Question about Xerox Phaser 8560DN Printer
Add yellow ink appears cannot print.
"Add yellow ink" appears on menu and I cannot print.
  • 240 Answers
The printer will not print if it thinks it may completely run out of ink. Running this machine dry could damage the $1500 print head, never mind the cost of labor to do the job. I have the multi-function version of that machine and our print head was bad out of the box. Even if you are only printing black, the machine will purge ink slowly through the print head of each color to avoid a clog and other costly repair.
Your solution is to add yellow ink and always use original Xerox ink, compatible ink can damage the print head as well and Xerox will not repair it. You will have to go after the vendor that sold it to you, which is very difficult.
Posted on Feb 03, 2010
The yellow ink is not functioning, when i print the yellow color does does not appear, what shall i do?
go to your menu ans you will have a choice of a few things one will be clean the head and one of them will say unclog ink cartriges or sumthin close to that. good luck
Jun 20, 2016 | Epson L200 Original Continuous Ink Tank...
I can not get Yellow to print
Personally I would just take out the print head and flush it through with warm water. When it is clean, add all the inks and run it through the clean print heads utility, until the test sheet looks correct. Another point, do not ever switch off the printer, as it cannot periodically clean itself. If it cannot clean itself the print heads can dry up and become clogged.
Apr 25, 2014 | Canon BubbleJet i9950 InkJet Photo Printer
My canon mg5220 printer is not printing anything. It just says error when the pop screen pops up. It doesn't give me an error code.
Hi Savannah,
Try deleting the printer entry completely and add it from scratch.
Here's how:
  • Go to System Preferences
  • Print & Fax.
  • Select the printer you want to remove,
  • Click the - (minus) button at the bottom of the panel.
  • Reboot the system.
  • Run Software Update to check for the latest third-party printer software and updates.
  • Make sure the printer is powered on, has paper, and doesn't have any issues such as a paper jam or low ink.
  • Adding, managing, or removing print queues may require an administrator account name and password--make sure you know one for your Mac.
How to add a printer
To add a USB printer
Mac OS X v10.6 comes with software for many third-party printers, so simply connect a USB printer and the print queue will be automatically created. If you do not see your printer in the "Printer:" pop-up menu after connecting it, go to the "To add a printer via the Print & Fax preference pane" section below.
To add "Nearby Printers"
With Mac OS X v10.6 you can quickly add a "Nearby Printer"--a nearby printer is a printer connected to the USB port on a Time Capsule or AirPort base station, a network capable printer that supports Bonjour, or a printer being shared by another Mac. Snow Leopard uses Bonjour technology to find nearby printers.
To add a Nearby Printer, all you have to do is select the Nearby printer you want from the "Printer:" pop-up menu:
Snow Leopard will automatically create the Print Queue.
To add a printer via the Print & Fax preferences pane
Control-click the System Preferences icon in your Dock and choose "Print & Fax" from the Dock menu. If the Print & Fax lock icon appears locked, click the lock icon and enter an administrator name and password when prompted. Click the + (plus) icon below the Printers pane on the left to open the Add Printer application.
From the Add Printer toolbar you have these default tools:
  1. Default - Used to get a list of all printers that your Mac can see via USB, Bonjour, and so forth. Tip: If you have a long list of printers, use the search field to find the printer you are looking for. Just click the printer in the list that you would like to add and Snow Leopard will add the printer driver for you.
    • Mac OS X v10.6 comes with software for many third-party printers. If an additional or updated printer software is available, Software Update will offer it to you. If you do not see your printer listed in the "Print Using:" pop-up menu or a Generic printer driver is selected, then the printing software may not be available from Apple. For more information about supported printers see this article. You can also visit the printer vendor's website for printer software, or contact them for technical support.
    • Once the driver is set, click the "Add" button to create your Print Queue.
