCD Monitor
I ve bought viewsonic 19" va1913wm. i inserted the pin but there is no sound from monitor speakers. help please....
We need to verify if it is the monitor or the PC. Try feeding it with MP3 or audio source first to see if you do get the sound, try setting the volume 1/3 way up first. You are using mini stereo phone jack, right?
Please post back so we can guide you further.
Apr 13, 2010 | ViewSonic VA1930WM LCD Monitor
I have a viewsonic va1930wm. it turns off and on. how do i fix this
Is ur graphic card ok?
Have ur screen tested on another PC to determine exact cause...
Feb 06, 2010 | ViewSonic VA1930WM LCD Monitor
Screen turns on briefly then off, a few seconds later on again, then off. It is mostly dark, but turns on for about a second, then off.
Open it up and look for bad caps with bulging tops, also check for 12v for the backlight inverter circuits. See some example of failed Viewsonic monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 12, 2010 | ViewSonic VA1930WM LCD Monitor
ViewSonic Main menu pop up all the time
Replace the button switch. That switch may worn out, Kindly give feedback after problem get solved
Aug 23, 2009 | ViewSonic VA1930WM LCD Monitor
Viewsonic VA1930WM
You need to isolate the problem to see if there's a problem with the monitor or with the sound card of the computer.
To isolate this problem, please try the steps below:
1. Make sure that the monitor is properly connected to the computer.
2. Check the volume of the monitor and the volume properties of the computer.
3. Try to connect your monitor into a known working computer.
Apr 15, 2009 | ViewSonic VA1930WM LCD Monitor
View sonic va1930wm 19' wide screen
hi there, first boot go to safe mode and choose the lowest resolution, restarting the unit and you can adjust the resolution to the high stage one by one. ty
Jan 09, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
David Payne
David Payne
