Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printer always indicate E5 and say that cartridges are not conform the printer altough they are original
I've got the same proble. It seems that there's a possibility to reset the cartiges, but works only on windows and I've got a mac. Maybe it will help you.
1. Download "mptool" software, it's the software you'll use to reset
2. Connect the usb cable to the printer and to the computer
3. Disconnect the printer's power cable from wall jack
4. Press the start button on the printer an KEEP IT PRESSED
5. While keeping it pressed reconect the power jack
6. Still keeping the power button pressed when it becomes green, (don't release it) press the reset button (the first button from the left of the power button)
7. The yellow error led should light up and the New Hardware Instalation wizard should appear on your desktop; click the automatic install, or use the instalation cd's.
8. Now you can release the power button
9. Use the mptool to reset the cartiges
10. Restart the printer
Now it should work, let me know if it worked please tony10dj@yahoo.com
tony10dj@gmail.com
howto.web.contact@gmail.com
Posted on Feb 02, 2010
I installed a new black catridge. The error(E) keeps coming up. can u help me
MP190, u must be using PG40, CL41 for your printer.
Well, if you used brand new original cartridge you should have any problem.
(except, some mechanical problem occurs)
If you not, may be used competible, or refilled cartridge, you may have to face some cartridge error, called e5 error.
What this is "cartridge is not readable at the printer" due to not proper cartridge has been used.
In this case, there is no other solution except buying new cartridge.
The only way is prevent from e5 error occurs.
1. Always "unplug" the power cord, before ejecting cartridge.
2. And also, install your cartridge under unplugged condition.
This is some happen at only "CANON" printer.
I could see many solution on web, but non of them works!!!
Jun 15, 2011 | Canon PIXMA MP190 All-In-One InkJet...
My canon MP 145 printer displayed E5. How can I solve my problem?
E5 means your cartridge error. May I know are you using original ink cartridge or yours has been modified before?
I assume you to refill your ink cartridge before because E5 error won't appear after replacing new cartridge.
So, you need to take out both of your ink cartridge and then use a clean cloth to wipe them. After that, slowly put in back into the printer. If the error is still there after wiping it, try to do it till the error is gone.
I had tested this way with my own printer and it works again without needed to buy a new ink cartridge.
All the best and good luck =)
May 20, 2011 | Computers & Internet
How to error e5 how to go to service mode
Hum....e5 error.
The truth is...there is no solution for e5 error.
U may see some solutions through web, however, non of them works..
The only way you can get out of e5 error, replace with new cartridge..
or...
prevent it...before you face it!!
How?
Whenever you take out the cartridge from printer, make sure unplug the power code first..
and then take and refill or whatever...
And then when you put it back....do it when power code is unplugged as well.
Personally, I refilled and used CL831 more than 8 times..
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 19, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My printer is reading error E5... what does this mean?
May 15, 2011 | Canon PIXMA MP210 InkJet Printer
My canon mp 145 printer after refilling show E5 and not working
the solution is to replace the cartridge with a new one original
e5=cartridge error
Feb 24, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Error code e5?
Good day sir, E5 indicates that the electrics/fuse wire has burnt out in one of your cartridges. Replace appropriate cartridge.
Jul 27, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
E5 for original cartridge
Do not use tissues it leaves residue on the capstan and printing area always use Q tips
May 28, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Mp160
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly.
1. try to take out colour ink and then put in again to see ok or no
2.try to install new cartridge to see ok or no
3.try cleaning head just go to printer preferences go to find services and click clean head.
4.if this all can't is better you send you printer to authorized canon to check you printer is print head problem or no....
Error E5 means a problem with cartridge chipset, here follows reset procedure, it does not always work:
Error E5 is a problem with cartridge ink counter. This happens when you use refilled or not original crtridges.
Try removing cartridges and putting them back in place.
Here is the whole service procedure for Pixma, you must use this to reset the ink counter:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If it does not work you will need to buy a new set of cartridges, possibly original ones. If you just bought cartridges tell the seller they are faulty and ask an original set of cartridges as replacement
Sep 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My canon pixma mp150 is showing error 5?
E5 is saying that ink is not installed, generic cartridges, or not installed properly, If all those are good you could have a defective carriage assembly and need shop work.
Aug 10, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP160 E5 error.
The unplugging procedure is called hard reset, and is useful only when there is no real problem on the printer.
button pressing
procedures below.
procedures below.
If it does not work you will need to buy a new set of cartridges, possibly original ones. If you just bought cartridges tell the seller they are faulty and ask an original set of cartridges as replacement.
Aug 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
146 people viewed this question
old marine
old marine
