Question about 2wire (1000-000057-000) Modem
Wireless radio adapter
Turning on wireless radio adapter for a compaq r3000 notebook, and fn f2 does'nt work.
  • lissycasey Feb 19, 2008
    it is not fn & f2 to get it to work. must be something else for this laptop, fn f5 doesn't work either. any further suggestion?
    sorry had tried this already there is no such thing on my laptop. what else could it be?
    Novelist:
  • 142 Answers
If ur sure that that it is the fn and f2 that u have to press simultaneously to turn on wireless capabilty. Make sure u press it long enough
Right click on wireless network connection item in ur system bar and goto view available wireless connection and check what message is displayed there
If it still says that " No wireless network were found , make sure wireless switch is on "
Contact COMPAQ
If ur not sure whether it FN F2 , then try to FN & F5 or FN & F2
Posted on Feb 19, 2008
Wireless capability turned off
Wireless capability will turn on after Press Function Key (fn - Red) + F2. if wireless adapter is turn off you can turn it on at Network and searing center on control panel > Change adapter setting > Double click on disabled wireless adapter.
Hope it Works. Enjoy.
Nov 03, 2012 | Dell Inspiron 1545 Notebook
HOW DO I TURN ON THE WIRELESS CONNECTION AS WHEN
Try pressing at the same time the Fn + F2 key to turn on wireless radio.
Mar 30, 2010 | HP Compaq nc6000 Notebook
Acer 4720,when switched on wifi button,the light for wifi is flash and the funcion is worked.But switched off wifi button,the light is still on.How can i switch off the light?
For Windows Based Computers
If the drivers for the wireless adapter contain a setting to toggle wireless radio, it can be located using the
following path: Start > Settings > Control Panel > Right click Wireless Network Connection Icon > Properties >
Configure > Advanced tab
Here you will find a textbox with a list of selectable properties that are populated by the device driver. Once you
select a property there will be a value field with a dropdown box containing configuration options that apply to that
specific property. The name of the wireless radio property may vary because the listed properties are dependent on
each specific device driver. It should be fairly intuitive to determine the correct property if you simply have the user
read all the listed properties to you.
Many laptop manufacturers will place a physical switch on the outside casing of the laptop, so that the user can
easily toggle wireless radio. Sometimes these switches get accidentally turned off, or intentionally turned off and the
end user forgets to switch it back. The best practice in these situations is to ask the user to look for a physical switch
on the case of the laptop, possibly with a symbol of a radio tower next to it. After turning the wireless switch on, the
user will probably need to refresh their network list.
Laptops built by certain manufacturers may have a specific keystroke set up to toggle wireless radio.
Below are some examples of wireless radio software and hardware toggles that we have been able to
document:
Acer (General) - FN,F5
ASUS (General) -The F5R has a toggle switch to turn on and off the WIFI; it is located on the left side of the
notebook
Dell (General) - FN,F2 or FN,F8 or FN,F12
Dell d630 (D6xx?) latitude: toggle switch on the left side towards the front by the PCMCIA slots and headphone
jack
E-machine (General) - FN,F2
Fujitsu (General) - FN,F10
HP/Compaq (General Older models) - Button on upper left on keyboard deck
HP/Compaq (General Newer models) - Button on lower left below keyboard
IBM thinkpad (General) - Most have software switch or button on left hand side.
IBM thinkpad (model not further identified) with wireless switch on front edge of case.
Sony Vaio (General) - switch on front left
Toshiba (General) - FN,F5 or FN,F8 or switch
Toshiba Satelite has a physycal switch on front of case. FN+F8 shows wether wireless communications is
enabled or disabled.
For MAC/Apple Based Computers
MAC OS X 10.4.x (Tiger & Earlier)
Open MAc Hard Drive > Applications > Utilities folder > Set the Configure pull-down to Airport.
Make sure the "Airport Power:" says On. (This is the status or your Mac's Airport card.)
If not, click "Turn Airport On" button.
MAC OS X 10.5.x (Leopard)
Click on the: Apple Icon > System Preferences > Network > Airport > Airport Power - On/Off
Jan 20, 2010 | Acer Aspire 4720 Notebook
Can't enable Dell Wireless 1390 WLAN Mini-Card
I had the exact same problem and went through the same steps that he did. It was only when I searched for a physical wireless switch (on the left side of my Dell D630) that the problem was solved. I didn't even know it was there and must have inadvertently knocked into the off position.
Dec 12, 2009 | Dell Inspiron 6400 Notebook
Cant find my wireless button
it must a combination of fn and windows key
Nov 03, 2008 | Compaq Presario R3000 Notebook
Wireless radio adapter or card
Try:
G1S - This laptop supports multimodal switching of the wireless and Blue Tooth radios via the key command Fn+F2:
1st press: On both Blue Tooth & WiFi
2nd press: Off Blue Tooth / On WiFi
3rd press: On Blue Tooth / Off WiFi
4th press: Off both Blue Tooth & WiFi
Sep 14, 2008 | ASUS (wifibralinkuay) 802.11b Wireless...
Do i need a network adapter to plug in to a new compaq f765 laptop to enable a wireless internet connection?
According to the specification of your laptop it has built in wireless adapter so there is no need to install or purchase one. If your having problems getting a wireless signal from your router check if the wireless button/radio/switch is enabled/turned on. Usually its on the left hand side near the bluetooth switch or Fn+F2 will do the trick.
Aug 05, 2008 | Computers & Internet
I have a notebook model # MA6 NX560X Want to take it to Aruba. What do I need? ISit WIFI ready? I can buy a card down ther for access. Thanks Barbara Rant BCR9541@aol.com
According to the spec sheet from gateway it already has a intel-pro wireless adapter installed to verify go to start,right click on my computer, left click on properties,left click on hardware, left click on device manager, left click on the + plus sign by network adapters and if the wireless network adapter is listed it is installed.
Q: How do I turn my notebook's wireless on and off?A: To turn the wireless radio on or off, press FN+F2. The wireless status indicator turns on or off.
Apr 05, 2008 | Computers & Internet
2wire (1000-000057-000) Modem Logo
315 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