  2. Fax - Used to add a queue for the Fax device connected to your Mac.
  3. IP - Used to add your printer network printers that don't use Bonjour or are on a different network subnet from your computer. Printers that support the Internet Printing Protocol (IPP), Line Printer Daemon (LPD), and HP Jetdirect (Socket) can be added in this manner. See your printer's manual or support documentation for information about how to setup the printer to use an IP-based printing protocol.
  4. Windows- Used to add your printer being shared via the Windows printer sharing protocol (CIFS). Tip: See Mac 101: File Sharing for details about how to add your Mac to a Windows Workgroup. This is often needed to see Windows printer shares.
Note: Any applications that are open before you add a printer will need to be quit and re-opened, in order to see all the features of the new printer.
Feb 19, 2014 | Canon Pixma Mg5220 Inkjet Multifunction...
My printer is turning on, but not printing, its telling me that the printer is offline and that there is a media jam. I have an I Mac please help.
Here's a quick summary of what's new for printing in Snow Leopard (read below for more details):
  • Apple's Software Update will automatically provide you with third-party printer software and updates.
  • "Nearby Printers" is a list of available printers that will appear right inside your printer dialog box. Adding a nearby printer is just a selection away.
  • You can simply connect a USB printer and the print queue will be automatically created.
  • You can create a PDF document from any application and have an automated workflow process it.
Before you connect your printer
  • If you are upgrading from Mac OS X v10.5, see "Upgrading Print Queues..." in the additional information section below.
With Mac OS X v10.6 you can quickly add a "Nearby Printer"--a nearby printer is a printer connected to the USB port on an Apple Time Capsule or AirPort base station, a network capable printer that supports Bonjour, or a printer being shared by another Mac. Snow Leopard uses Bonjour technology to find nearby printers.
nearby%20printer.jpg Snow Leopard will automatically create the Print Queue.
Note: Mac OS X v10.6 comes with software for many third-party printers. If an additional or updated printer software is available, Software Update will offer it to you. For more information about supported printers see this article. You can also visit the printer vendor's website for printer software, or contact them for technical support.
blank print _ fax system preference.png From the Add Printer toolbar you have these default tools:
Dec 11, 2010 | HP Hewlett Packard LaserJet P1005 Printer
Flashing yellow light. paper does not load.
It's trying to say that the page you are trying to print is too complex.If you press the button to cintinue it may print out part of the page. Check the printer driver for print resolution settings. Change it to 300dpi and try again. Or, you could always add some extra memory to the printer. If you decide to add extra memeory, don't forget to tell the print driver it has more memory
Oct 14, 2009 | HP LaserJet 5L Printer
My blue color does not print
Remove the Color and Black Cartridge >
Remove the Printhead by pushing the grey latch with your thumb going upwards
close the access door without nothing on it
unplug your power cord > re connect after 10 seconds
reinsert Printhead and Ink cartridges
goodluck....
Sep 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How to ink Casio FR 1211 Printing Calculator
I have a Casio FR-1211 Printing Calculator and I have the same problem. I removed the roller and tried inking the roller with "Sanford's Roll-On Stamp Pad Inker". It works beautifully ! I don't know how long it will last, but for now the print is dark and clear.
John
Apr 05, 2009 | Casio Office Equipment & Supplies
I need to install HP deskjet 6940 on my Powerbook G4. I am operating on MAX OSX 10.4.6
If your printer does not appear in the Printer pop-up menu, find and install the appropriate driver. Check any CD-ROM discs included with the printer, or the website of your printer's manufacturer. Only users with an administrator account can install software.
Tip: You can also open the Printer List window from Printer Center (Mac OS X 10.2.8 or earlier) or the Printer Setup Utility (Mac OS X 10.3 Panther, or later).
Check the Printer menu again after installing the software. If the printer does not appear, you may need to do this:
  1. Make sure the printer is connected to your computer, plugged in, and turned on.
  2. For Mac OS X 10.2.8 or earlier, from the Printer menu in the print dialog choose Edit Printer List. The Printer List window appears.
