Question about Canon MultiPASS F80 All-In-One InkJet Printer
While printing i have black lines down the edges of my copies
  • 26 Answers
SOURCE: Black Line printing on copies
Just clean the glass top of the scanner and the slit of glass on the left hand side of the scanner.
Posted on May 20, 2007
SOURCE: Wide black line down middle of paper
I have same problem, with new ink cartridge, also tried cleaning the print head, no luck.
Posted on Jan 15, 2008
SOURCE: Black Line Down Center of Page
I had the same problem. I cleaned the strip above the glass and this fixed the problem. Hope it helps!
Posted on Mar 14, 2008
I have the same problem and have tried all the fixes suggested but to no avail. In fact, if anything, the line on the bottom is getting wider and wetter. I'm at wits end with this thing. Any new info from anyone?
Posted on Mar 24, 2008
Evilsmith
  • 26 Answers
SOURCE: ink bleed dark line down
click Start and then Printers And Faxes.
Right-click your printer and then Printing Preferences.
Click the Maintenance tab to view what your printer can do from a software perspective.
Click "CLean Print Cartridge" to start it and let the cleaning process run its course.
You may have to do this a number of times to get the print head clean.
Posted on May 07, 2008
Why do I get a thick black line down side of page when copying, but not when I print
Not sure, but one possibility is that your paper you are copying is not all the way to the edge of the copier. If there is a crack along the edge where light from the room can get in it will show up black in those areas. You will see the same effect if you leave the top of the copier off and try to copy something. There could also be something wrong with the scanner arm preventing it from moving all the way to the edge of the window.
Mar 12, 2015 | Canon Pixma MX452
Thick lines
Check the fusing unit and or transfer belt. Does it print OK not copy! Print Ok means internal OK then check the scanner section
Nov 11, 2013 | Minolta MF1600E Plain Paper Laser Fax
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
Black line along the right side near the center when copying ONLY
first, the line are in all printing pages, or only when you make copies?,
if the line are in all printing pages, maybe your fuser has damage the fuser film sleeve,(aprox, 10-20 dlls), if only this line are when you make copies, maybe the glass in the scanner are dirty(clean and try).
i expect this solution your problem
Aug 05, 2009 | HP LaserJet 3050 All-In-One Printer
SOLID BLACK LINE FROM LEAD EDGE TO TRAIL EDGE
"dk" means the the life black drum is over. You need to replaced the drum and blade. Or you can replaced the whole drum cartridge. The line that you are getting from one of the blades, more likely from the black drum. Pull out all the drum check if there is toner on the drums.
Mar 20, 2009 | Sharp AR-BC320 All-In-One Led Printer
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
Thin black line on Xerox 4011 laser printer
Does the same thing occur with a different document.. Because it is not repetative, it leads me to believe the line is being drawn at the direction of the software. Try printing a test page, and see if the line appears. If not the issue is from within the word processsing software. It almost sounds like a legal template for a pleading..
Nov 21, 2008 | Computers & Internet
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
Canon MultiPASS F80 All-In-One InkJet Printer Logo
95 people viewed this question
old marine
old marine
