Question about Sta Rite Maxi Therm 400k Btu Propane Heater
Not keeping the pool heated. it heats it up but then cannot hold the heat. What is the warranty on these units?
  • Dale Cobb May 11, 2010
    2 years, does the heater continue running or does it shut off completely and quit heating. There are many reasons why it would have trouble keeping up.
  • 366 Answers
Warranty is two years. if it's still in warranty, pentair should send a tech out to repair it.
Posted on Feb 09, 2010
Waterco spa pump. In demand mode, why won't pump switch off?
Spa pumps are not only for Heat. The pup also circulates water thru the filter and provides optimal chemical dispersion. Recommend you call the customer service see how your warranty has been holding up and go from there.
Nov 21, 2015 | Waterco Pool & Spa
Need to replace heat sensor, where is it located on the unit?
there should be 3 heat sensors on the unit. Incoming water to decide if it needs heat, outgoing water, and a sensor on the burner(flame). the in and out sensor should be behind a panel near the inlet and outlet pipes. The burner sensor is more tricky usually near the igniter or below the heat exchanger inside the unit.
Jun 18, 2015 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a Hayward HP50HA pool heat pump. The unit
Good Day, I would recommend calling our tech line at 908-355-7995 and go to the prompt for Heat pumps. Have the date of installation and serial number when you call.
Sep 02, 2014 | Pool & Spa
I have a Pentair Mastertemp 400. It worked fine for 3 years until the temp sensor went out and both (internal and external) were replaced about a year ago. It then worked fine for about another 7-8...
You might have a much bigger issue than the temp sensor. When the heater is running hold the "pool" or the "spa" button for 12 seconds. This will show the exhaust temp, if the temp is rising above 375 degrees with in 1-2 mins then your not getting the heat out of the heat exchanger.
One other thing to check would be an external by-pass. If you have an external by-pass make sure the by-pass is set correctly. Opened or closed to much can cause the problem your having.
Mar 04, 2017 | Pentair MasterTemp 400000 BTU Pool and Spa...
What is the meaning of BTU?
British thermal unit: a unit of heat equal to the amount of heat required to raise one pound of water one degree Fahrenheit at one atmosphere pressure; equivalent to 251.997 calories. The amount of heat needed to raise 1 pound of water 1 degree F (equal to 252 calories).
(British thermal unit) Describes the heat value of fuel for appliances - the higher the BTU, the more heat available for cooking.
A Btu is equivalent to 252 calories and serves as the base unit for measuring the heat content of a fuel source.
-The Ugly Pool Guy www.wefixuglypools.com
Dec 09, 2010 | Pentair Minimax Ch 400,000 Btu Propane...
I want to heat the pool from the spa. I have the spa and spa heat on but the spillover wont come on when I have the spa on. When I turn the spa off the heat goes off. What do I do
When your system is put into Spa mode the system draws water from the spa only to the heater to keep the spa at temp, this is why the overflow doesn't work and why you can not heat the pool in spa mode. If you could heat the pool this way it would take a very long time, since the spa is smaller then the pool. You can heat the pool and spa at the same time in pool mode. Water is pulled from the pool, heated and goes back into the pool and spa.
Mar 27, 2010 | Jandy AQUALINK RS TELELINK KIT
Heating pool very slow outside temp is 70 30000 gal pool . Ran 10 hrs went from 81 to only 83 131000 btu unit !
With an outside temp of 70 your probally getting down to the 40's at night wich is to cool to get much heat rise and with 30,000 gal this will take a few days to raise the temp much also you should have a cover for a pool that big. If you have any wind the pool will loose 90 persent of it's heat from the surface. Once it is warm the heat pump will keep it warm for cheap if it is covered and you run it in the day.
Oct 18, 2009 | Jandy Ae3000t 131,000 Btu Heat Pump
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Pool heat pump won't keep running
It is likely that you have a low refrigerant condition and require an HVAC person to service the unit. It's not unusual to need "freon" every so often. Call the repair man...
Mar 03, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
Sta Rite Maxi Therm 400k Btu Propane Heater  Logo
54 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