  3. For Mac OS X 10.3 or later, choose Show Printer List from the View menu. The Printer List window appears.
  4. Click the Add Printer button.
  5. Choose USB from the first pop-up menu.
  6. Select your printer from the list.
  7. Click Add.
  8. Close the Printer List window.
How to add a network printer (AppleTalk or LPR)
Adding an AppleTalk or LPR network printer is very similar to adding a USB printer. In Step 4 above, you would choose AppleTalk or "LPR Printers using IP" from the pop-up menu. From there, the setup differs slightly.
AppleTalk printer
  • AppleTalk must be enabled in Network preferences.
  • If your network uses AppleTalk zones, choose one from a second pop-up menu that appears.
  • Make sure to avoid potential issues with AppleTalk multi-homing.
LPR printer
  • You must enter the printer's IP address or DNS name.
  • If you're printing to a queue, deselect the checkbox for "Use Default Queue on Server", then type the queue's name. If not, leave the checkbox selected.
  • You can select your printer from the Printer Model menu or leave it at Generic. In essence, are selecting a PPD file.
Question mark appears, or trouble finding a printer?
If you can't find the printer you want to add in the list of connection methods, make sure you're choosing the right connection type for your printer. Some printers may use custom input-output modules, such as "Epson AppleTalk". You may need to select one of these custom options in order to add your printer. If there's a question mark on the printer's icon, or Print Center or Print Setup Utility lists it as unsupported, check for an updated software version at the manufacturer's website, or the Mac OS X downloads page.
Tip for software installation
Your printer may appear in the printer list before manufacturer-required software is installed. If you have such a printer, remove the printer from your printer list before installing the software. Add the printer back to the list after you've installed the software.
Printers whose drivers or PPDs are included with Mac OS X
Additional Information See these articles for lists of printer drivers and PPD files included with Mac OS X:
25587: Mac OS X 10.3: Included PPDs for PostScript Printers
25588: Mac OS X 10.3: Raster (Inkjet) Printer Drivers Included
107001: Mac OS X 10.2: Included Ink Jet Printer Drivers
107002: Mac OS X 10.2: Included PPDs and Use of PostScript Printers
106490: Mac OS X 10.1: Many Third-Party Ink Jet Printer Drivers Are Included
106516: Mac OS X 10.1: Includes PPDs for Many PostScript Printers
Jul 10, 2008 | HP Office Equipment & Supplies
Epson printer and windows vista wont talk to each other
Windows Vista should automatically detect and install devices attached to the computer. Simply connect the printer to your computer and power it on.
If the driver does not automatically install, you can follow the steps below to install a resident driver which is part of Windows Vista. The resident driver installation should only be used if the printer is not detected and installed.
1. Click on START, CONTROL PANEL and PRINTERS.
2. Click the ADD PRINTER button. If you do not see ADD PRINTER, right-click in the PRINTERS window and select ADD PRINTER from the menu.
3. The ADD PRINTER wizard window will appear select Add a Local Printer.
4. Select the port the printer is connected to from the drop down window beside Use an Existing Port, click NEXT.
5. In the next window select EPSON under Manufacturers and your printer model under Printers.
6. In the Type a Printer Name window, Set as Default is automatically selected. If you, have another printer that will be the default simply remove the check and click NEXT to install the driver.
7. Ensure the printer is directly connected to the computer and that the printer is ready to print. Click PRINT TEST PAGE to test the printer.
8. Once the test page has printed, click FINISH to exit the wizard.
*NOTE:
-Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The RED error light will flash when the printer is low on ink and go solid when it is out.
-If the ink levels do not appear, click GET INK LEVELS from the MAIN tab of the printer driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
Jun 11, 2008 | Epson Stylus Photo R300 InkJet Printer
Xerox Phaser 8560DN Printer Logo
240 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
