Question about Toshiba 51H83 51" Rear Projection HDTV-Ready Television
Hi i have a convergence problem bought tv 5 years ago 2 techs have looked at it and have replaced convergence sensor unit and digital convergence unit but now tech says i need a convergence board and not sure if that will fix problem what else could it be if this last one does not work
  • Toshiba Master
  • 3,459 Answers
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more ehi i have a convergence problem bought tv 5 years - bb0cf99.png find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Mar 25, 2010
My tv is a magnavox and we bought it about 3 years ago and it is now showing like a double picture the color is hazy and pinkish looking the model is 51MP392H/17
The problem of your unit is the convergence. Try to adjust it using the original remote control in the setting menu, then goto the convergence section adjust the red and blue convergence, you should move red and blue UP, DOWN and LEFT or RIGHT, if you cannot move them far enough the convergence IC is defective, replacing this IC will restore the original setting of your tv. This convergence IC is attach to a large aluminum plate it is the heat sink this IC has a marking of STK-#### followed by numbers, remember be careful when replacing this IC you may accidentally tampered or damage the PCB and cause much damage to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards. Try to check this link for the convergence http://www.google.com.ph/search?q=convergence+ic&hl=tl&sa=X&tbm=isch&prmd=ivns&bav=on.2,or.r_gc.r_pw.&biw=798&bih=472&ech=1&psi=JZdtTvDCPIe4iAe72sTABA.1315804977740.3&emsg=NCSR&noj=1&ei=MpdtTpa4OKKSiQfBpcjGBA
Sep 12, 2011 | Philips Magnavox 51MP392H Rear Projection...
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Thanks.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
Green & Blue Ghosting Convergance problem
Odds are real good that the cooling fluid in the green and blue picture tube assemblies has become contaminated. You can tell by looking down into the lenses with a flash light. Funny thing is the red never gets contaminated because whatever organism is causing the problem can't survive in red light. BTW this may still not solve all of your convergence problems but when the colors are so badly diffused the convergence sensors for flash focus can't lock onto the beam landing.
Jun 01, 2009 | Samsung HCL473W 47" Rear Projection...
Picture flickers in and out rapidly,gets blurry for about 5sec then looks like new for about 5sec then back again
Did you replaced 2 IC convergence as well or just 2 resitors 3.9 ohms ? if you did replaced 2 IC then you might have probelm in convergence drive it is1 of the PCB mount vertical on the left side from the rear view under part BP95-00415C you need to readjust the convergence by using your remote control just follow in the servive manual
Nov 22, 2008 | Samsung HC-P4752W 47" Rear Projection...
Green double image
you need to replace both convergence ICs they are both STK392-110 and you can get replacement ICs at the following link and they provide free step by step instructions with pictures so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | JVC AV-65WP74 Rear Projection Television
I have a 65 inch toshiba projection tv about 5 years old that has a problem with the picture. the red blue and green lines are not aligning, giving it a 3d looking image. i was just wondering what it might...
Greetings fireftr2001,
You may need to perform convergence on the unit. This is something that needs to be done periodically and especially if you have recently moved the unit. You can normally find the convergence option in your menu system.
Thanks,
Dorothy
Go Ahead. Use Us.
Jun 24, 2008 | Televison & Video
Resetting convergence daily on Toshiba 43h70
Hi Mark, tough call without putting a scope to the circuit, either the convergence IC`s are going bad, signal from DCU is going bad (digital convergence unit), or possibly bad solder somewhere in the convergence circuit, I`m afraid your going to need a tv tech for that problem, BMW Rider
Jan 02, 2008 | Toshiba 43H70 43" Rear Projection...
How to do convergence on a PT-53WX53
Hello Yann,
Please be advised that doing the convergence in service mode is a very complicated process. This could mess up your TV even more. The best TV tech out there finds doing convergence a Headache. Doing convergence is part of the repair that most TV tech fears. Email me if you still want it. I will not post here for the general public.
Best regards
Mervin Guy
Oct 15, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Pioneer rear projection 51inch tv
moving big screens around may throw off the convergence, look to see if you have red,blue or green or all.. ghosts or edges in the picture. you will need a tech manual ..not owners manual to fix it, I would call a local tech and hear what he thinks for just a service charge. good luck
Sep 01, 2007 | Televison & Video
Toshiba 51H83 51" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
