Question about Powerline 200Watt DC to AC inverter (0900-35) Power Supply
PC will not turn on
My Dell PC will not turn on after I shut it down. When it is plugged in the light on the power button flashes.
  • smilenow Feb 19, 2008
    Thank you for the quick response. I don't recall haering any beeps and I have not changed anything on the computer. But I have not shut down the computer in months. I usually leave it on all the time but I thougth I was wasting electricty so I turned it off.
Unplug power cord, press power button f a few bseconds, plug power cord back in, wait for 5 seconds and turn power on. This worked for me.
Posted on Apr 19, 2009
  • 3 Answers
I had a similar problem on my Dell Dimension E520
The Help Line Instructed To Switch Off
Remove the cover
Find the Memory Cards
Gently remove then And Carefully Replace Them
This Worked For Me So You Might Like To Give This A try
I think That One Of them Must Have Been Loosened Through Vibration
Good luck
Posted on Mar 18, 2009
    Brigadier General:
  • 3,614 Answers
Got this link posted by some expert (ginko) here, hope it can described more about regarding in your Laptop..
http://www.fixya.com/support/t403660-laptop_died
Posted on Feb 19, 2008
  • 123 Answers
Hello, have you changed anything on your machine, do you get any error beeps?
  • Steve Martyn
    Steve Martyn Feb 19, 2008
    your welcome, have you plugged out the mains cable (Kettle Lead) from the back of the pc for a few minutes, Dell PSU's have been know to trip out. This usually sort's it out, let me know how you get on, Steve...
My computer was downloading windows updates overnight and froze. Tried turning it off from the power button, but did not work so I unplugged the computer. Few hours later I plugged the computer back in and...
You will have to get your power button unstuck. I do not know what type of button you have but if you would like to at least get your PC on without it instantly turning off, you can remove the power switch connector from the motherboard. You will eventually need to have the switch unstuck, or replaced though.
Oct 13, 2013 | Dell Dimension C521 PC Desktop
Dell Inspiron 6000 powers up, caps lock flashes 9 times, then laptop shut down. Why???
Unplug power cord from laptop, remove battery from laptop. Open memory access panel on the bottom of the laptop. Remove memory module(s) (SO-DIMM). Plug power cord back into laptop. Turn laptop on (with the memory removed), the caps lock and scroll lock LEDs light, then the laptop shuts itself off. Unplug power cord from the laptop. Reinstall the memory modules. Make sure they are seated correctly. Put the battery back in, plug the laptop back in, and power on. Laptop should power on and boot up properly.
May need to hold the power button down to get it to power on properly.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 03, 2011 | Dell Inspiron 6000 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a dell dimensions 5100 C and I was using it one day and it all of a sudden shut down. Now when I go to turn it back on the amber led light on the power button flashes, and will not power up....
You need to listen carefully to those beeps they will tellyou in a moment where to start looking for any problem
They are listed in your manual but if you dont have that then they re listed on the dell websiteunder the support section Q and A.
Aug 21, 2009 | Dell Computers & Internet
Dell optiplex gx150 power button just flashes - help?
System seems to be in hibernate or standby mode and frozen in that state. Hold dosn power button for 5 seconds or until all signs of life shut down. Wait about 30 second and power up the system.
Jul 25, 2009 | Dell Optiplex GX270
My dell laptop won't turn on and the two lights
what is the pattern that these lights flash or do they just blink repeatedly?
there is a chance that you will need to replace the system board on this laptop. continually flashing lights usually are an indication of a faulty system board or power supply. with a dell, these are on the same part.
Jul 11, 2009 | Dell Inspiron 8000 Notebook
Inspiron Battery Light Flashing Orange
Battery.
Dell has a chip internal to the battery programed to shut down after a certain number of charge cycles. This means every time you plug the laptop in with the battery installed. When it reaches this determined number the battery effectively shuts down, even though technically it's still good. There have been loads of complaints on the net toward Dell over this issue. I have myself experience this. Battery good one day, powered down, went home, powered up... only to receive the deadly flashing light. Only cure is to replace battery. Several hacks trying to get around this but they're all horrible. Bad Dell - bad, bad Dell!
Jun 29, 2009 | Dell Inspiron 6000 Notebook
4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Apr 11, 2009 | Dell XPS 700 PC Desktop
Dell Desktop
Have you tired holding down the power button. Other wise what model is this computer? And how far into the boot cycle does it get?
Jun 16, 2008 | Dell Computers & Internet
Powerline 200Watt DC to AC inverter (0900-35) Power Supply Logo
148 people viewed this question
Top Powerline Computers & Internet Experts
Chris Larocque
Tom Chichester
Rob Woolcock
Rob Woolcock
Are you a Powerline Computer and Internet Expert? Answer questions, earn points and help others
