Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My garage door opens/shuts sporadically when using the Home Link transceiver on my car and does the same thing on my wifes car indicating that the problem is with the opener motor.
    Top Expert:
  • Sears Master
  • 76,630 Answers
I would replace the reciever if the door doesn't respond at times, if it shuts down once it starts moving you need a new motor, this repair would most likely exceed the cost of the whole opener unit if done by a professional service repair person, if u do it is much cheaper.
Posted on Feb 02, 2010
Craftsman garage door opener. Why won't it pair with remotes?
If the remotes operate with no problem it's not the board. once you've paired the remote to your home link in the car, you have to go back and hit the learn button on the motor housing unit then go back and hit the home link button you just paired. Keep in mind when you hit the home link button, you should with a firm 3 second push. If that doesn't work it's one of two things. First is all three buttons may have been programmed on the visor not allowing you to reprogram. You would have to wipe out the programming by holding the first and last buttons simultaneously until the light flashes rapidly. Then start over. Secondly it could be the radio frequency. Depending upon the year of the vehicle you have and the opener you have there's a difference in the megahertz. I hope it's as easy as my first suggestion. GL!
Jan 23, 2016 | Building Materials
We just installed a MyQ on our garage door, and the first time my wife used it (she tried it about 2 blocks away from home), it didn't open and she said she got a message that it wouldn&#3
Garage door openers can sometimes be triggered by (illegally) boosted CB or ham radios.
A passing vehicle pumping out high power might open the door (an acquaintance did this years ago annoying the neighborhood) and the 30 minute delay may serve to protect against unwanted opening of the door.
Sep 19, 2014 | Chamberlain 940EV Wireless Keyapd MyQ,...
How do i program my garage door to open with my car garage opener button
Push and hold the two outer buttons until the LED flashes fast Approx (15 seconds) then hold your garage opener up to the mirror or visor and push and hold any button 3 or 4 seconds on the opener Now the Home Link is programed. With the car safely away from the closing garage door find and push the garage openers red programming button (on the motor assembly somewhere that gives you about 30 seconds to push your cars home link button so the garage opener learns the button you want to use for that door the other two buttons can be programed for other doors or house light controler gate opener in the same manner
Jan 03, 2012 | 2004 Nissan Maxima
How do you connect the home link garage control to your car & garage?
Things You'll Need
  • Remote garage door opener
Suggest Edits
    • 1
      Turn your Chrysler vehicle off and press and hold the two outside buttons on your onboard opener system. Release the buttons once the red indicator light begins flashing. This will erase any previous codes programmed to your system.
    • 2
      Hold your garage door opener remote two inches away from the onboard system.
    • 3
      Press and hold the button you wish to program on your onboard system and the open button on your remote simultaneously. Release the buttons once the indicator light on the onboard system begins flashing.
    • 4
      Press the training button on your Chrysler's system until the light glows solid. If it does not glow solid, continue to the following steps.
    • 5
      Press the "learn" button on your garage door remote, located near the antenna wire on the back or side of the system, and return to your vehicle.
    • 6
      Press the training button on your on board system, hold it for two seconds and release. Repeat the press/hold/release step two more times and your remote will be programmed and ready for use.
Dec 10, 2011 | 2002 Chrysler Town & Country
I have a Craftsman Garage Door opener model # 139.53674SRT2. It is sporadically going up and down to varying degrees. The LED indicator on the back is constantly blinking. If I trip the motion sensor it...
Rapid blinking of that LED indicates it is receiving a signal. Make sure you don't have an old remote somewhere that is sending a signal and that your other remotes do not have a stuck switch. Remove the batteries and check that light.
Jul 17, 2011 | Sears Craftsman LiftMaster Chamberlain...
The cl;icker works to open/shut door inside garage but not out side...signal weak...new batteries...whaT TO DO
Some things to check.
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
Nov 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I setup the homelink feature in my 2000 chevy impala with my garage opener?
First clear it pushing the 2 outer buttons for about 20 seconds till the lite blinks.
Then here is the weird part take the old remote that you use for your garage door opener and hold it next to the home link in the car.
Push the button on your old remote then the button on the home link. the home link will flash slow then quickly (about 10 sec).
Now go push the learn button on the main door unit then back to the car and push the home link again for 2 seconds.
Oct 22, 2009 | Chevrolet Impala Cars & Trucks
Having trouble setting garage door opener to my 2004 trailblazer
1. Position vehicle within 10 feet of garage door- engine off and battery on.
2. Press/hold 2 outside buttons of Homelink transceiver until red indicator starts flashing rapidly, then release button. This should take about 20 seconds. This erases any previously learned codes.
3. Press/hold remote control and press/hold button of Homelink transceiver simultaneously. Slowly move remote control from 5" away to 1" away from Homelink transceiver. Release both buttons after red indicator starts blinking rapidly. This should take about 5 seconds. I discovered that the Homelink in my TL is a bit faulty because it took much longer to accomplish this than when programming the Homelink in my MDX. My TL's Homelink may "unlearn" it's code in the future and the needed proximity of the TL to the garage door may be much closer than desired until I get the Homelink fixed.
4. Press training button on garage door opener unit until the indicator lights illuminates- this should be immediate.
5. Within 30 seconds press/hold the Homelink button for 2-3 seconds until the red indicator starts flashing rapidly. Repeat a second time. It should now be programmed. Check it by pressing the programmed button on the Homelink receiver.
6. When programming more than 1 garage door opener unit, disconnect power from unit before programming more units. By not doing this the programmed unit could conflict with the unprogrammed units commands.
Problems:
1. The Battery in the garage door remote may be too weak to program Homelink. However, the battery may be strong enough to operate the garage door. One of my remote controls had a weak battery- my system was installed today, fresh out of the box. I had to use the second remote control for the programming of Homelink on my 2 vehicles.
2. Antenna on the garage door opener unit must be hanging down, fully extended.
source:chalkstar100 (fixya mate)
Thanks for using Fixya
Have a nice day!
Mar 07, 2009 | 2004 Chevrolet TrailBlazer
1-800-355-3515
www.homelink.com
Problems:
Oct 11, 2008 | 2003 Acura MDX
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
21 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
